| 12 volt Port | |
+4john grinsel Kenjj50 tinman chazman 8 posters |
chazman Scooter Rider
Number of posts : 9 Age : 64 Location : Minnesota Points : 2930 Registration date : 2016-05-07
| Subject: 12 volt Port Sat Jun 04, 2016 8:59 am | |
| I just picked up a new 2013 Silverwing. I'd like to add a 12 V cigarette lighter port in the left-hand glove box where I see they've added a knockout, but I'm unsure about the best aftermarket kit and wiring. Any tips? |
| Subject: Re: 12 volt Port Sat Jun 04, 2016 9:22 am | |
| Make sure that the cord is at least 6' long ore you will have difficulty getting to the batterie. I don't recommend cutting into the power supply line as it can cause trouble in the long run . A good time to install Oxford heater grips as it is the same work involved , also if you want to install a sound system. |
Kenjj50 Super Scooter Rider
Number of posts : 220 Age : 74 Location : Naperville, Illinois Points : 3371 Registration date : 2015-09-28
| Subject: Re: 12 volt Port Sat Jun 04, 2016 9:33 am | |
| There is a post by TomK on this forum "12 volt power install without removing tupperware". It explains how to step-by-step. I also removed the left passenger foot peg (two bolts) to make threading the wiring easier. Lots of great information on this forum. Check out Accessories and Modifications. |
| Subject: Re: 12 volt Port Sat Jun 04, 2016 10:11 am | |
| Why not do it simplier? I bought plug in from parts store, mounted under seat directly hooked to battery with in line fuse---filed slot in "basket" for wire to pass thru. Rarely use, but works fine with my Aerostich heated bib---bike electric system seems to handle all day rides with bib on=no dead battery=system can balance load. |
Number of posts : 1012 Age : 73 Location : HI Points : 4140 Registration date : 2015-12-18
| Subject: Re: 12 volt Port Sat Jun 04, 2016 7:27 pm | |
| I agree with John. I also did that. Mine mounts up front where the seat meets storage compartment. It has a USB and cigarette lighter ports. I wired it directly to my fused power panel. You can charge your phone and/or tablet under the seat as you drive. My first Swing I installed a power outlet in the left compartment. The only thing I used it for was to charge my phone. Being that it is the locking compartment I stored a lot of stuff in there. Using the under seat storage made more sense to me. |
| Subject: Re: 12 volt Port Sat Jun 04, 2016 9:35 pm | |
| I installed a socket in the left side box on my second SW. I used a 15A radial fuse holder at the battery and ran the wires without removing any plastic other than the left rear cover by using a piece of welding wire (could just as well use a coat hanger wire) to fish the wire through to the front of the fairing to where I could get hold of the wire through the hole where the left box was. It was handy for me to have the outlet in the box so I could leave my GPS or iPhone locked up while charging. |
ScottO Scooter Rider
Number of posts : 49 Age : 61 Location : DeSoto Texas Points : 3900 Registration date : 2013-10-19
| Subject: Re: 12 volt Port Sun Jun 05, 2016 7:09 pm | |
| I installed my socket at the same time I installed my givi airflow. I had to remove the front fairing to look for the rubber grommets that fell off so I went ahead and installed the 12v socket. I used a blade fuse so I only need spare blade fuses. The fuse is under the left passenger foot peg with enough slack so I can replace the fuse without removing the foot peg. |
hondos Scooter Rider
Number of posts : 37 Age : 62 Location : Rogue River Points : 2650 Registration date : 2017-03-11
| Subject: Re: 12 volt Port Sun Apr 23, 2017 12:51 pm | |
| I Installed a Battery tender plug to my battery under the seat, When my Battery is NOT plugged in I can use Battery tenders Power port, plugged into the Battery tender Port for charging the battery, so that I have power under the seat too.
Its a very easy switch from charging the battery, just unplug battery charger cord, and plug in Power port, as a the battery tender is wired directly to the battery and is fused, a relay is all that I installed.
That way I have a power port at the left glove box, and under the seat. |
| Subject: Re: 12 volt Port | |
| 12 volt Port | |
