» Sinko De Mayo
Fuel pump problem or what ! I_icon_minitimeby Loosemarbles Today at 3:33 pm
» May 2024 forum picture
Fuel pump problem or what ! I_icon_minitimeby Dale N. Today at 10:44 am
» checking the oil
Fuel pump problem or what ! I_icon_minitimeby GHM-PM Mon Apr 29, 2024 10:13 pm
» Strongly considering a one way ride from Texas to Progreso,Mexico and could use some advice
Fuel pump problem or what ! I_icon_minitimeby GHM-PM Mon Apr 29, 2024 10:08 pm
» LF extended back rest
Fuel pump problem or what ! I_icon_minitimeby Rzor93 Mon Apr 29, 2024 4:14 pm
» FOR SALE - 2009 Silver Wing
Fuel pump problem or what ! I_icon_minitimeby GHM-PM Mon Apr 29, 2024 6:47 am
» Where can I find top-quality electronic tracks?
Fuel pump problem or what ! I_icon_minitimeby GHM-PM Mon Apr 29, 2024 6:43 am
» Forgive My Rookie Questions
Fuel pump problem or what ! I_icon_minitimeby Erdoc48 Mon Apr 29, 2024 6:28 am
» Silver Wing for sale - UK
Fuel pump problem or what ! I_icon_minitimeby StuartBrown Mon Apr 29, 2024 5:15 am
» Top Box considering that Hi-vis and LED's are my friends
Fuel pump problem or what ! I_icon_minitimeby Tbear Sun Apr 28, 2024 12:54 pm
2 posters
codge
Number of posts : 16
Registration date : 2011-08-24
Fuel pump problem or what ! Empty
PostSubject: Fuel pump problem or what !   Fuel pump problem or what ! I_icon_minitimeThu Nov 16, 2017 12:44 pm
Hi All,
My ultra reliable 04 (D3) Swing has started giving me trouble. Reading other posts it seems as thought it might be the fuel pump, but I am open to suggestions.
Here's what happens, the engine turns, but mainly refuses to fire, every now and then it will fire up but only runs on one cylinder, will not rev and then dies after about 5-10 seconds.
Ive put in a new battery and spark plugs today. When I operate the kill switch I get a weak sound from (the pump ?). It is different from the higher pitch sound I used to get. The F1 light comes on when the kill switch is on and goes off after a few seconds. It does not blink or stay on at any time. The V light is on because I need to replace the drive belt which I have ready. The bike has done 16,500 miles and is always garaged.
Any help would be gratefully received. Thanks Codge.
PostSubject: Re: Fuel pump problem or what !   Fuel pump problem or what ! I_icon_minitimeThu Nov 16, 2017 2:26 pm
Might be worth taking off the right hand side lower panel (under footboard) & check the condition of the H.T coil connections ?
After refusal to start are the sparkplugs wet ? (Clogged air filter/faulty choke)
When it does start what are the rev's at idle ?
codge
PostSubject: Re: Fuel pump problem or what !   Fuel pump problem or what ! I_icon_minitimeThu Nov 16, 2017 4:29 pm
Hi
The plugs were slightly wet, Ive seen them worse on other vehicles.
The engine barely reached tickover speed before cutting out.
I will take off the panel you suggested and check it out tomorrow.
Thanks for your kind reply.
» J-Bart fuel-ing problem
» NO fuel pump, rats got into it!
» fuel pump issue
» Fuel delivery system problem
» Fuel pump not making any noise?
