| Light bar - your opinion | |
+7Art dspevack Easyrider cotetoi Cookie MikeO the_mad_rshn 11 posters |
the_mad_rshn Maxi-Scooter Rider
Number of posts : 121 Location : Virginia near D.C. Points : 3132 Registration date : 2016-03-11
| Subject: Light bar - your opinion Fri Apr 08, 2016 12:28 pm | |
| Hey guys, I am about to make my own light bar similar to what DennisB sells. I will be installing the Optronics running lights that I picked up at Walmart. I am thinking of installing 4 lights. Two vertical pairs. Something that will look like this. Please forgive my poor Photoshopping job. What do you, guys think? Cheers, Mad |
Number of posts : 3790 Age : 74 Location : Seaham, Co Durham, UK Points : 9449 Registration date : 2009-06-29
| Subject: Re: Light bar - your opinion Fri Apr 08, 2016 1:15 pm | |
| Why four lights? Are two not sufficient?
Genuine questions, not finding fault. |
| Subject: Re: Light bar - your opinion Fri Apr 08, 2016 1:41 pm | |
| - MikeO wrote:
- Why four lights?
Genuine questions, not finding fault. Thank you. I figured that brighter is better anyway. Plus it might look pretty cool too. :-) Cheers, Mad |
| Subject: Re: Light bar - your opinion Fri Apr 08, 2016 1:44 pm | |
| Thanks. |
Cookie Super Scooter Rider
Number of posts : 233 Location : Essex UK Points : 4836 Registration date : 2011-10-03
| Subject: Re: Light bar - your opinion Fri Apr 08, 2016 4:13 pm | |
| Can't see a lot wrong with your photoshopping skills there Mad. Now all you've got to do is make it!
I'd probably have settled for two lights simply to reduce the weight on the brackets bearing in mind that when you hit bumps the effective weight of the lamps can easily be multiplied up several times. Considering the state of some of the roads round here that's an important consideration. |
| Subject: Re: Light bar - your opinion Fri Apr 08, 2016 4:25 pm | |
| - Cookie wrote:
I'd probably have settled for two lights simply to reduce the weight on the brackets bearing in mind that when you hit bumps the effective weight of the lamps can easily be multiplied up several times. Considering the state of some of the roads round here that's an important consideration. Thank you, Cookie. This is a very good point that I did not consider. I might double the thickness of some parts of the bracket if I decide to go with the vertical duo. The problem is I have a weak flux welder that does not weld well anything above 1/8". Anyway, we will see. Cheers, Mad |
cotetoi Silver Wing Expert
Number of posts : 757 Location : New Brunswick, Canada Points : 4854 Registration date : 2013-06-27
| Subject: Re: Light bar - your opinion Fri Apr 08, 2016 4:47 pm | |
| I like the idea of more lighting up front. With the weight of 4 lights I'd look at getting beefy bars to keep them from vibrating. If you are concerned about the "welding", you could do a combo nut and bolt plus welding for added security. Of course, the nuts and bolts would be permanent but provide strength. Just my thoughts on yur project. Good luck with the mod. Jay. |
| Subject: Re: Light bar - your opinion Fri Apr 08, 2016 5:04 pm | |
| - cotetoi wrote:
- I like the idea of more lighting up front. With the weight of 4 lights I'd look at getting beefy bars to keep them from vibrating. If you are concerned about the "welding", you could do a combo nut and bolt plus welding for added security. Of course, the nuts and bolts would be permanent but provide strength.
Just my thoughts on yur project. Good luck with the mod. Jay. Thanks, Jay. It is still cooking in my melon so all the ideas are appreciated. I also was thinking of only two lights, like on the original setup, but also installing two LED, short (6" or 8" long) lights stocked one on top of the other and mounted under the bracket, in the middle of it. Like these guys: Pair 20 LED White Daytime Running Lamp Auto Car Fog Light Headlamp Cheers, Mad |
Number of posts : 1012 Age : 73 Location : HI Points : 4140 Registration date : 2015-12-18
| Subject: Re: Light bar - your opinion Fri Apr 08, 2016 9:47 pm | |
| Mad, I have two of the Wal-Mart lights that you mentioned and they are very bright. I believe that four will be too bright for the oncoming vehicle. Like driving with your high lights on. Remember, brighter is good, but blinding the oncoming drivers may be dangerous to you. My 2¢.
dspevack Silver Wing Guru
| Subject: Re: Light bar - your opinion Sat Apr 09, 2016 9:01 am | |
| If I used 4 lights I would aim the lower 2 @ 30 degrees outward and down a little bit, giving me cornering lighting, and the upper 2 forward and slightly down. While its nice to see very far ahead of you, too bright a light can unconsciously attract drivers, like moth to a flame. |
| Subject: Re: Light bar - your opinion Sat Apr 09, 2016 10:18 am | |
| Gents,
Thanks for your advice. It was actually my thought to aim the lights in such way so that I have a much brighter area right in front of me and a bit on the sides, rather than aiming far ahead. This way there should not be a worry for the upcoming traffic.
