| Givi Monolock Top box E370 | |
+4john grinsel Silver Dave K model28a gary.meehan 8 posters |
gary.meehan Scooter Rider
Number of posts : 1 Location : Dagenham, Essex Points : 2895 Registration date : 2014-06-20
 | Subject: Givi Monolock Top box E370 Fri 20 Jun 2014, 15:41 | |
| I have been asking around and I am increasingly frustrated with the lack of knowledge from suppliers not knowing if this box will fit my Honda Silverwing 2002 600cc Scooter. Does anyone know if it will and does it come with a base plate that I can just attach without any drilling? Many thanks
Regards,
Gary |
Number of posts : 2085 Age : 69 Location : St.Pete.FL. Points : 6642 Registration date : 2010-02-04
 | Subject: Re: Givi Monolock Top box E370 Fri 20 Jun 2014, 21:01 | |
| You'll get better help if you go HERE first and introduce yourself. It's just common courtesy to introduce yourself before asking questions.  |
Number of posts : 109 Age : 75 Location : Sedro Woolley ,WA Points : 3018 Registration date : 2014-06-13
 | Subject: Re: Givi Monolock Top box E370 Fri 20 Jun 2014, 23:14 | |
| First you need the rack which you can buy at Twisted Throttle. They also have the box. |
Number of posts : 3177 Age : 83 Points : 8395 Registration date : 2009-08-18
 | Subject: Re: Givi Monolock Top box E370 Sat 21 Jun 2014, 01:45 | |
| Remember Givi has 2 types of boxes----Monokey or Monolock---make sure you get right rack OR box can be bolted directly to rear wing----take wing off there are 4 pre- made holes, just drill thru. |
 | Subject: Re: Givi Monolock Top box E370 Sat 21 Jun 2014, 06:17 | |
| On my first Silverwing I bought the bike specific mount for $89 and a $250 Givi box. On the Swing I just bought I just mounted a $40 top box with the mounting plate that came with the box, and a three eighths aluminum plate between the mounting plate and the rear spoiler. I don't see a lot of difference between the Givi and the cheap box. Don't get me wrong the Givi is much better quality, but I'm not sure that the Givi is $299 better. After I've had the cheap box for a few thousand miles I'll know if the Givi is worth the difference. |
Number of posts : 3952 Location : York, North Yorkshire, England UK Points : 8262 Registration date : 2010-11-16
 | Subject: Re: Givi Monolock Top box E370 Sat 21 Jun 2014, 08:33 | |
| - kreiseldave wrote:
- First you need the rack which you can buy at Twisted Throttle. They also have the box.
Why would a UK member import Givi stuff from the USA at when it's available from almost any British motorcycle or accessory dealer? |
 | Subject: Re: Givi Monolock Top box E370 Sat 21 Jun 2014, 08:37 | |
Why would a UK member import Givi stuff from the USA and pay Import Duty and Tax when it's available from almost any British motorcycle or accessory dealer?  |
Number of posts : 3624 Age : 72 Location : Seaham, Co Durham, UK Points : 8563 Registration date : 2009-06-29
| All my Givi stuff came frome here:
http://www.1stlinemotorcycles.co.uk/
Competitive prices and good service. |
Colin B Silver Wing Expert
Number of posts : 586 Age : 70 Location : Windsor, UK Points : 3996 Registration date : 2013-03-20
 | Subject: Re: Givi Monolock Top box E370 Sat 21 Jun 2014, 09:43 | |
Why would a UK member import Givi stuff from the USA and pay Import Duty and Tax when it's available from almost any British motorcycle or accessory dealer?  kreiseldave said, "you CAN buy"; not MUST buy. The important phrase was "First you NEED the rack". No argument there. |
 | Subject: Re: Givi Monolock Top box E370 Sat 21 Jun 2014, 13:32 | |
| Who's arguing, a quick look on www.givi.co.uk gives the OP all the info he needs on the correct rack for the Silver Wing, and it's probably already been covered in previous topics as a quick Search on here would find. You have to drill four holes in the rear rack of the Silver Wing to mount a Givi rack and plate, again it's another topic that's probably been done to death as well, all the info is there if you look. The mounting instructions for fitting any Givi Monorack or Monokey plate and rack are available to download in PDF form from the Givi website if you make the effort to look. |
hotwings Silver Wing Expert
Number of posts : 876 Age : 52 Location : Ontario Points : 4650 Registration date : 2012-04-29
 | Subject: Re: Givi Monolock Top box E370 Sat 21 Jun 2014, 18:22 | |
| - model28a wrote:
- On my first Silverwing I bought the bike specific mount for $89 and a $250 Givi box. On the Swing I just bought I just mounted a $40 top box with the mounting plate that came with the box, and a three eighths aluminum plate between the mounting plate and the rear spoiler. I don't see a lot of difference between the Givi and the cheap box. Don't get me wrong the Givi is much better quality, but I'm not sure that the Givi is $299 better. After I've had the cheap box for a few thousand miles I'll know if the Givi is worth the difference.
X2 |
