| Opinions wanted on mixing Dr Pulley sliders. | |
+5SCTLVR john grinsel Dale N. exavid model28a 9 posters |
| Subject: Opinions wanted on mixing Dr Pulley sliders. Thu Mar 12, 2015 9:47 pm | |
| I have two Silverwings that I'm going to put Dr Pulley sliders in. What I'm looking for opinions on is I have one set of 21 gram Dr Pulley sliders. I'm thinking of getting a set of 28 gram Dr Pulley sliders and putting four 21 gram and four 28 gram sliders in each scooter. That way I could utilize the 21 gram sliders that I've already got and save some money too. I feel the 21 gram sliders are just too light to use, so unless I mix them with heavier sliders they are useless. Anyone have an opinion they would like to share? |
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Thu Mar 12, 2015 10:16 pm | |
| Seems to me that would increase the wear on the heavier rollers since they'd be taking almost all the pressure in the Variator. The lighter ones would indeed move outward but they'd just be going along for the ride. I've never felt mixing different weight rollers would be a good idea for that reason. |
Number of posts : 1983 Age : 77 Location : Princeton, MN Points : 5847 Registration date : 2014-02-13
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Thu Mar 12, 2015 10:22 pm | |
| Even tho I don't know the answer I agree about not mixing the different weights. It would be advisable to contact Dr. Sliders and ask them. |
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Thu Mar 12, 2015 11:55 pm | |
| I am hoping that some of the forum members that have already mixed different weight sliders will see this post and let me know how things have worked out for them long term. |
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Fri Mar 13, 2015 11:17 am | |
| I think mixing different weights could cause out of balance as things go around?
Stock stuff has worked well for me-----want different performance? get different bike. |
SCTLVR Maxi-Scooter Rider
Number of posts : 186 Location : Fairfield, CA Points : 4528 Registration date : 2012-06-27
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Fri Mar 13, 2015 12:25 pm | |
| Just be certain the low-mass weights are at 180 degrees from each other and you will have no issues. Mixing weights is very common practice with this type of CVT. |
Number of posts : 2596 Age : 64 Location : Bay Area, Ca Points : 8453 Registration date : 2008-12-19
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Fri Mar 13, 2015 3:10 pm | |
| As "SCTLVR" said, if you alternate the weights you will be good to go. So if you are mixing 28gr and 22gr you would have them in this order:
28, 22, 28, 22, 28, 22, 28, 22
This will make the variator balanced. |
masscoot Silver Wing Rider
Number of posts : 438 Location : Central New England Points : 5972 Registration date : 2009-03-24
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Sat Mar 14, 2015 2:08 pm | |
| I've have a mixed set (21/28) installed, no balance issues that I have experienced. I purchased a 28g set in 2009. They were a great improvement (IMHO) over stock rollers. Our good friend JeffR had a set of 21g for sale, so I bought them to try. They were great fun, fast take-offs! However, I decided to mix them for quicker take-offs with no sacrifice of top end speed. Yes, I have them in alternating slots 21-28-21 etc.
I clean and inspect the belt/variator regularly and have found no issues. They really smooth out the 20-40 mph power band. Note: at 15,000 miles I put in the second of the two sets (21/28g) to see if there was any notable performance difference, what I found was that they were more robust! Just like a new pair! Roger, you can utilize them by mixing and get a smoother ride as a bonus! |
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Sat Mar 14, 2015 4:44 pm | |
| Thank you Paul that's the information I was looking for. I knew someone was running that setup but I couldn't remember who. I've been running 26 gram sliders in my first Silverwing for three or four years and I like them alot. I figured since I've already got a set of 21 gram if I mixed them with 28s I'd end up close to what I'm running in my other one, and only need to buy one more set. I guess you could call me cheap. |
DickO Founding Member
Number of posts : 1018 Age : 79 Location : Atchison, KS Points : 6752 Registration date : 2008-12-23
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Sat Mar 14, 2015 11:53 pm | |
| "model29a"... I think I'd refer to it as "efficient"... rather than cheap... it's nice to know the info gleaned from those who are " experimenting " for the rest of us. |
hotwings Silver Wing Expert
Number of posts : 876 Age : 54 Location : Ontario Points : 5356 Registration date : 2012-04-29
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Sun Mar 15, 2015 11:43 am | |
| Paul,
I'm glad it worked for you. I liked the 21 grams at first but after awhile I just thought it was running at too high of rpm's at lower speeds. I have to say that they were like the J Costa in terms of acceleration though. I would race mc's off the line and the SWing is very quick with 22 grams. |
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Sun Mar 15, 2015 2:59 pm | |
| Solved it. Sorry didn't read model28a's first post, just his last. I guess the bike with the 26 gram sliders in his last post is no longer in his possession but another has taken its place with the 21 gram sliders. Got it!!! |
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Sun Mar 15, 2015 8:36 pm | |
| I find that I like to mix my Dr Pulley's with a 'Jack and Coke" or "Screwdriver with GreyGoose". |
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. Mon Mar 16, 2015 12:56 am | |
| - JeffR wrote:
- I find that I like to mix my Dr Pulley's with a 'Jack and Coke" or "Screwdriver with GreyGoose".
I guess I did ask if anyone had an opinion they would like to share. And I think you're right a few drinks probably would make the decision easier. But I think I'll use a swizzle stick to mix my drinks, my Dr Pulley's get too sticky when I mix my drinks with them. |
| Subject: Re: Opinions wanted on mixing Dr Pulley sliders. | |