Cheers, Mad |
Art Super Scooter Rider
Number of posts : 272 Location : Garwood Tx Points : 3327 Registration date : 2015-12-25
| Subject: Re: Light bar - your opinion Sat Apr 09, 2016 10:55 am | |
| That's probably a good idea I don't know about the particular lights you are using but most LED lights have no vertical cut off, and that makes them pretty dangerous to use on the road, as well as illegal, which is why so many of those lights are not DOT approved If those are DOT approved, they will have the vertical cut off, and could be aimed further down the road |
Number of posts : 1984 Age : 77 Location : Princeton, MN Points : 5848 Registration date : 2014-02-13
| Subject: Re: Light bar - your opinion Sun Apr 10, 2016 9:19 am | |
Cheers, Mad Hi Mad, I also have a weak flux welder that I got from Harbor Freight. My professional welder friend who lives across the street also has one. He told me that in order to weld heavier metal with it he heats it up with a torch first then welds it. He said that the only reason it won't weld heavier metal is because these weaker ones don't heat the metal enough to get penetration. By heating the metal red hot first gives the welder a jump start, so to speak. Hope this helped. |
masscoot Silver Wing Rider
Number of posts : 438 Location : Central New England Points : 5972 Registration date : 2009-03-24
| Subject: Re: Light bar - your opinion Sun Apr 10, 2016 11:08 pm | |
| Another example for you. I very rarely ride at night, but this what I use ...for now. Cookie brings up a good point about weight, the two bolts are the only two mounting points in this area but they were never meant to carry too much stress. |
| Subject: Re: Light bar - your opinion Sun Apr 10, 2016 11:16 pm | |
| - Dale N. wrote:
Hi Mad,
Hope this helped. Thank you, Dale. I have the 90A flux core welder from HF too. This is interesting about the heat, as I had no idea it could help. Thank you. Cheers, Mad |
| Subject: Re: Light bar - your opinion Sun Apr 10, 2016 11:19 pm | |
| - masscoot wrote:
Thank you, sir. May I ask you, how good are those MR16 LED's? That is the standard in my light, but just the regular 55W light. Thank you. Cheers, Mad |
Bash On! Super Scooter Rider
Number of posts : 252 Location : Dallas, Texas Points : 3441 Registration date : 2015-08-24
| Subject: Re: Light bar - your opinion Mon Apr 11, 2016 9:04 am | |
| Looks like the center two lights would impinge on the headlight beam. Do they, Paul? |
| Subject: Re: Light bar - your opinion Mon Apr 11, 2016 11:39 am | |
| Dan is the King of Bling, back in the early days there were several of us who couldn't leave well enough alone and had to farkle the hell out our scoots for any number of reasons, comfort or just the enjoyment of tinkering. He and others may be able to give some direction on newer products to look at.
Mad, Its been so long but I think the halogens came with the MR16 base in the lamp. If I remember correctly I had to modify the inside of the lamp housing to remove the elevated piece that the lamp base sat on, so the MR16 LED would fit down further and the cover would fit. The LED replacements I used were the best I could find at the time (2008). They work well, but there are better ones available now. These are mainly for conspicuity and they do get attention, but nothing beats heads up riding!
Bash, no interference with the headlight beam for the same reason as above. |
| Subject: Re: Light bar - your opinion Mon Apr 11, 2016 2:30 pm | |
| Keep an eye on total added current to make sure you don't overload your bike's alternator. Also remember that the system doesn't generate enough juice to begin charging the battery below 3000-3500rpm. The SW has a pretty good generation system but it's easy to overdo it. Stop and go riding in traffic with lots of lights can bring the battery down. |
| Subject: Re: Light bar - your opinion Mon Apr 11, 2016 6:41 pm | |
| - masscoot wrote:
- Dan is the King of Bling, back in the early days there were several of us who couldn't leave well enough alone and had to farkle the hell out our scoots for any number of reasons, comfort or just the enjoyment of tinkering. He and others may be able to give some direction on newer products to look at.
https://www.clearwaterlights.com//products2_pp.html From 800 lumens to 7500 lumens....each! (12 watts to 70 watts) You can turn night into day or land a Boeing 747....pick your poison. (Not cheap!) On my bike I use a pair of fork mounted Darlas. Nice thing about these LEDs are that they are dimmable, and you can hook them up to the horn so that when you beep, they come on full power. Dan |
| Subject: Re: Light bar - your opinion Mon Apr 11, 2016 7:49 pm | |
| I knew it wouldn't take long! Thanks Dan! I was wrong EddieB is the king of bling. You are the king of custom, hands down! |
| Subject: Re: Light bar - your opinion Wed Apr 13, 2016 9:41 am | |
| I decided to just go with two lights for now. I can always add two more holes to the bracket for additional two lights. Here it is. Cheers, Mad |
| Subject: Re: Light bar - your opinion Wed Apr 13, 2016 11:19 pm | |
| Subject: Re: Light bar - your opinion Wed Apr 13, 2016 11:33 pm | |
| - Dale N. wrote:
- Hi Mad,
Looks great! Thank you, sir! Cheers, Mad |
| Subject: Re: Light bar - your opinion | |
