» OE Quality Drive Belt
removable swingarm won't come off I_icon_minitimeby JohnyC Today at 5:05 am
» LF extended back rest
removable swingarm won't come off I_icon_minitimeby Rzor93 Yesterday at 2:21 pm
» New to Me Swing
removable swingarm won't come off I_icon_minitimeby Tbear Yesterday at 10:56 am
» I said Farewell...
removable swingarm won't come off I_icon_minitimeby Swingbatter Wed Apr 24, 2024 11:52 am
» FOR SALE - 2009 Silver Wing
removable swingarm won't come off I_icon_minitimeby bkr62rsk Wed Apr 24, 2024 9:28 am
removable swingarm won't come off I_icon_minitimeby zrx212 Wed Apr 24, 2024 7:28 am
removable swingarm won't come off I_icon_minitimeby Meldrew Wed Apr 24, 2024 5:37 am
» Rear shock longevity
removable swingarm won't come off I_icon_minitimeby LarryD Tue Apr 23, 2024 5:11 pm
» YSS rear shocks for sale
removable swingarm won't come off I_icon_minitimeby Tbear Tue Apr 23, 2024 12:01 pm
removable swingarm won't come off I_icon_minitimeby welshman in canada Sun Apr 21, 2024 1:37 pm
Silverbobber
Number of posts : 4
Registration date : 2015-08-08
removable swingarm won't come off Empty
PostSubject: removable swingarm won't come off   removable swingarm won't come off I_icon_minitimeSat Aug 08, 2015 6:26 pm
I'm trying to replace rear tire . I have removed rear brake,parking brake ,brake lines , axle bolt (required 260 lbs force to brake it loose), disconnected shock and all bolts holding removable swingarm in place . swingarm rotates on axle but won't pull off . What needs to happen to get it off the axle ?
0
PostSubject: Re: removable swingarm won't come off   removable swingarm won't come off I_icon_minitimeSat Aug 08, 2015 7:51 pm
Silverbobber I've used a two jawed gear puller with good results on a tuff to remove one before. Silverbobber would you please click here on this blue link and introduced yourself.  Then you'd get a proper welcome from the forum members.
NWSSC
NWSSC
Number of posts : 418
PostSubject: Subject: removable swingarm won't come off    removable swingarm won't come off I_icon_minitimeSun Aug 09, 2015 1:59 pm
I hope you removed the muffler. The reason you can rotate the swing arm is because you are just turning the bearing in the swing arm. As previously mentioned.I'm sure you will get more help after a introduction. Howard
Silverbobber
Number of posts : 4
PostSubject: Thanks    removable swingarm won't come off I_icon_minitimeTue Aug 11, 2015 12:26 am
I bought a 6" wide two jaw puller at Harbor Freight . The purchases on the swing arm were a bit out of line . A judicious application of penetrating oil calmed my worries of breaking the casting . I cranked the puller down while using a rubber mallet to wack it laterally keeping it "relatively" in line to break it free . A loud crack told me some thing gave way . Relieved was I to see the swing arm had popped off the axle . I was fearful of breaking the casting . I'm going to use grease when it goes back together .  Thanks for your helpful suggestions !
tinman
Number of posts : 1298
PostSubject: Re: removable swingarm won't come off   removable swingarm won't come off I_icon_minitimeTue Aug 11, 2015 7:34 am
Try Never seize ,the same used on the bolt threads to stop it from rusting,and seizing.the sticking won't be a problem anymore. This problem usually happens to those that don't ride a lot and changes the tire every 5 yrs or more.
Silverbobber
Number of posts : 4
PostSubject: Thanks    removable swingarm won't come off I_icon_minitimeTue Aug 11, 2015 10:53 am
Thanks for the tip I'll give it a go .
cliffyk
cliffyk
Number of posts : 182
PostSubject: Re: removable swingarm won't come off   removable swingarm won't come off I_icon_minitimeFri Jun 17, 2016 12:13 am
Old thread I know but thought I'd report that on my "new-to-me" low mileage 2006 S'Wing I found the inner race of the axle bearing in the removable swingarm also not wanting to release from the axle shaft.
No jaw type puller I had would grab a decent purchase on the arm so I drilled an tapped two 3/8-24 holes (unsure of how hard I would be pulling I wanted a fine thread did not a fine thread metric tap) to allow use of a harmonic balancer puller--used polished stainless button-head cap screws to plug 'em up when done:
removable swingarm won't come off TappedRightArm-01
puller:
removable swingarm won't come off Harmonic_balancer_puller
» Swingarm torque question
» Clutch removal of 22mm bolt
» Removing rear wheel - swingarm.
» RH SWINGARM FRONT PIVOT BEARING
» Swingarm Torx Bolt Sixe
