| Warning, battery related | |
+4exavid cotetoi Modernman1953 oldwingguy 8 posters |
Number of posts : 1936 Location : Hocking Hills U.S.A. Points : 5152 Registration date : 2016-01-29
| Subject: Warning, battery related Mon May 29, 2017 10:03 am | |
| When I was waking up the S'Wing this spring I noticed some " white powder " on the area below the battery cover, took cover off and found corrosion around the negative terminal. This was on a Power Source sealed battery. I set it aside and replaced it with a new battery. Today I used it as a power supply to test horns. The battery had been in the upright position but it still developed a very noticeable pile of corrosion around the same terminal, this sealed battery apparently is leaking around the base of the terminal. It's easy to forget a battery when it's working but a check on it's condition may save a headache in the future. |
Number of posts : 379 Location : Yuma, AZ Points : 3312 Registration date : 2016-06-01
| Subject: Re: Warning, battery related Mon May 29, 2017 10:57 am | |
| Sorry you are having troubles.
I take my battery out of the bike if the bike is going to be dormant for awhile and bring the battery inside and keep it on a battery tender. |
| Subject: Re: Warning, battery related Mon May 29, 2017 11:21 am | |
| Thanks it was in a warmer than outside garage on a tender. I was just surprised to see a sealed unit leak like this one, hidden under the battery cover it went unnoticed for a couple months. |
cotetoi Silver Wing Expert
Number of posts : 757 Location : New Brunswick, Canada Points : 4854 Registration date : 2013-06-27
| Subject: Re: Warning, battery related Mon May 29, 2017 11:31 am | |
| Subject: Re: Warning, battery related Mon May 29, 2017 3:34 pm | |
| Bummer. Did fluid leak out onto the bike? Any damage you can see? |
| Subject: Re: Warning, battery related Tue May 30, 2017 1:22 am | |
| Just old school but I still have the habit of greasing the terminals after the cable is connected. It does tend to reduce corrosion from condensation around the terminals. |
| Subject: Re: Warning, battery related Tue May 30, 2017 8:24 am | |
| - Modernman1953 wrote:
- Bummer. Did fluid leak out onto the bike? Any damage you can see?
None noted, just the white powder / corrosion, I laid it on it's side for a couple days and no liquid seen. |
Jolly Bodger Maxi-Scooter Rider
Number of posts : 105 Age : 71 Location : Lancashire, UK. Points : 2901 Registration date : 2016-10-05
| Subject: Re: Warning, battery related Tue May 30, 2017 8:45 am | |
| ".....honestly officer it's off the battery!!!" JB |
Number of posts : 1983 Age : 77 Location : Princeton, MN Points : 5847 Registration date : 2014-02-13
| Subject: Re: Warning, battery related Thu Jun 01, 2017 1:29 am | |
| For what it's worth: I've had my Lithium Ion Battery Tender battery in my 08 Swing for a couple of years now with no problems. In the winter I put the Battery Tender Jr. on about every other month just to bring up the charge. There's no acid to leak and so far so good. It starts the SWing with no problems and everything operates great.
Although I've read that they aren't the best in cold weather but seeing as I DON'T ride in cold weather it works great for our two weeks of summer here in Minnesota... :lol!: |
steve_h80 Silver Wing Expert
Number of posts : 998 Location : Teesdale, UK Points : 3980 Registration date : 2016-05-15
| Subject: Re: Warning, battery related Fri Jun 02, 2017 2:26 pm | |
| - Jolly Bodger wrote:
- ".....honestly officer it's off the battery!!!"
JB ... imported from Columbia... ? |
Greysilver Silver Wing Rider
Number of posts : 494 Age : 78 Location : Arizona Points : 4211 Registration date : 2014-04-08
| Subject: Re: Warning, battery related Fri Jun 02, 2017 3:36 pm | |
| I put a battery tender on my battery about every two weeks or after a ride. So far so good. Battery is about a year old. |
| Subject: Re: Warning, battery related | |
