| Colour wiring diagram for early non-ABS | |
SilverFeather Scooter Rider
Number of posts : 20 Location : UK Points : 3579 Registration date : 2014-08-10
| Subject: Colour wiring diagram for early non-ABS Tue Aug 12, 2014 1:01 pm | |
| Please could someone provide me with a colour wiring diagram. My manual is on order from my local Honda dealer but will be here in two weeks.
There is a hole where my storage light should be and 2 wires that have been cut off by the previous owner. I am assuming these are for the trunk light, however I would like to confirm this and purchase the Civic switch light so i can manually turn it on and off.
If someone could be kind enough to take a few pictures for me that would be great.
TIA
Number of posts : 2387 Location : Winnipeg Points : 7700 Registration date : 2010-05-02
| Subject: Re: Colour wiring diagram for early non-ABS Tue Aug 12, 2014 2:07 pm | |
| I will send you an email with the instructions how to get the whole manual from me. |
| Subject: Re: Colour wiring diagram for early non-ABS Tue Aug 12, 2014 4:39 pm | |
| Thanks BigBird.Saved me a lot of hassle! Top bloke! |
Colin B Silver Wing Expert
Number of posts : 586 Age : 72 Location : Windsor, UK Points : 4705 Registration date : 2013-03-20
| Subject: Re: Colour wiring diagram for early non-ABS Tue Aug 12, 2014 5:25 pm | |
| To be honest, I found the position of the fitted light to be useless. Anything pushed to the rear of the seat space blocks the light. Better to fit a stick-on LED light to the bottom of the seat, so illuminating the whole area from above. |
Number of posts : 4178 Location : York, North Yorkshire, England UK Points : 9199 Registration date : 2010-11-16
| Subject: Re: Colour wiring diagram for early non-ABS Tue Aug 12, 2014 6:46 pm | |
| - SilverFeather wrote:
- There is a hole where my storage light should be and 2 wires that have been cut off by the previous owner. I am assuming these are for the trunk light, however I would like to confirm this and purchase the Civic switch light so i can manually turn it on and off
How much nocturnal rummaging about under the seat (trunk? ) are you planning to do to warrant the purchase of a switchable light? It'll still be useless whatever you fit because as Colin B said it's right at the rear of the storage area and the light is easily blocked by anything that's back there. The previous owner probably realised that the interior light was a potentially battery flattening waste of space, cutting wires was a bit harsh when all he has to do was remove the bulb. By all means fit that switchable Honda interior light and I believe it's from an Integra not the Civic, and buy a LED light too you'll need in in the dark to find that light switch! |
| Subject: Re: Colour wiring diagram for early non-ABS Tue Aug 12, 2014 7:37 pm | |
| Chances are I will never use it, however the fact that someone has botched something on the bike is not how I like things. All my bikes when worked on are done as close to OEM spec as possible and attempt to maintain originality to some degree unless being upgraded. There is a gaping hole there with two unaccounted for wires. So i am merely reinstalling a light with a slight upgrade that should be there. The light from the Integra and Civic are the same. I'm sure I will not need a light to find the switch, the beauty of spatial awareness |
Number of posts : 106 Age : 80 Location : Adelaide,Sth.Australia Points : 3878 Registration date : 2014-01-30
| Subject: Re: Colour wiring diagram for early non-ABS Tue Aug 12, 2014 7:56 pm | |
| Getting back to your original question, the two luggage light wires are Light Green and Green. If you think this light position on the Swing is not ideal, my '02 T-Max has this item at the BOTTOM of the underseat space! How silly is that? |
Number of posts : 3794 Age : 74 Location : Seaham, Co Durham, UK Points : 9456 Registration date : 2009-06-29
| Subject: Re: Colour wiring diagram for early non-ABS Wed Aug 13, 2014 10:35 am | |
| I've just had a thought (rare but not without precedent) - one could put a socket on the wires and have a 12V lead-light arrangement to plug into it. I'll leave you to imagine how it would function. |
| Subject: Re: Colour wiring diagram for early non-ABS | |
