| Battery Charging | |
Tommo Scooter Rider
Number of posts : 94 Age : 78 Location : Kidderminster UK Points : 3250 Registration date : 2015-10-01
| Subject: Battery Charging Tue Oct 13, 2015 2:17 pm | |
| On my old Yamaha XJ600S I had fitted a 12v auxiliary socket direct from the Battery through a fuse, for Mobile Phone charging etc, It also was useful for plugging my trickle charger into to keep Battery topped up.
My question is, can I do the same with the standard 12v socket fitted to the SW? I am no electrician and want to be sure before I plug charger in. Tommo. |
| Subject: Re: Battery Charging Tue Oct 13, 2015 2:27 pm | |
| I've been using my Optimate 4 plugged into the 12v socket in the left glovebox since I bought my Silver Wing in November 2010. |
Tommo Scooter Rider
| Subject: Re: Battery Charging Tue Oct 13, 2015 2:32 pm | |
| - Meldrew wrote:
- I've been using my Optimate 4 plugged into the 12v socket in the left glovebox since I bought my Silver Wing in November 2010.
Thanks for that, wanted to be sure I wasn't going to burn anything out. As I mentioned in my post Electrics are not my strong suit. Cheers. |
NWSSC Silver Wing Rider
Number of posts : 418 Age : 86 Location : Mt Prospect IL 30 miles west of Chicago Points : 5639 Registration date : 2010-03-03
| Subject: Battery Charging Tue Oct 13, 2015 7:39 pm | |
| As previously stated you can use this outlet with a trickle charger. It would not be wise to use a larger capacity charger here though. Howard |
Cookie Super Scooter Rider
Number of posts : 233 Location : Essex UK Points : 4836 Registration date : 2011-10-03
| Subject: Re: Battery Charging Wed Oct 14, 2015 3:30 am | |
| Howard's right. I believe the socket is protected by a 2 amp fuse so be careful not to use a charger that goes above this. Like Meldrew, that's where I plug in my Optimate. |
Tommo Scooter Rider
| Subject: Re: Battery Charging Wed Oct 14, 2015 5:25 am | |
| Subject: Re: Battery Charging Thu Oct 15, 2015 11:28 pm | |
| Just remember that the fuse in a circuit is normally sized to protect the wiring not whatever might be plugged into it. It's perfectly safe to go to a lower current fuse if desired but not to a higher current one. One can safely go to a 5A fuse if needed on the 12V socket with no risk. |
Gustafa Super Scooter Rider
Number of posts : 218 Location : Cordova, TN Points : 3390 Registration date : 2015-10-10
| Subject: Re: Battery Charging Fri Oct 16, 2015 10:02 am | |
| Following this thread with interest. |
Tommo Scooter Rider
| Subject: Re: Battery Charging Sat Oct 17, 2015 10:04 am | |
| I have put a 12v auxiliary socked direct to the battery through an in line fuse, which sits in the luggage compartment under seat, nice and handy for plugging my trickle charger in. I know that it was said that it was Ok to charge though the factory fitted one in the glove box but, just feel happier with one direct to battery. Should I carry a fire extinguisher? |
| Subject: Re: Battery Charging Sun Oct 18, 2015 11:09 am | |
| - Tommo wrote:
- I have put a 12v auxiliary socked direct to the battery through an in line fuse, which sits in the luggage compartment under seat, nice and handy for plugging my trickle charger in.
I know that it was said that it was Ok to charge though the factory fitted one in the glove box but, just feel happier with one direct to battery. Should I carry a fire extinguisher? I did much the same thing except I installed the battery tender adaptor direct to battery. Then purchased a maintainer to 12 volt power outlet adapter at Cyclegear. That way I can plug in maintainer w/o using battery clips and when on road can plug in outlet and charge cell phone, GPS or camera. All safely under the seat, out of sight. Did same thing on Goldwing (sorry Meldrew for mentioning a non Silver Wing) and use same adapter for both. Here is what I mean by the adapter: http://www.amazon.com/Battery-Tender-081-0069-8-Cigarette-Disconnect/dp/B0041CDPQO |
woodturnertimmers Scooter Rider
Number of posts : 11 Age : 65 Location : Monett, Missouri Points : 3128 Registration date : 2015-10-16
| Subject: Re: Battery Charging Sun Oct 18, 2015 9:03 pm | |
| I'm Getting some good ideas here. |
| Subject: Re: Battery Charging | |
