I have the following problem: Whenever it's cold in the morning, the turn signal doesn't work, neither on the right nor on the left. When the sun shines on it, at around 20 degrees Celsius, everything works as it should. Why can that be. I've already sprayed in contact spray, that helped for a day. Do I need the whole control panel again?
greeting
