| Variator tool | |
vmaximus Maxi-Scooter Rider
Number of posts : 133 Age : 71 Location : Kirkby in ashfield Nottinghamshire England Points : 4928 Registration date : 2011-04-15
| Subject: Variator tool Mon Jun 03, 2013 3:33 pm | |
| Saturday I decided to make a new Variator holding tool. I made one last year similar to the Y shaped one on this forum and used it when I changed to Dr Pulley sliders and again when I changed the belt. I also used it on my 125 majesty. It worked ok but I found it awkward to hold whilst undoing and re-tighten the centre bolt to the req'd torque. The new one that I made fastens to the frame using the bottom foot rest cover bolt and fits tight across the outer variator plate with 2x6m bolts at 100mm centres into the locating holes on the front plate, once tightened down there is no movement in either the holding tool or the front plate leaving your hands free just to use a socket and torque wrench. I tested it out on Saturday and it worked better than expected. Sorry that I am unable to upload any photo's but there are some in my personnel album. |
RArch Silver Wing Expert
Number of posts : 613 Age : 57 Location : West London, UK Points : 5205 Registration date : 2011-11-07
| Subject: Re: Variator tool Mon Jun 03, 2013 4:46 pm | |
| vmaximus: If you quote my post you will see the links I used which I got from looking at your photo album. Nice piece of work, it certainly looks like it held it solid |
| Subject: Re: Variator tool Mon Jun 03, 2013 6:22 pm | |
| That looks so much nicer than the Y tool or the official Honda tool. AND...small enough to be portable too. So if someone is anxious about a belt breaking while they are touring the tool can be packed along quite nicely.
Nice Job!!!
Now I gotta make myself another one. Any chance of a measured drawing?
Number of posts : 1298 Age : 75 Location : Matheson, Ontario, Canada Points : 5921 Registration date : 2011-11-29
| Subject: Re: Variator tool Mon Jun 03, 2013 6:26 pm | |
| That is a nice and compact tool you made . You made a better hammer. |
Ofer Rothmann Scooter Rider
Number of posts : 48 Age : 47 Location : Israel Points : 4075 Registration date : 2013-05-06
| Subject: Re: Variator tool Tue Jun 04, 2013 1:59 am | |
| Looks great, I'm going to make one! i'm sure it's better than what i'm using... |
| Subject: Variator Tool Tue Jun 04, 2013 10:18 am | |
| Thanks chaps on the interest and comments made regarding the tool. It could have been made a little smaller and lighter but the steel bar that I used was the only size that I had. A big thank you to RArch for uploading the 2 photo's for me.
| Subject: Re: Variator tool Fri Jun 07, 2013 5:43 pm | |
| Any chance of a measured drawing? |
| Subject: Re: Variator tool | |
| Variator tool | |
