| Oil change, Air filter anything else? | |
FLAMAUI Scooter Rider
Number of posts : 7 Location : maui Points : 396 Registration date : 2023-04-05
| Subject: Oil change, Air filter anything else? Wed Apr 05, 2023 11:30 pm | |
| Hi everyone, Just got my new 2002 silver wing 27000 miles, Planning to change the oil, filter and air filter. Anything else? What type of oil should I use? Thank you I live on Hawaii. |
Number of posts : 1564 Age : 62 Location : South East England Points : 4505 Registration date : 2016-10-01
| Subject: Re: Oil change, Air filter anything else? Thu Apr 06, 2023 4:10 am | |
| Welcome to forum Flamaui. Please tell us a bit more about yourself like; are you a novice or an experienced rider and do you intend to do your own maintenance etc?
This information helps other members with their replies and advice. Try getting used to using the search bar above using key words... It's a mine of information but also don't be afraid to ask.
Any decent 10w30 oil is ok and the drive belt should have been changed at 16000 miles.
I hope you enjoy your new mount. |
Erdoc48 Touring Scooter Rider
Number of posts : 338 Age : 59 Location : Myrtle Beach, SC Points : 1047 Registration date : 2022-05-31
| Subject: Re: Oil change, Air filter anything else? Thu Apr 06, 2023 7:03 am | |
| Even though mine had low mileage when I bought it, it is a 2003, so now 20 years old. What I did was: -oil/filter -new coolant (VERY easy procedure)- also looked as new at 7300 miles and 20 years. -rear drive oil (also very easy) -new drive belt (you need a torque wrench for this one and the proper tool to lock the variator in place to torque the variator in place- you can make this yourself - I bought the OEM Honda tool)- depends on when your belt and at what mileage it was last changed. It’s a pretty easy procedure as well. -new spark plugs (I used the NGK Iridium type but this is not a necessity- easy to do as there’s only 2 of them!)
The oil for the rear drive as well as the engine is 10W-40 for the temp range you’re in, but 10W-30 up to 20W-50 can be used as well according to the service manual (20W-50 I assume above 100 degrees F). I used 10W-40 for mine
You can find most procedures here on this forum or via YouTube videos. I’ve never worked on a CVT scooter in the past (just my ST1100s) and it’s really straightforward to work on one of these.
I would do lots of research to see what you truly need vs what’s been done in the past by the prior owner. From what I understand, they are VERY reliable bikes, so maintain what’s needed and ride on! |
| Subject: Re: Oil change, Air filter anything else? Thu Apr 06, 2023 1:06 pm | |
| Awesome, Thank you all for the quick response. I'm planning on to get all done by myself. Yes, I have have a torque wrench. One more question, should I use synthetic oil? I guess I can get it at Walmart or O'Reilly's. Thanks again
| Subject: Re: Oil change, Air filter anything else? Thu Apr 06, 2023 2:49 pm | |
| For synthetic, you can if you want (it’s not spec for the bike to use synthetic). If you change it regularly (like yearly), either conventional or blend is fine (I just changed mine a few days ago and had Castrol synthetic blend in 10W-40 in the garage and used that)- on my ST’s, I use Rotella T6 5W-40 (and that’s likely overkill)- I used a HiFlo 204 filter available on eBay. You don’t need much- I believe 2.3 US quarts with a filter change is all the volume you need.
Lastly, when checking oil level (and this is on this forum as well as in the service manual), unscrew the dipstick, clean it, then reinsert but DO NOT screw it down, to get an accurate oil level. If you screw it down, it’ll show more oil on the stick and your actual level will be lower than that. |
| Subject: Re: Oil change, Air filter anything else? Thu Apr 06, 2023 3:02 pm | |
Johnbil09 Maxi-Scooter Rider
Number of posts : 129 Age : 59 Location : Jersey City Points : 546 Registration date : 2023-03-23
| Subject: Re: Oil change, Air filter anything else? Thu Apr 06, 2023 5:28 pm | |
| - Erdoc48 wrote:
- For synthetic, you can if you want (it’s not spec for the bike to use synthetic). If you change it regularly (like yearly), either conventional or blend is fine (I just changed mine a few days ago and had Castrol synthetic blend in 10W-40 in the garage and used that)- on my ST’s, I use Rotella T6 5W-40 (and that’s likely overkill)- I used a HiFlo 204 filter available on eBay. You don’t need much- I believe 2.3 US quarts with a filter change is all the volume you need.
