Number of posts : 106 Age : 80 Location : Adelaide,Sth.Australia Points : 3875 Registration date : 2014-01-30
| Subject: Handy things to know . Sun Feb 09, 2014 12:20 am | |
| Did you know that the actual valve cap is considered the PRIMARY seal for your your tyre pressure NOT the screw in valve assay in the valve stem . Fit metal caps with an integral seal and tighten a firm finger-tight . Copper and Ali washers can be re used if they are not badly scored - and you are miles away from the nearest stockist ! You just have to re-anneal them . This is a very simple procedure covered by a video on U-tube . Go to " How to anneal a copper washer." |
