| Givi AF214 Fitting Issues | |
+8Waspie Skippy DennisB honda_silver mitch Silver Surfer bugrod ehaughn 12 posters |
ehaughn Maxi-Scooter Rider
Number of posts : 131 Age : 55 Location : Norcross, GA Points : 5283 Registration date : 2010-06-13
| Subject: Givi AF214 Fitting Issues Fri Aug 27, 2010 2:19 pm | |
| Hi All,
Thought I would update you on my Givi AF214 installation.
I am a little disappointed with how the installation is going.
First, the windscreen did not fit well over the 6 mounting holes. I had to spread the shield slightly to align the holes.
Second, the left side of the screen extends approximatly 1/2 inch more forward than the right side. I tried for a few hours trying to align this, but nothing seems to work. See pictures.
Also, just an FYI, according to Givi, the bottom holes, you must remove the rubber grommet and insert it into Givi windscreen. I do not recall reading or seeing anything about this.
Any suggestions is greatly appreciated. |
| Subject: Re: Givi AF214 Fitting Issues Fri Aug 27, 2010 2:28 pm | |
| Here are the right side pictures. |
| Subject: Re: Givi AF214 Fitting Issues Fri Aug 27, 2010 10:38 pm | |
| Well, I decided I will not be using the AF214 windscreen.
I remove it this evening.
Interesting, when installing the windscreen, it had to be compressed on the sides for the 6 holes to align on the right and left hand sides. Well, this caused too much stress on the top 2 holes, and actually cracked the upper mounts. And I did use the metal brackets.
Needless to say, I was not happy at all. I contacted Givi and waiting for a response.
Will keep you all posted.
See attached pictures. |
| Subject: Re: Givi AF214 Fitting Issues Fri Sep 03, 2010 4:01 pm | |
| well this isnt good , not seen any problems like this reported, hope you get it sorted out. Rob. |
| Subject: Re: Givi AF214 Fitting Issues Fri Sep 03, 2010 6:04 pm | |
| Thanks.
Givi ordered a call tag and being sent to NC for inspection.
Will keep you all posted. |
bugrod Scooter Rider
Number of posts : 18 Age : 76 Location : Northwest North Dakota Points : 5035 Registration date : 2010-08-05
| Subject: Re: Givi AF214 Fitting Issues Sat Sep 04, 2010 11:02 pm | |
| I just installed a 214 on my '07 SWing and it fit just great.
Bugrod |
Silver Surfer Scooter Rider
Number of posts : 6 Location : Maidstone Kent England Points : 4970 Registration date : 2010-09-26
| Subject: Re: Givi AF214 Fitting Issues Mon Sep 27, 2010 3:24 pm | |
| I recently fitted this screen to my 2010 Silverwing 600. At first I could see no use for the two stainless brackets, thinking I had a later bike, I fitted the screen without them. This worked, but the rubber mounts allowed the screen to flex a little. I re-visited the rather poor pictures sent with the screen, and the penny dropped ! I removed the screen, fitted the brackets, drilling only one hole each side to connect with the thread in the upper frame, and then refitted the screen. Suprise ! the screen is much more solid, still using the three rubber mounts each side. I put this down to the friction generated by the screen abutting the stainless bracket. Hope this helps. |
mitch Scooter Rider
Number of posts : 42 Location : West Lothian, Scotland. Points : 5031 Registration date : 2010-09-10
| Subject: Re: Givi AF214 Fitting Issues Sat Nov 06, 2010 10:55 am | |
| I fitted my Givi AF 214 screen (Including the two metal brackets) today and the forum tutorial helped a great deal.
Everything came off and went back OK but just one question re metal plates.
Each plate comes with two bolts from Givi - One for the end of the plate (Nearest to handlebars) where a hole has to be cut in the plastic to access a predrilled securing point and one in the middle of the plate that replaces a large shiny bolt which fits into fairing and has a collar type spacer / washer.
I kept the two spacer washers out am just wondering if these spacer / collar type washers should in fact have remained in place behind the middle hole of each plate.
Rather than strip it all down again to find out can someone please let me know.
Thanks
| Subject: Re: Givi AF214 Fitting Issues Sat Nov 06, 2010 11:13 am | |
| I found that leaving out the spacers distorted the plates, so I left them in, also I prefered the original bolts to the Give ones, they had a better head, which I felt spread the load better. |
mitch Scooter Rider
| Subject: Re: Givi AF214 Fitting Issues Sat Nov 06, 2010 12:19 pm | |
| Thanks for your prompt reply Silver Surfer
When I was installing the plates I too noticed that the plates were distorting in the middle as the pressure on the plates, which rest on the flanges of two of the tunnel bolts, built up when tightening the plate fitting bolts.
It was not until after full installation that I started to wonder if I should in fact have left the collar / spacers in place especially as I thought that they may also perform some other function as well. Anyway having read your reply I have now stripped the AF214 back off of the bike, loosened up the two plates and reinserted the two collar / spacers.
The plates now fit flush without the distortion in the middle as the washer now takes up the space.
I am now satisfied with the install.
I think mention should be made in the Givi instructions about these collar washers. |
Number of posts : 2453 Location : Georgetown, Tx Points : 8163 Registration date : 2008-12-23
| Subject: Re: Givi AF214 Fitting Issues Sat Nov 06, 2010 12:46 pm | |
| - mitch wrote:
- I think mention should be made in the Givi instructions about these collar washers.