Lastly, when checking oil level (and this is on this forum as well as in the service manual), unscrew the dipstick, clean it, then reinsert but DO NOT screw it down, to get an accurate oil level. If you screw it down, it’ll show more oil on the stick and your actual level will be lower than that. I think worth mentioning is when checking the oil level it’s done on level ground when on its center stand. |
| Subject: Re: Oil change, Air filter anything else? Thu Apr 06, 2023 7:08 pm | |
| Subject: Re: Oil change, Air filter anything else? Fri Apr 07, 2023 1:49 am | |
| Ok, I really appreciate all the great help from this forum . Just changed the oil and filter today. Big accomplishment. The old oil was black. Anyway, I just wondering where are you folks buying the parts? My next wil be the drive belt and maybe the clutch. Any suggestions on places to buy? Thank you again. |
| Subject: Re: Oil change, Air filter anything else? Fri Apr 07, 2023 8:54 am | |
| For the belt, I didn’t go Honda OEM (I got a GBoost belt) I believe on Amazon (model of the belt is DBHOMCT)
For coolant, I used Preston’s pre-mix that’s available at Autozone (and it’s compatible with all formulas, so it’s silicate free)
For oil/ air filters, I bought the HiFlo branded ones on eBay.
If you’re in the driveline case to swap the belt anyway, you can look at the clutch pads (which will probably be fine) and as long as you’re in there, you should re-grease the needle bearings with NLG2 thickness grease (usually the red stuff) and they have that at the auto parts store. I did mine at 7300 miles per recommendations here and mine were black, but not worn (very grateful to those here who recommended I check).
Lastly, if you’re going to bleed the brakes (never a bad idea)- I installed SpeedBleeders on mine (actually, on all my bikes)- I originally screwed up as I tried to pressure bleed them and introduced a bunch of air in the system, so after vacuum bleeding with a hand pump MityVac, I purged the lines of air and installed the Speedbleeders (make sure if you do this they’re nice and snug when tightening them but not over tight). Now I can bleed brakes in 5 minutes per master cylinder on all my bikes.
Size is: SB8125 M8 x 1.25 (and you need 3 of them, 2 on the front caliper and one on the rear caliper)- use an 8mm box wrench to open and close them for bleeding purposes.
You’re in Maui, so I assume shipping costs of parts will be higher if you buy from online vendors. |
| Subject: Re: Oil change, Air filter anything else? Fri Apr 07, 2023 10:20 am | |
| - FLAMAUI wrote:
- Ok, I really appreciate all the great help from this forum. Just changed the oil and filter today. Big accomplishment. The old oil was black. Anyway, I just wondering where are you folks buying the parts? My next wil be the drive belt and maybe the clutch. Any suggestions on places to buy? Thank you again.
Besides your local Honda dealer the three most popular suppliers of OEM parts are; Babbits, Partzilla, and Ron Ayers. They all offer free shipping to the lower 48 states. And at ~$132, Ron Ayers has the best price on the OEM drive belt. So you might check with them for shipping cost to HI. https://www.ronayers.com/oemparts/a/hon/5053f2fcf870021c54be6d53/driven-face |
| Subject: Re: Oil change, Air filter anything else? Fri Apr 07, 2023 1:50 pm | |
| Great. Thank you so much for the info. I'll check it out today. Aloha |
Number of posts : 1382 Location : Allentown PA. Points : 4518 Registration date : 2016-01-02
| Subject: Re: Oil change, Air filter anything else? Sat Apr 08, 2023 5:40 pm | |
| Don't forget about the fork oil it's the most overlooked thing on most bikes. If you can remove the front wheel it's not much more work to drop forks and change the oil. Research it it's not that difficult just takes a little measuring to set oil level after flushing it out. Fork oil gets very nasty after a few years and causes a lot of wear inside tubes. Improves handling and ride quality with fresh oil. |
| Subject: Re: Oil change, Air filter anything else? Sat Apr 08, 2023 6:23 pm | |
| Ok, I'll check. Just ordered my drive belt. Done with the oil change |
| Subject: Re: Oil change, Air filter anything else? | |
