thornev Scooter Rider
Number of posts : 15 Location : Hudson Valley NY Points : 2893 Registration date : 2016-06-13
| Subject: [SOLVED] Givi V46 light kit won't go on Tue Jun 14, 2016 8:41 pm | |
| On my 2004 FSC600D the Givi 46V Monokey Top case has the light kit that is supposed to light the 4 round LED lights. It seems to be wired correctly, but the lights don't go on as running lights nor brake lights. I can't find a wiring diagram for the scooter. Does anyone know to what tail light/brake light wires on the scooter the blue and black light kit wires should be wired to? (yikes, ended a sentence with a preposition!) Thanks.
Number of posts : 3790 Age : 74 Location : Seaham, Co Durham, UK Points : 9449 Registration date : 2009-06-29
| Subject: Re: [SOLVED] Givi V46 light kit won't go on Wed Jun 15, 2016 5:11 am | |
| Green (Ground) Light Blue (Rt Signal) Orange (Lt Signal) Black/Brown (running lights) Green/Yellow (brake lights) |
| Subject: Re: [SOLVED] Givi V46 light kit won't go on Wed Jun 15, 2016 5:22 am | |
| Subject: Re: [SOLVED] Givi V46 light kit won't go on Wed Jun 15, 2016 5:28 am | |
| Pleasure! Good luck. |
| Subject: Re: [SOLVED] Givi V46 light kit won't go on Wed Jun 15, 2016 9:38 am | |
| A little troubleshooting and I found the problem. The bottom spring-loaded connector by the trunk latch was not firmly making contact with the corresponding metal poles on the top of the trunk. What I did to fix was to put a tie around the connector to make it sit higher and put a piece of adhesive between the connector and the trunk piece that holds the connector in place so the connector wont wiggle. Let there be (brake) light ! |
| Subject: Re: [SOLVED] Givi V46 light kit won't go on Wed Jun 15, 2016 10:29 am | |
| Excellent! |
| Subject: Re: [SOLVED] Givi V46 light kit won't go on Thu Jun 16, 2016 1:43 pm | |
| deleted - already answered above. |
| Subject: Re: [SOLVED] Givi V46 light kit won't go on | |
