| Givi topbox baseplate & backrest fitting | |
Atrick Maxi-Scooter Rider
Number of posts : 198 Age : 75 Location : England Points : 4467 Registration date : 2012-09-04
| Subject: Givi topbox baseplate & backrest fitting Thu Sep 20, 2012 1:20 pm | |
| I've just bought a Givi SR19 baseplate & TB19 backrest an although the backrest fitting pictures make it seem easy enough, I'm not so sure about the baseplate as there's no template or guide as to where to drill. Daft question 1: Do the items use any of the same drilled holes? Daft question 2: Anyone any idea as to which is the best order to drill/fit them? Maybe I'm just a bit paranoid about making holes in my nice new shiny paintwork...!! |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7349 Registration date : 2010-02-03
| Subject: Re: Givi topbox baseplate & backrest fitting Thu Sep 20, 2012 4:22 pm | |
| Remove the rear spoiler and take off the undercover and you will see where to drill the holes. Yes the holes for the backrest are two of the holes for the base plate. |
| Subject: Re: Givi topbox baseplate & backrest fitting Thu Sep 20, 2012 5:06 pm | |
| Thanks for that Roger, I guess it would've been obvious once I got going however feel much happier now. |
| Subject: Re: Givi topbox baseplate & backrest fitting Thu Sep 20, 2012 8:08 pm | |
| You are quite welcome. We are all hear to help when we can, and learn from others when we can. I'm glad to help when the easy questions come up. |
JeffR_ Site Admin
Number of posts : 1103 Age : 64 Location : Bay Area, Ca Points : 8866 Registration date : 2010-05-12
| Subject: Re: Givi topbox baseplate & backrest fitting Fri Sep 21, 2012 12:39 am | |
| Gerry, I did a pictorial a few years ago so you may want to look at it. https://www.silverwing600.com/t31-givi-passenger-backrest-installation-pictorialJust drill out the 4 holes. The pictorial shows 2 to drill out for the backrest but you will see the other 2 that is pretty obvious. If you need more help just get back to us here. Just be careful because the drill bit will go right through the material pretty quick. So don't think it will take much pressure to push the bit through. |
| Subject: Re: Givi topbox baseplate & backrest fitting Fri Sep 21, 2012 3:15 am | |
| That's great JeffR, it's now very clear. There's no guidance on the fitting instructions for the baseplate but from looking at the backrest instruction pics I had assumed this to be the case, however I just wanted to be sure!
As I want to get this done today, my thanks to you & Roger for your very rapid assistance. :not worthy: |
Number of posts : 3790 Age : 74 Location : Seaham, Co Durham, UK Points : 9450 Registration date : 2009-06-29
| Subject: Re: Givi topbox baseplate & backrest fitting Fri Sep 21, 2012 5:42 pm | |
| I can confirm that using Jeff's pictorial for the backrest makes fitting both backrest and topbox mount very easy - the 'extra' bit is obvious when you get the spoiler apart. |
| Subject: Re: Givi topbox baseplate & backrest fitting | |
