» I said Farewell...
this will make you cry I_icon_minitimeby Swingbatter Today at 8:12 pm
» OE Quality Drive Belt
this will make you cry I_icon_minitimeby JohnyC Today at 10:05 am
» LF extended back rest
this will make you cry I_icon_minitimeby Rzor93 Yesterday at 7:21 pm
» New to Me Swing
this will make you cry I_icon_minitimeby Tbear Yesterday at 3:56 pm
» FOR SALE - 2009 Silver Wing
this will make you cry I_icon_minitimeby bkr62rsk Wed Apr 24, 2024 2:28 pm
this will make you cry I_icon_minitimeby zrx212 Wed Apr 24, 2024 12:28 pm
this will make you cry I_icon_minitimeby Meldrew Wed Apr 24, 2024 10:37 am
» Rear shock longevity
this will make you cry I_icon_minitimeby LarryD Tue Apr 23, 2024 10:11 pm
» YSS rear shocks for sale
this will make you cry I_icon_minitimeby Tbear Tue Apr 23, 2024 5:01 pm
this will make you cry I_icon_minitimeby welshman in canada Sun Apr 21, 2024 6:37 pm
algaz2001uk
Number of posts : 2
Registration date : 2016-07-15
this will make you cry Empty
PostSubject: this will make you cry   this will make you cry I_icon_minitimeSat Jul 16, 2016 2:58 pm
Hi I wish I was joining under better circumstances. On wednesday I bought a 2004 SW from Margate, Kent. I am living in Oban and drove back but reached Carlisle. Filled with fuel at the services on restart I had white smoke and loss of power, checked the coolant and it had gone. I presume the cylinder head gasket has gone and it has overheated the block. I was driving through thunder and lightning before I pulled in so it could have overheated without my noticing. has anyone got any advice? seen a engine on ebay for £450 or is it repairable?
PostSubject: Re: this will make you cry   this will make you cry I_icon_minitimeSat Jul 16, 2016 3:28 pm
That's a helluva Introduction. Welcome to the forum. Sorry to hear about your unfortunate crisis. "Odd" that the failure occured just after you took posission. I would sure go back to the seller and seek some redress.
On a related note; I've been active on various Silverwing forums since 2002 and don't ever recall anyone rebuilding an engine. That said, it certainly is possible to replace the head gasket and have the head remachined so that the gasket surface isn't warped. I don't know whether the entire motor must be removed to do that though.
You'll need a Factory Service Manual (FSM). Ebay is your friend.
Registration date : 2008-12-20
PostSubject: Re: this will make you cry   this will make you cry I_icon_minitimeSat Jul 16, 2016 4:38 pm
Welcome to the site and sorry for what happened. I would go back to the person and try to get them to give you your money back or have them foot the bill. They had to know there was a problem with coolant. I haven't heard of people rebuilding SWings either. They seem to be very bullet-proof bikes. I wish you the best and hopefully you can get some help fixing this.
NWSSC
NWSSC
Number of posts : 418
PostSubject: this will make you cry   this will make you cry I_icon_minitimeSat Jul 16, 2016 8:43 pm
Welcome and sorry for your situation.By all means you should contact the seller.How did you make back to your home? I would think even in the rain you would have noticed a misfiring engine.Hopefully you developed a coolant leak and it was spraying antifreeze on a hot engine causing the white smoke and not a internal leak. Let us know. Howard
algaz2001uk
Number of posts : 2
PostSubject: Re: this will make you cry   this will make you cry I_icon_minitimeSat Jul 16, 2016 8:54 pm
Hi Guys thanks for the sympathy, I have contacted the seller and negotiations are proceeding, with regard to the rest of the journey RAC breakdown were amazing picking me up at the roadside and dropping me at home 6 hours later.
The white smoke came from the exhaust on restart, I wish it was as simple as coolant spraying! will keep you posted on engine transplant!
Registration date : 2009-07-18
PostSubject: Re: this will make you cry   this will make you cry I_icon_minitimeSat Jul 16, 2016 9:27 pm
I doubt you'd need a new engine. If it didn't seize there's probably no severe damage done. The loss of coolant could have made it tighten up but as long as it didn't seize hard it's worth a tear down to take a look. I'd agree is sounds a lot like a blown head gasket but I've rebuilt a couple of Goldwings with blown head gaskets that weren't damaged much beyond the gasket. Usually the heads don't warp either and as long as it didn't seize the cylinder bore and piston should be okay as well as the lower end.
There's also a SW engine complete on eBay for $299US.
» Not sure I can make it until spring...
» Soft Grips....Make Your Own!!!
» how to make a back rest?
» Full LED upgrade
» Would make one hell of a pair of boots! OR Three!
