| Seat Catches | |
+4Winger61 model28a tinman ronslaverda 8 posters |
ronslaverda Scooter Rider
Number of posts : 26 Age : 83 Location : epsom, uk Points : 3888 Registration date : 2013-10-31
| Subject: Seat Catches Wed Nov 13, 2013 12:59 pm | |
| I have found that I have to slam the seat down very hard to get it to lock, so much so I have taken the bulb out of the under seat storage light. Is there any way to ease this ? Thanks in advance. |
| Subject: Re: Seat Catches Wed Nov 13, 2013 4:10 pm | |
| I don't have to slam my seat but what I do is push hard at the back of the seat. I can and do sometimes ride without the seat latched. I also think that only the back latch is working on my seat. It's been that way from the first day I have it and I have never seen a need to change it. |
Winger61 Silver Wing Rider
Number of posts : 452 Age : 75 Location : Louth, Lincolnshire, UK Points : 5424 Registration date : 2010-10-15
| Subject: Re: Seat Catches Wed Nov 13, 2013 4:21 pm | |
| - model28a wrote:
- I don't have to slam my seat but what I do is push hard at the back of the seat.
+1 for me. A good idea to remove the underseat light bulb - if the seat doesn't latch properly, the light could/would stay on, and you could end up with a flat battery. |
| Subject: Re: Seat Catches Wed Nov 13, 2013 4:34 pm | |
| Yes the underseat light bulb was the first thing to go. I always have a LED light in my pocket that works better than the underseat light. |
Atrick Maxi-Scooter Rider
Number of posts : 198 Age : 75 Location : England Points : 4466 Registration date : 2012-09-04
| Subject: Re: Seat Catches Thu Nov 14, 2013 8:57 am | |
| I do the same as model28a to close my seat and to prevent a flat battery also took out the bulb; it wasn't bright enough to be of any use anyway! |
rjdoles Maxi-Scooter Rider
Number of posts : 140 Age : 76 Location : Columbus, Ohio Points : 4417 Registration date : 2012-09-24
| Subject: Re: Seat Catches Fri Nov 15, 2013 10:57 am | |
| Welcome to the site.
I have problems with the seat latch on my wife's Reflex and on the Silverwing. Slamming either of them usually doesn't do it. I learned that if you just close the lid and then press in the middle of the back of the seat it latches every time.
Enjoy your ride! |
WingMan02 Super Scooter Rider
Number of posts : 287 Location : Honolulu Points : 4815 Registration date : 2012-01-19
| Subject: Re: Seat Catches Fri Nov 15, 2013 5:34 pm | |
| - Atrick wrote:
- I do the same as model28a to close my seat and to prevent a flat battery also took out the bulb; it wasn't bright enough to be of any use anyway!
I replaced the light with one that had a manual on/off switch. You can get it from a Honda car dealer parts department. Use the search feature to get the part number. I only turn it on when needed. Works for me. |
CathyN Silver Wing Expert
Number of posts : 771 Location : USA Points : 5834 Registration date : 2010-11-15
| Subject: Re: Seat Catches Fri Nov 15, 2013 5:46 pm | |
| - WingMan02 wrote:
I replaced the light with one that had a manual on/off switch. You can get it from a Honda car dealer parts department. Use the search feature to get the part number. I only turn it on when needed. Works for me. Wingman, I did the same with my Swing. It works for me too. Wasn't that expensive and easy to do. Better than a dead battery. Plenty of times my seat wasn't closed all the way. Even though I try to be careful. |
| Subject: Re: Seat Catches | |
| Seat Catches | |
