| | Givi TB19 & SR19 Install | |
chazman Scooter Rider
Number of posts : 9 Age : 64 Location : Minnesota Points : 2930 Registration date : 2016-05-07
| Subject: Givi TB19 & SR19 Install Mon Jun 06, 2016 6:02 pm | |
| Hi, I don't have the backrest yet, but I have a '13 Swing and am prepping to install both a Givi TB19 backrest and an SR19 Monokey top case mounting bracket. Since I know Givi only sends cryptic pictogram instructions, I'm thinking there will be some confusion as to how these both go on the bike. I have confirmed that they are compatible, I'm just wondering if one of you kind experts will share some of your wisdom so I don't have to rip everything apart after realizing I put it all together upside down and backwards. Thanks in advance.
P.S. Also, I'm wondering if anyone has any wisdom to offer in routing the brake light kit wiring from the Givi top case to the brake light wiring on the bike.
Last edited by chazman on Mon Jun 06, 2016 6:04 pm; edited 2 times in total (Reason for editing : spelling error) |
| Subject: Re: Givi TB19 & SR19 Install Mon Jun 06, 2016 10:38 pm | |
| I do have a couple of tail/brake/running light connector plug n' play harness adapters available. Fits the 6P wire harness plug at the left rear. Similar to DennisB's Perfect Connector. Same OEM Hitachi wire harness plugs, same wiring color codes, and the same 20 ga wiring as Honda's. PM me if interested
Do an Archive search for Perfect Connector for a photo.
Last edited by Cosmic_Jumper on Tue Jun 07, 2016 7:01 pm; edited 1 time in total |
| | | MikeO Site Admin
Number of posts : 3790 Age : 74 Location : Seaham, Co Durham, UK Points : 9449 Registration date : 2009-06-29
| Subject: Re: Givi TB19 & SR19 Install Tue Jun 07, 2016 4:16 am | |
| My advice is to sit and look at the diagrams well before you use them (the day before, perhaps). You'll mull them over in your mind and they'll become clearer.
When fitting the metal bits, put the two mounts for the rack flush on the spoiler with the back rest on top. Put the four bolts up from underneath so the nuts tighten up on the metal bits you are fitting.
As I said elsewhere, it is relatively easy to get a flat spanner on the nuts which are now on top while it is impossible to get an Allen key on the bolt heads if they are on top when the plastic rack is in place. You need to wait before tightening then as all eight bolts may need wriggling to get them all lined up. So, don't tighten any of the bolts until they are all in place with the nuts, spacers and washers in place.
It isn't a very good explanation but if you drop in the bolts through the seat back and rack mountings first so the nuts are under the spoiler, you'll see what I mean! |
| | | MikeO Site Admin
| Subject: Re: Givi TB19 & SR19 Install Tue Jun 07, 2016 4:34 am | |
| | | tinman Silver Wing Guru
| Subject: Re: Givi TB19 & SR19 Install Tue Jun 07, 2016 6:41 am | |
| To wire the givi stop light , under the seat open the access panel the colour coded wires are easily access there using a service manual to identify the 2 wires |
| Subject: Re: Givi TB19 & SR19 Install Tue Jun 07, 2016 7:19 am | |
| Mike, Thanks for the great info... ride on. - MikeO wrote:
- My advice is to sit and look at the diagrams well before you use them (the day before, perhaps). You'll mull them over in your mind and they'll become clearer.
| | | bicyclenut Maxi-Scooter Rider
Number of posts : 141 Age : 55 Location : Chicago Suburbs Points : 3356 Registration date : 2015-09-04
| Subject: Re: Givi TB19 & SR19 Install Tue Jun 07, 2016 8:32 am | |
| Tim's (Cosmic_Jumper) light connector, plug-n-play, makes wiring in any additional brake lights, turn signals a piece of cake without cutting into the OEM Honda wiring. The time it saves and how easy it makes this, is well worth the price. |
| | | Sponsored content
| Subject: Re: Givi TB19 & SR19 Install | |
