Hi, I am opening this site back up for new members. I closed it due to a few members complaining. Please just accept the site for what it is. The site is 'what it is'. We hope you enjoy the site. Please also join www.maxi-scoots.com !!!
» First Road Trip
by Greysilver Yesterday at 11:22 pm
» Hello from Norfolk, VA!
by cotetoi Yesterday at 11:12 pm
» Low rear tire Milage
by Sidewinder Pilot Yesterday at 9:06 pm
» Trike Tire Change ? ( re-post to correct forum )
by Briorick Yesterday at 8:08 pm
» Dusty RearWheel
by oldwingguy Yesterday at 7:02 pm
» Job #1 done, #2 not to sure of.
by Osprey Yesterday at 3:50 pm
» Braking
by Osprey Yesterday at 3:43 pm
» Helpful Tips for Centre Stand???
by MikeO Yesterday at 10:53 am
» Howdy y'all ...
by Sirkitrider Yesterday at 7:07 am
» Bonjour hullo from the Cote d'Azur
by Mech 1 twa Mon Jul 16, 2018 9:18 pm
 Likely new owner needing help
MickP62
Number of posts : 1
Registration date : 2017-03-14
PostSubject: Likely new owner needing help   Tue Mar 14, 2017 4:49 pm
Hi all,
I am looking at a "grey" import Silverwing 400. Now obviously this means a speedo in km/h & a headlight that dips the wrong way. Would the speedo & headlight from a U.K. spec 600 fit? Or can I get a sticker for the speedo?
Any & all help deeply appreciated.
Mick
Art
Number of posts : 272
Registration date : 2015-12-25
PostSubject: Re: Likely new owner needing help   Wed Mar 29, 2017 1:09 pm
welcome! can't answer those questions, sorry
avatar
Number of posts : 2719
PostSubject: Re: Likely new owner needing help   Wed Mar 29, 2017 1:19 pm
This subject has come up before. IIRC it turned out that the km/h speedo wasn't a problem for your MOT inspection. The headlight can be adjusted --both up & down as well as left & right.
You might post your 400/600 interchangeability question to the Singapore Sivlerwing Tech Corner: http://www.singaporebikes.com/forums/showthread.php/325894-lt-Info-gt-Silverwing-400cc-600cc-Tech-Corner
avatar
Number of posts : 3126
PostSubject: Re: Likely new owner needing help   Wed Mar 29, 2017 1:52 pm
Check with a Motorcycle MOT Station; I think you will find that any vehicle registered in the UK must have a speedometer showing Miles Per Hour.
I stand to be corrected but I think a Silverwing headlight doesn't dip left or right, only straight ahead.
avatar
PostSubject: Re: Likely new owner needing help   Wed Mar 29, 2017 5:23 pm
The headlight adjusting info, both horizonal and vertical, is located on page 3-20 of the FSM.
If the kp/h speedo turns out to be an issue email me. I may be able to find a direct color copy of the mph speedo faceplate which you can use to cover over your existing kp/h faceplate. However that will require that you remove the Combination Meter and lens.
Here is a link to that original kp/h - mph discussion: http://www.silverwing600.com/t5944-sw400-from-kph-to-mph
avatar
Number of posts : 224
PostSubject: Re: Likely new owner needing help   Wed Mar 29, 2017 9:08 pm
... snipped ... If the kp/h speedo turns out to be an issue email me. I may be able to find a direct color copy of the mph speedo faceplate which you can use to cover over your existing kp/h faceplate. However that will require that you remove the Combination Meter and lens.
I did the conversion from MPH to KPH when I imported a Honda Reflex to Canada from the USA a few years back. It is possible to dismantle everything and superimpose a new faceplate. The tricky part was aligning the faceplate such that the right speeds i.e. 50 mph lined up in exactly the same spot for the new 80 kph demarcation point. The needles (I did all of the gauges as I changed the background colour combo) were a PITA to remove and reinstall too. You need patience and a steady hand but the procedure is doable ... and ours turned out looking and working great.
