» Sinko De Mayo
Crankshaft left oil seal? I_icon_minitimeby Loosemarbles Today at 8:33 pm
» May 2024 forum picture
Crankshaft left oil seal? I_icon_minitimeby Dale N. Today at 3:44 pm
» checking the oil
Crankshaft left oil seal? I_icon_minitimeby GHM-PM Yesterday at 3:13 am
» Strongly considering a one way ride from Texas to Progreso,Mexico and could use some advice
Crankshaft left oil seal? I_icon_minitimeby GHM-PM Yesterday at 3:08 am
» LF extended back rest
Crankshaft left oil seal? I_icon_minitimeby Rzor93 Mon Apr 29, 2024 9:14 pm
» FOR SALE - 2009 Silver Wing
Crankshaft left oil seal? I_icon_minitimeby GHM-PM Mon Apr 29, 2024 11:47 am
» Where can I find top-quality electronic tracks?
Crankshaft left oil seal? I_icon_minitimeby GHM-PM Mon Apr 29, 2024 11:43 am
» Forgive My Rookie Questions
Crankshaft left oil seal? I_icon_minitimeby Erdoc48 Mon Apr 29, 2024 11:28 am
» Silver Wing for sale - UK
Crankshaft left oil seal? I_icon_minitimeby StuartBrown Mon Apr 29, 2024 10:15 am
» Top Box considering that Hi-vis and LED's are my friends
Crankshaft left oil seal? I_icon_minitimeby Tbear Sun Apr 28, 2024 5:54 pm
4 posters
peterb
peterb
Number of posts : 11
Registration date : 2017-07-06
Crankshaft left oil seal? Empty
PostSubject: Crankshaft left oil seal?   Crankshaft left oil seal? I_icon_minitimeMon Jul 17, 2017 3:38 pm
Hello,
Can you suggest a reliable distributor, Ebay seller, etc., where I can buy the crankshaft left oil seal (91201-MCT-003 or equivalent) in a short time, with resonable price and postal fee and primarily from an EU country?
I ordered it from a big, local, vehicle parts distributor on 23-06, they promised 1-2 weeks delivery, and until now they can tell me nothing about the current location and delivery date...
efinglada
Number of posts : 29
Registration date : 2020-02-12
PostSubject: Re: Crankshaft left oil seal?   Crankshaft left oil seal? I_icon_minitimeMon Dec 20, 2021 10:09 pm
Hi to all,
Does anyone know if to change the crankshaft's left side oil seal, it is possible to do it removing the belt case-swing arm with the clutch and final reduction, all in one piece?
Regards
Eduardo
PostSubject: Re: Crankshaft left oil seal?   Crankshaft left oil seal? I_icon_minitimeMon Dec 20, 2021 10:30 pm
Yes. Obviously the variator assembly must be removed but no need to remove the Driven Pulley/Clutch/Final Drive assembly.
efinglada
PostSubject: Re: Crankshaft left oil seal?   Crankshaft left oil seal? I_icon_minitimeMon Dec 20, 2021 11:25 pm
Thanks CJ,
That is what I mean. The belt case gets dirty with dust+oil due to a very small leak, since I bought my SW two years ago. So I think I will try to replace the seal
Also, the lower half of the engine gets oily, so the oil seal on the alternator side must be the cause? Is there another place from where the engine sweats oil?
Besides that it runs as it should and I don't have to add oil, so the loss is minimal, just a drop once in a while in the garage floor
Number of posts : 1382
PostSubject: Re: Crankshaft left oil seal?   Crankshaft left oil seal? I_icon_minitimeWed Dec 22, 2021 1:38 am
Over filling the rear diff. will also cause a leak into belt case. Over filled it once and cost me a belt and under hard acceleration belt was slipping made a loud noise and felt the loss of drive.
Alternator cover a known leak. Had a bad water pump also minor leak after long rides just a drop or two. Two weep holes on pump one coolant other oil.Crankshaft left oil seal? Img_2013
PostSubject: Re: Crankshaft left oil seal?   Crankshaft left oil seal? I_icon_minitimeWed Dec 22, 2021 9:03 pm
Further to zrx212’s comments regarding the known stator seal leakĀ I’ve spun off the comments about the alternator seal leak to its own topic.
» left crankcase oil seal
» Final Drive Shaft Dust Seal and Oil Seal Replacement Advice Needed
» Right Side Axle 'Dust Seal and Oil Seal' Replacement
» fork removal
