| Newbie needing advice | |
solo Scooter Rider
Number of posts : 2 Location : North America Points : 3593 Registration date : 2014-07-07
| Subject: Newbie needing advice Mon Jul 07, 2014 1:21 pm | |
| Hello all. I am from Canada. Started to ride in 1978 at 25. Rode a Honda for a few years. Didn't ride until I was 50. Rode for a few years. Crashed one bike. Rode for a few more years. Stopped riding for two years. Now at 60 I would like to go back to riding but not sure how much I want to do. So I started to look at small bikes / scooters. Came across a 2006 SWing/ABS with 4800 kilometers. I am considering buying it.
The seller is installing new tires and new battery. This is an estate sale and the scooter has been idle for 2-3 years. It will need an oil / filter change.
What else should I worry about? Belt? Final drive? Etc.
Thanks for your help.
ScooterBJ Maxi-Scooter Rider
Number of posts : 170 Location : Colorado USA Points : 4042 Registration date : 2013-11-14
| Subject: Re: Newbie needing advice Mon Jul 07, 2014 2:01 pm | |
LDB Maxi-Scooter Rider
Number of posts : 157 Age : 67 Location : Houston Points : 3838 Registration date : 2014-05-19
| Subject: Re: Newbie needing advice Mon Jul 07, 2014 4:56 pm | |
| You may want to think about new brake lines and anything else rubber as well. The fuel tank may need cleaned out due to gasoline gumming up from sitting so long. Good luck with it all. |
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8354 Registration date : 2010-02-17
| Subject: Re: Newbie needing advice Mon Jul 07, 2014 5:32 pm | |
| My advice is to go to the top of the forum and read the line about introducing yourself as a sign of Courtesy!! |
solo Scooter Rider
| Subject: Re: Newbie needing advice Mon Jul 07, 2014 6:55 pm | |
| - Hi Yo wrote:
- My advice is to go to the top of the forum and read the line about introducing yourself as a sign of Courtesy!!
Understood. I edited my initial post. |
| Subject: Re: Newbie needing advice Tue Jul 08, 2014 9:40 am | |
| - solo wrote:
Understood. I edited my initial post. Thank you. The introduction is very good and helps people understand your experience and they can give better advice. |
Number of posts : 4416 Age : 81 Location : damn near Philadelphia, PA Points : 10544 Registration date : 2009-06-12
| Subject: Re: Newbie needing advice Tue Jul 08, 2014 10:06 am | |
| As a matter of precaution, and because the scoot has been unloved for so long, you might want to replace the belt. There is a tutorial here on the forum for doing that yourself.
Maybe replace the air filter too.
Parts are available at a discounted prices at www.Partzilla.com. The belt cost just under $100 USD, about $140 from a dealer, and a bazilion dollars in Canada. So if you have a work-around for getting stuff delivered from here now would be the time to use it
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7354 Registration date : 2010-02-03
| Subject: Re: Newbie needing advice Tue Jul 08, 2014 4:01 pm | |
hotwings Silver Wing Expert
Number of posts : 876 Age : 54 Location : Ontario Points : 5362 Registration date : 2012-04-29
| Subject: Re: Newbie needing advice Wed Jul 09, 2014 5:16 am | |
- As a matter of precaution, and because the scoot has been unloved for so long, you might want to replace the belt. There is a tutorial here on the forum for doing that yourself.
Tim Actually a new belt is $135 delivered (ebay) to Canada. Not Partzilla. |
| Subject: Re: Newbie needing advice Wed Jul 09, 2014 6:01 am | |
| That being said, i wouldnt even consider changing the belt at 4800 klms. Dont need to be changed till you hit 25000klm, even then is questionable. My bike is an 05 and im still on the original belt at 21000klm and on the original (manufactured 04) front tire, still looks in excellent condition, however changing tires is the next thing on my list. My bike is always inside when not riding so the havoc created by sunlight is not an issue. Bottom line- if your bike was left in the sun for the past 8 years you've got issues, if it was stored inside your good to go! |
Number of posts : 4178 Location : York, North Yorkshire, England UK Points : 9202 Registration date : 2010-11-16
| Subject: Re: Newbie needing advice Mon Jul 14, 2014 9:19 am | |
| I'm so disappointed, I started reading this topic thinking it was from the Solo, a well known character on UK maxi forums. |
| Subject: Re: Newbie needing advice | |