Givi instructions have been horrible ... and continue to be horrible. |
| Subject: Re: Givi AF214 Fitting Issues Sat Nov 06, 2010 3:51 pm | |
| Glad your sorted Mitch. I think ( from memory ) that the collared washers transfer the load to the metal frame beneath the plastic, without it the plastic distorts, hence the bent plates. I have to say that it was the pictures in the instructions which gave me most trouble, a simple diagram would have been better. We live and learn ! |
| Subject: Re: Givi AF214 Fitting Issues Tue Nov 09, 2010 5:56 pm | |
| Hello to you all ... if you install this Givi AF214 on your silverwing make sure to clip properly ... I don `t have done and the top part of the windshield was ejected by the Wind...just pass close to receive the piece in the face...
Stevens as Tiguedooo
Number of posts : 2778 Age : 73 Location : NE Oklahoma Points : 8889 Registration date : 2008-12-28
| Subject: Re: Givi AF214 Fitting Issues Tue Nov 09, 2010 7:18 pm | |
| Hi Stevens, Welcome to the forum. Happy you decided to join in. That must have been darn scarry. How fast were you going when this event happened? |
Skippy Super Scooter Rider
Number of posts : 299 Age : 57 Location : Exeter. Devon. Points : 5358 Registration date : 2010-08-18
| Subject: Re: Givi AF214 Fitting Issues Wed Nov 24, 2010 11:10 am | |
| While tend to agree that the instructions for these could be better, downloading the PDF and blowing them up really does help.
Givi seem to be high on price and customer ergonomics seem to take a rather poorer back seat.
I was a little taken aback that fitting the screen requires the drilling of four new holes. |
Number of posts : 2392 Age : 72 Location : Portland, UK Points : 7939 Registration date : 2009-07-26
| Subject: Re: Givi AF214 Fitting Issues Wed Nov 24, 2010 11:30 am | |
| - Skippy wrote:
- I was a little taken aback that fitting the screen requires the drilling of four new holes.
How four holes? I fitted mine about a week ago and only had to drill two!!!! Looking from the front it was for the last hole on the enclosed bracket. Have I missed something! I used the sheet Givi attached and the guide from this web site. Worried now! |
Number of posts : 3790 Age : 74 Location : Seaham, Co Durham, UK Points : 9450 Registration date : 2009-06-29
| Subject: Re: Givi AF214 Fitting Issues Wed Nov 24, 2010 11:34 am | |
| Don't be - two holes only, one on each side. |
| Subject: Re: Givi AF214 Fitting Issues Wed Nov 24, 2010 4:11 pm | |
| - MikeO wrote:
- Don't be - two holes only, one on each side.
Thanks Mike. |
Ishkatan Super Scooter Rider
Number of posts : 203 Age : 69 Location : Monrovia, Md Points : 5145 Registration date : 2010-11-16
| Subject: Re: Givi AF214 Fitting Issues Mon May 16, 2011 9:24 pm | |
| - ehaughn wrote:
- Thanks.
Will keep you all posted. So what happened? Did they fix your cracked holes? |
Rasherman Scooter Rider
Number of posts : 40 Age : 77 Location : London Points : 5443 Registration date : 2009-07-12
| Subject: Re: Givi AF214 Fitting Issues Wed Aug 03, 2011 2:08 pm | |
| Managed to fit my Airflow 214 today. Many thanks to everybody who has contributed to this discussion. You have been a great help. Bob |
| Subject: Re: Givi AF214 Fitting Issues Wed Aug 03, 2011 4:07 pm | |
| Congrats! Now's the time to show it off to the Burger squad at the Ace at Saturday Breakfast! |
drewscrew13 Scooter Rider
Number of posts : 11 Points : 4524 Registration date : 2011-12-31
| Subject: Re: Givi AF214 Fitting Issues Wed Jan 04, 2012 10:44 am | |
| Hi al I want to put my AF214 on my scooter but have read all of these responses and frankly I'm a bit confused. Drill 2 holes ,Drill 4 holes. I wish someone could tell me where I can go to get the proper was to install the AF214 for I sure the instruction I can go by. I'm not very mechanical incline. Have to be walked thru always. Thanks Drew from Arlington,VA |
| Subject: Re: Givi AF214 Fitting Issues Wed Jan 04, 2012 2:31 pm | |
| Two holes - one on each side/one for each bracket.
When you've got the old screen off, offer up the brackets, one at a time, and gently drill through the hole in the bracket (using the bracket as a guide as to where to drill). |
| Subject: Re: Givi AF214 Fitting Issues Wed Jan 04, 2012 2:36 pm | |
| Bigbird wrote:
Wendell, don't give up. You will have to remove the large shiny bolt with stepped washer that attaches to the steel frame. That's one of the mounting points for the bracket. Do not re-use that big shiny bolt. You will use the round head GIVI bolt in that location. The other holes will align properly with the existing Honda mounting holes for the windshield. There is only 1 hole you will drill. With the bracket correctly aligned, you will see the bent part of the bracket is now towards the rear of the bike, and is angled inwards 45 degrees towards the the centre of the bike. You will drill through that angled hole. Behind that hole is a boss which holds the threads for the other GIVI bolt. That bolt is the socket head bolt as opposed to the pan head bolt. Try again. As they say in the movie "The Waterboy", you can do it!If you type 'AF214' in the Search box and tick 'posts' you'll see this and a few other posts. And this thread has loads of help and suggestions: https://www.silverwing600.com/t2756-givi-af214-metal-bracket-positioning |
| Subject: Re: Givi AF214 Fitting Issues | |
