| Battery problem? | |
LewdNcrued Scooter Rider
Number of posts : 5 Location : Glos Points : 3282 Registration date : 2015-06-04
| Subject: Battery problem? Tue Oct 13, 2015 3:47 pm | |
| Hi I've had my silverwing for 6 months and it's been working fine up until the last few weeks, my battery does not hold charge anymore. The first week of the issue I charged it and it lasted a week, since that charge in now needs charging every other day.
Is this just a case of buying a new battery or could it possibly be something else not working correctly?
The bike is a 2003... Not sure how old he battery is.
Many thanks |
| Subject: Re: Battery problem? Tue Oct 13, 2015 6:00 pm | |
| Check the battery volts when it's running about 4000 rpm (while it is up on the center stand). If your charging system is working properly you should read approximately 14 volts. If you are only reading approx 12 volts then your charging system is at fault. If you are reading that 14 volts then your battery needs replacing.
NWSSC Silver Wing Rider
Number of posts : 418 Age : 86 Location : Mt Prospect IL 30 miles west of Chicago Points : 5663 Registration date : 2010-03-03
| Subject: Battery problem? Tue Oct 13, 2015 7:13 pm | |
| By this time a 2003 S/W would have had several battery replacements.As previously stated check the voltage. If any doubt take the battery to a bike shop and have a brake down test done. It has to have a given amps capacity to hold a charge. Howard |
| Subject: Re: Battery problem? Wed Oct 14, 2015 5:26 pm | |
| Thanks very much, I shall test the battery tomorrow |
| Subject: Re: Battery problem? Thu Oct 15, 2015 5:52 am | |
| Ok I've just tested the battery. Not running = 12.5 volts Running at 4000 rpm = 12.7 volts
This obv isn't enough to keep it charged, anyone got any ideas as to what the issue might be?
Many thanks |
Number of posts : 247 Location : Hocking Hills Points : 3665 Registration date : 2015-02-08
| Subject: Re: Battery problem? Thu Oct 15, 2015 6:27 am | |
| The obvious would be the charging system, the alternator stator is on the right hand side of the engine AND a heck of a lot easier to get to than say my old GL 1200. have you gone over all your grounds and electrical connections associated with the charging system? Checked the alternator connector for corrosion ect? |
| Subject: Re: Battery problem? Thu Oct 15, 2015 6:50 am | |
| Not yet, the battery is the only thing I've checked so far |
| Subject: Battery problem? Thu Oct 15, 2015 11:14 am | |
| You have to have the battery(keep it simple)tested. The capacity of battery is measured in amps and must be tested with a load device.The amps is what gives the power. Yes you have to have 14.? volts charging the battery but this has nothing to do with ability of the battery to hold a charge. Howard |
| Subject: Re: Battery problem? | |
