» New to Me Swing
charging issue I_icon_minitimeby john grinsel Today at 5:41 pm
» I said Farewell...
charging issue I_icon_minitimeby Swingbatter Today at 3:12 pm
» OE Quality Drive Belt
charging issue I_icon_minitimeby JohnyC Today at 5:05 am
» LF extended back rest
charging issue I_icon_minitimeby Rzor93 Yesterday at 2:21 pm
» FOR SALE - 2009 Silver Wing
charging issue I_icon_minitimeby bkr62rsk Wed Apr 24, 2024 9:28 am
charging issue I_icon_minitimeby zrx212 Wed Apr 24, 2024 7:28 am
charging issue I_icon_minitimeby Meldrew Wed Apr 24, 2024 5:37 am
» Rear shock longevity
charging issue I_icon_minitimeby LarryD Tue Apr 23, 2024 5:11 pm
» YSS rear shocks for sale
charging issue I_icon_minitimeby Tbear Tue Apr 23, 2024 12:01 pm
charging issue I_icon_minitimeby welshman in canada Sun Apr 21, 2024 1:37 pm
 charging issue
genescammell
Number of posts : 4
Registration date : 2012-10-11
charging issue Empty
PostSubject: charging issue   charging issue I_icon_minitimeThu Oct 18, 2012 5:22 pm
i have a 2007 honda fsc600a last week it quit charging and the engine will intermittently cough and quit usually at idle when at speed you just feel a bump this all happened at the same time i do not have any tec info on this unit i am also looking for a service manual i was checking the unit out yesterday and on the rear stand when i run up the rpm's to around 3000 the engine surges a lot but below and above it runs smooth
looking to see if any one has encountered this before the unit has 73000 miles
any help thanks
rollsroyce250
Number of posts : 73
Registration date : 2012-06-21
PostSubject: Re: charging issue   charging issue I_icon_minitimeThu Oct 18, 2012 6:39 pm
73 000 miles?
Probably not worth the parts you're going to have to replace.
Stator, voltage regulator, and fuel pressure regulator.
RArch
RArch
Number of posts : 613
PostSubject: Re: charging issue   charging issue I_icon_minitimeThu Oct 18, 2012 6:41 pm
Check this topic out it sounds similar: https://www.silverwing600.com/t5279-sudden-electrical-failure
Turned out to be a burnt out stator.
http://www.rcmodeltalk.co.uk
PostSubject: Re: charging issue   charging issue I_icon_minitimeThu Oct 18, 2012 10:19 pm
How old is the battery? Will the battery hold a charge? If it runs until you stop the bike may be charging until you stop. If you charge the battery full and let it sit over night how many volts does it have the next day? Need more information. What does this mean? " when at speed you just feel a bump" Question
genescammell
Number of posts : 4
PostSubject: Re: charging issue   charging issue I_icon_minitimeFri Oct 19, 2012 9:42 am
yes 73,129 miles as of 10/18/2012 the battery is 2 years old i tested the battery ok the bike charges some times and some times it will not i have to keep the battery charged all the time the bump i feel is the bike back firing when i am running at highway speeds the power loss for a second and now yesterday the bike at about 10 mph back fired in the intake area a huge cloud of smoke an now it is leaking oil and the sound of the engine has changed so i am in the process of taking off the body panels so i can see what could be leaking oil so bad it used 1 quart of oil in 20 miles as everyone knows mobil 1 is not cheap and i have to fix it i am still making payments my round trip to work and back to home is 116 miles if my wife dose not send me on any side trips i cant afford to drive my truck the fuel cost is to high
thanks
PostSubject: Re: charging issue   charging issue I_icon_minitimeFri Oct 19, 2012 4:06 pm
Could be time to check the valves, 73k is a lot if you haven't checked the valves. Have you done a search for oil leaks in the Maintenance, Tips and Hints section?
tinman
Number of posts : 1298
PostSubject: Re: charging issue   charging issue I_icon_minitimeFri Oct 19, 2012 4:35 pm
I also think that the valve shims need to be replace. To save money remove the tupperware. motorcycle
charging issue
» Low charging
» charging battery
» Battery Charging
» Wing not charging
» Charging system
