| Connector to disable side stand safety switch | |
Number of posts : 2387 Location : Winnipeg Points : 7709 Registration date : 2010-05-02
| Subject: Connector to disable side stand safety switch Mon Apr 02, 2012 10:52 pm | |
| Subject: Re: Connector to disable side stand safety switch Tue Apr 10, 2012 5:09 pm | |
Number of posts : 4416 Age : 81 Location : damn near Philadelphia, PA Points : 10550 Registration date : 2009-06-12
| Subject: Re: Connector to disable side stand safety switch Tue Apr 10, 2012 5:50 pm | |
| - bigbird wrote:
- I know Dennis was making these. I'm not sure if he's around any more or not.
If anyone wants me to make one of these for them, I can do it. I can also do the "Perfect Connector". Just PM me. Terry If you are going to make a "Perfect Connector"-type connection I do hope that you are able to follow the Honda wire color codes in that location. If you recall, the 'original' version color codes were not consistent with Hondas and tended to cause some deal of confusion --even though a nice illustration came with the product. Tim |
| Subject: Re: Connector to disable side stand safety switch Tue Apr 10, 2012 6:52 pm | |
| Subject: Re: Connector to disable side stand safety switch Tue Apr 10, 2012 10:03 pm | |
| Yeah, that'll be a big help for anyone wishing to use that Connection for aux circuits. May even be a good spot to add on the $5 Hazard Lights components. Rather than splice the wire harness elsewhere. - bigbird wrote:
- I believe Dennis's original perfect connector was wire coloured to match a trailer connector. My colours would be:
Ground --> Green Right Turn Signal --> Light Blue Left Turn Signal --> Orange Brake Lights --> Green/Yellow Running Lights --> Black/Brown
Does that jive with your thoughts, Tim? |
| Subject: Re: Connector to disable side stand safety switch Mon Apr 16, 2012 1:41 pm | |
| Subject: Re: Connector to disable side stand safety switch Mon Apr 16, 2012 1:43 pm | |
| Subject: Re: Connector to disable side stand safety switch Thu Apr 19, 2012 4:56 pm | |
Number of posts : 1099 Age : 70 Location : Cleveleys, Lancashire, England Points : 6336 Registration date : 2010-03-27
| Subject: Re: Connector to disable side stand safety switch Fri Apr 20, 2012 7:25 am | |
| Using that connector you could wire in a switch as well as the side-stand switch so the sidestand would act as normal, the switch would act when switched to the relevant position so you could run the engine with the side-stand down plus the switch could act as an immobiliser. I feel a mini project coming on!
Cheers,
Number of posts : 2453 Location : Georgetown, Tx Points : 8174 Registration date : 2008-12-23
| Subject: Re: Connector to disable side stand safety switch Fri Apr 20, 2012 9:16 am | |
| - tarmacburner2 wrote:
- switch could act as an immobiliser.
That is an excellent idea!! A three-way position switch 1) Normal mode 2) Engine running with side-stand down 3) Immoblize mode (regardless of side-stand up or down ) That would be worth buying. |
| Subject: Re: Connector to disable side stand safety switch Fri Apr 20, 2012 12:22 pm | |
| Bill,
Not a three way position switch but utilising two switches.
When I have figured it out correctly in my head and done the work i'll post a how-to / how I did it on here.
Connector ordered, switch in stock, one already on the scoot.
Cheers, |
| Subject: Re: Connector to disable side stand safety switch Fri Apr 20, 2012 12:27 pm | |
| Subject: Re: Connector to disable side stand safety switch Fri Apr 20, 2012 1:46 pm | |
- Not a three way position switch but utilising two switches.
That will work. First switch 1a) Normal straight through to switch two 1b) Immobilizer mode Second switch 2a) Normal behavior - Only starts with kickstand down 2b) Disable "normal behavior" - Starts with kickstand down *** At your own risk ** I would buy the "first switch" setup!!!! |
RArch Silver Wing Expert
Number of posts : 613 Age : 57 Location : West London, UK Points : 5216 Registration date : 2011-11-07
| Subject: Re: Connector to disable side stand safety switch Fri Apr 20, 2012 2:49 pm | |
| Its too easy for someone to blip the throttle, they would not release that the bike could lurch forward knocking it off the side stand and theres your pride n' joy on the floor Just ride the bike easier until it warms up, you will save fuel too! If you must, maybe a micro switch could be fitted to the throttle which would cut the engine should someone twist it when the side side was down... |
| Subject: Re: Connector to disable side stand safety switch Fri Apr 20, 2012 7:38 pm | |
| My thinking is having another switch so that you can have the engine running whilst the sidestand is down when you need it to be. Having a switched circuit means that under normal circumstances (when you don't need to have the engine running with the sidestand down) you can disable the facility. No chance to idiot blipping the throttle. Going to be a bit busy this weekend stripping the inner front wheel arch on one of the cars in order to get to the washer reservoir and pump - MOT test next Thursday. I may get around to playing with this setup for the Silverwing, it will be a temporary rig up to see if what is in my head actually works - not always successful transferring theory to practice!
Cheers, |
| Subject: Re: Connector to disable side stand safety switch | |
