| Replacing front indicator bulb. How? | |
MarkF Scooter Rider
Number of posts : 7 Location : UK Points : 1275 Registration date : 2020-11-20
| Subject: Replacing front indicator bulb. How? Sat May 08, 2021 5:54 am | |
| Last week my dash indicator signal flashed double quick, a quick look & the throttle side front bulb is out. I cannot find info on the forum on how to replace it so I followed headlight bulb info........
With the front panel removed I can see the rear of the bulb housing. I've got small hands so can reach in, the headlight bulbs are accessible but I've short fingers, I can't get any leverage on the turn unit, even if I could I wouldn't be able to get it back in. Am I missing something? |
Number of posts : 4179 Location : York, North Yorkshire, England UK Points : 9208 Registration date : 2010-11-16
| Subject: Re: Replacing front indicator bulb. How? Sat May 08, 2021 6:39 am | |
| Not really, if you've got the front windscreen garnish off. Just reach in and turn the bulb socket anti-clockwise to remove it. It is a confined space but you get quite adept at it once you've poked around in there a couple of times. It doesn’t help either that the heat in there makes the dust covers a bit sticky when changing headlight bulbs. So a spray of rubber and plastic lubricant when you're in there makes things easier next time you want to replace or upgrade a bulb. |
Number of posts : 4416 Age : 81 Location : damn near Philadelphia, PA Points : 10549 Registration date : 2009-06-12
| Subject: Re: Replacing front indicator bulb. How? Sat May 08, 2021 10:32 am | |
| Aw, ya missed it Meldrew. The guy wants to replace a front turn signal bulb. Which is a bigger PITA than the headlight bulb.
Sorry, I’m too ham fisted to have attempted a turn signal bulb in situ. When the time comes I’ll just remove the front fairing (“front cover” in Honda speak) and change them to LED’s and do the turn signal flasher upgrade.
Now hopefully someone who’s actually replaced a turn signal bulb will chime in with some advise for MarkF. |
| Subject: Re: Replacing front indicator bulb. How? Sat May 08, 2021 11:09 am | |
| Well never having to change one myself, I blew the dust off my FSM and referred to that. If you want PITA don't mess with those 5w pilot bulbs unless absolutely necessary, because they'll be squeezed off their connector and drop down into the headlight reflector.
All is not lost though as you gain great manual dexterity skills disconnecting the headlight bulb dust cover, connector, and headlight bulb to to retrieve these pesky bulbs with numerous attempts with a flexible grab. Which of course you'll have to purchase unless you already have one.
It's all good experience though and well worth the scratches on the back of your hand.
MarkF Scooter Rider
| Subject: Re: Replacing front indicator bulb. How? Sat May 08, 2021 12:49 pm | |
- Aw, ya missed it Meldrew. The guy wants to replace a front turn signal bulb. Which is a bigger PITA than the headlight bulb.
Now hopefully someone who’s actually replaced a turn signal bulb will chime in with some advise for MarkF. Thanks, yes like I said...........I can reach in but only just touch the bulb holder, not get any grip on it. Maybe I'll have to look at fairing removal or look at the neighbours kids for a potential bulb removal candidate. |
MarkF Scooter Rider
| Subject: Re: Replacing front indicator bulb. How? Mon May 10, 2021 5:38 am | |
| Can't believe that the front has to come off to change a turn bulb. There has to be a way, I can't be the only one who's had turn bulb fail. |
MarkF Scooter Rider
| Subject: Re: Replacing front indicator bulb. How? Sun Aug 08, 2021 12:36 pm | |
| The fairing had to come off, to replace a bulb..............I ran out of neighbours kids in the end and gave up. |
MarkF Scooter Rider
| Subject: Re: Replacing front indicator bulb. How? Sat Sep 04, 2021 12:20 pm | |
| Hmmm it's gone pop again............tbh this bulb business is having a dispropotionate affect on my feelings towards this bike. This time I've taken more interest, the new bulb is fine, the socket super clean. After reading a few old posts, I've taken apart the handlebar switch assembly and cleaned it thoroughly with contact cleaner. Still no go, it can't be the relay as the other three bulbs function and I'd have thought a wire issue would likely have produced an intermittent fault before failure?
Ideas? |
Number of posts : 3298 Age : 84 Points : 9245 Registration date : 2009-08-18
| Subject: Re: Replacing front indicator bulb. How? Sat Sep 04, 2021 3:40 pm | |
| Subject: Re: Replacing front indicator bulb. How? Sat Sep 04, 2021 4:45 pm | |
| It doesn't. I had a look through the FSM recently before I sold it and it's just basic info. Access to the front indicator bulbs really is difficult and restricted, and it must be very annoying and frustrating for MarkF. |
| Subject: Re: Replacing front indicator bulb. How? | |
