MTH Scooter Rider
Number of posts : 2 Age : 60 Location : New Carlisle, Ohio Points : 3185 Registration date : 2015-08-12
| Subject: First time post long time reader and user. Sat Aug 22, 2015 8:56 am | |
| Hi, This is a great forum. I have been able to replace both tires, drive belt, finale oil drive, coolant flush and many other things. Thanks to all. My 2004 SW pulls to the right real bad when I let go of the handlebars ( Don`t let go LOL ) Miles 30,000 Last year I changed the right fork oil and seals. Can anyone help ? Please and Thank You! |
Number of posts : 247 Location : Hocking Hills Points : 3641 Registration date : 2015-02-08
| Subject: Re: First time post long time reader and user. Sat Aug 22, 2015 11:25 am | |
| My 2004 SW pulls to the right real bad when I let go of the handlebars <<<<<
Under what conditions> road surface, crown, speed?? Was it there before the shock change?? Steering head bearings loose? |
| Subject: Re: First time post long time reader and user. Sat Aug 22, 2015 9:32 pm | |
| MTH welcome to the best Silverwing forum on the web. How long have you had your Silverwing and is it your first scooter/bike? I moved down here from Ohio 1972, sometimes I miss riding the country roads up there. As Oldgwingguy said a little more information could help figure out if you have something that needs fixed. If you plan on doing your own maintenance you'll find you can do anything you need or want with the service manual and help from this forum. I add the paragraph below for most new members because there's a lot of information in the links and may save you some work. Here are some links(3 below in blue)that will help you learn a lot about your Silverwing. If you can't find what you need in the links below the search on this forum works good, and if you still need help just ask and someone will do what they can to answer your questions. Maintenance, Tips and HintsMaintenance "Pictorials" Accessories-Modifications |
Greysilver Silver Wing Rider
Number of posts : 494 Age : 78 Location : Arizona Points : 4211 Registration date : 2014-04-08
| Subject: Re: First time post long time reader and user. Mon Aug 24, 2015 12:12 pm | |
| Welcome to the site from Arizona. |
MTH Scooter Rider
| Subject: Re: First time post long time reader and user. Thu Aug 27, 2015 12:34 am | |
| Thanks everyone, I had a loose bolt on the very bottom of the fork, titan it and no more pull. Just to let you know. |
NWSSC Silver Wing Rider
Number of posts : 418 Age : 86 Location : Mt Prospect IL 30 miles west of Chicago Points : 5639 Registration date : 2010-03-03
| Subject: PostSubject: First time post long time reader and user. Thu Aug 27, 2015 1:00 am | |
| Hello and welcome to the forum. We appreciate your feed back,this is what makes this forum so help full to others. Howard |
| Subject: Re: First time post long time reader and user. | |
