» Greetings from a 'Wing' newbie
Buying Brake Pads I_icon_minitimeby Johnboy Today at 9:35 am
» YSS rear shocks for sale
Buying Brake Pads I_icon_minitimeby StuartBrown Yesterday at 12:11 pm
» checking the oil
Buying Brake Pads I_icon_minitimeby COMick Tue May 07, 2024 9:46 am
» Hobbies? (Besides maxi scooters, of course?)
Buying Brake Pads I_icon_minitimeby Erdoc48 Tue May 07, 2024 6:46 am
» Modifying Honda Silver Wing 600
Buying Brake Pads I_icon_minitimeby Frenchy Sat May 04, 2024 4:11 pm
» Poor man’s Power Commander: IAT Sensor modification (Intake Air Temp Sensor)
Buying Brake Pads I_icon_minitimeby gavinfdavies Fri May 03, 2024 3:33 am
» Sinko De Mayo
Buying Brake Pads I_icon_minitimeby GHM-PM Thu May 02, 2024 7:10 am
» May 2024 forum picture
Buying Brake Pads I_icon_minitimeby MikeO Thu May 02, 2024 4:42 am
» Strongly considering a one way ride from Texas to Progreso,Mexico and could use some advice
Buying Brake Pads I_icon_minitimeby GHM-PM Mon Apr 29, 2024 10:08 pm
» LF extended back rest
Buying Brake Pads I_icon_minitimeby Rzor93 Mon Apr 29, 2024 4:14 pm
 Buying Brake Pads
3 posters
africa1228
africa1228
Number of posts : 24
Registration date : 2023-04-19
Buying Brake Pads Empty
PostSubject: Buying Brake Pads   Buying Brake Pads I_icon_minitimeMon May 01, 2023 12:19 pm
I am planning on pulling the calipers apart and checking them and figured I might as well just change the brake pads at the same time.
But... when I look at the subject here on the forum and also on YouTube I see that the pads in the front have anti-rattle clips? and a white plastic seemingly designed to keep the brakes quieter.
The front calipers have only one plastic and the rear has two.
Now, I cannot find OEM parts online (will have to go to a dealer I guess) so I cannot see what is in their kit when you buy OEM pads, but the aftermarket pads do not seem to have the clip nor the white plastic as part of the kit and I cannot find them separately either.
Any advice would be appreciated.
Also, I have seen comments about stainless brake cylinders as well... any advice on caliper rebuild kits would likewise be appreciated.
Number of posts : 1567
PostSubject: Re: Buying Brake Pads   Buying Brake Pads I_icon_minitimeMon May 01, 2023 1:49 pm
I've always inserted the metal anti-rattle shims. As for the plastic inserts I used trial and error.
With the pistons 'all the way back' in the caliper, I used the plastic inserts if they fitted comfortably when sliding in the pads. If not, I left them out. I'm not sure of their purpose, maybe some kind of extra anti-rattle job.
My logic tells me that it provides a bit of extra reach before the pistons become 'exposed' as the pads wear down. Question
africa1228
africa1228
PostSubject: Re: Buying Brake Pads   Buying Brake Pads I_icon_minitimeMon May 01, 2023 2:21 pm
Thanks. Did your new pads come with that plastic insert and the metal clip? Did you use OEM pads or aftermarket? I am told by the Honda dealer here that the pads have been discontinued.
PostSubject: Re: Buying Brake Pads   Buying Brake Pads I_icon_minitimeMon May 01, 2023 2:40 pm
OEM seem to be available in the UK. However, other companies provide them, maybe EBC?
I can't remember which came with plastic bits. Actually, I don't think they are 'that' important.
Stainless steel pistons are a worthwhile investment.
JohnyC
JohnyC
Number of posts : 301
PostSubject: Re: Buying Brake Pads   Buying Brake Pads I_icon_minitimeMon May 01, 2023 5:39 pm
Hi africa1228.
Ref Stainless steel caliper pistons.
Follow this link for front.
https://www.ebay.co.uk/itm/164067731261?fits=UKM_Make%3AHonda&hash=item263332e73d:g:o~4AAOSwSABeOmtM&amdata=enc%3AAQAIAAABAO0pJZFGGqwdA%2Bre89M%2FWfiBuir696QIZd%2FoduOCCcksrETz8EXoGKZi3bzhADHivpdYisjGM4js2C%2FXa352G2DcnDj8gvTg96fX9Cr2pDb0yzswThjr7whvjx2glKdAWYYIbCVq3q4f4pQHSLmIrSXjU%2BagDLda2eqZcpW8qB3bY4d9a60R%2BZoQShTkSgzwYDqVHBgNEmahjHA8dfD03TWf%2FxfiaY0uaAKkNup%2BmnA2aRR6KB8JtR0DJbZHTvl7xMxAReWq3zI04aOv84AUuHpZ0DpaYt0e%2FyAE2CXCoJjQUU4qFVoBG5%2Fkyb9TcEEdkdx%2FdfWoPN%2BCDsxcEWfW2YU%3D%7Ctkp%3ABFBMvLfKk_th
Follow for back.
https://www.ebay.co.uk/itm/133578210211?fits=UKM_Make%3AHonda&hash=item1f19e1bba3:g:cNcAAOSwFJRdgdXZ&amdata=enc%3AAQAIAAAA4Abnk%2FD%2FsTduN84heeU5YtBoM0snR1qB2b%2BSep5fz29hsRA8Fq9vA3ScxKArP22MpHHrwfpRF3qwZ%2BKoklKIbizuNnscwdhVwvDqfLcKw%2B20VNKqT6c64lBdDYkDlPmlYS5pNGpB7r8WtUZxFuoR01LA7%2BhbIs5lxeju35WQBfENcNTQ994wB7ehyaSRfSaknFb%2Ff2AO62N0t0lvBtHqZjvdImB8CJvlCNTo44pUTQBigR9dB09ZksTvhP4TPu%2BOw4nolgNvAxrS2fSWWsbGuGPotxD8hE2L6SWyFQtkAN9R%7Ctkp%3ABk9SR_r0-ZP7YQ
Hope this helps.
Be safe, be seen!
africa1228
africa1228
PostSubject: Re: Buying Brake Pads   Buying Brake Pads I_icon_minitimeTue May 02, 2023 12:32 am
Thanks sp much for your help JohnyC and Loosmarbles! Truly appreciated!
Buying Brake Pads
» Brake pads
» Brake Pads
» Brake pads.
» Brake pads
» New brake pads
