| Author | Message |
tvpRich Scooter Rider
Number of posts: 19 Location: Burbank, CA Points: 938 Registration date: 2009-08-12
 | Subject: Upper Air Vents ? Wed Aug 19, 2009 10:10 pm | |
| The one's just left of tach & right of gas guage... What are they for? Can I replace them with Speakers for a radio? |
mickey Super Scooter Rider
Number of posts: 225 Points: 1273 Registration date: 2009-05-06
 | Subject: Re: Upper Air Vents ? Wed Aug 19, 2009 10:46 pm | |
| I don't think they do anything, actually. Does air even come through them? |
Excell Maxi-Scooter Rider
Number of posts: 143 Age: 64 Location: Winnipeg Manitoba Points: 1171 Registration date: 2009-05-06
 | Subject: Re: Upper Air Vents ? Thu Aug 20, 2009 6:26 am | |
| I think I am going to take my radio out .You can't hear it on the Hwy ,and I never turn it on in town .Its just wasting space. If you want to put speakers there you can just make sure their is enough room behind for them .I don't know if any one has tried that .I know they have been mounted in both glove box lids ,which is a terrible waste . I have mine mounted on the handle bars . |
honda_silver Site Admin
Number of posts: 2111 Age: 51 Location: Georgetown, Tx Points: 3351 Registration date: 2008-12-23
 | Subject: Re: Upper Air Vents ? Thu Aug 20, 2009 8:08 am | |
| | tvpRich wrote: | The one's just left of tach & right of gas guage... What are they for? |
I was curious so I wanted to check the vents during the winter months, which made detecting heat easier. As I recall ... after a long ride (I forget if the fan was on), I was stopped and put my hand up to vent and felt some warmth. So I believe the vents play some indirect part in cooling.
If you wanted more concrete proof, you may have to use a sensitive thermostat and measure.
| tvpRich wrote: | | Can I replace them with Speakers for a radio? |
I would be concerned about negatively effecting the operating temperature of the SWing._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
 | Subject: Re: Upper Air Vents ? Thu Aug 20, 2009 2:05 pm | |
| Hi, With your info, one could deduce that maybe HEAT generated from the fan below might build up in the area just behind the Vents. For that matter, maybe they're there to purposely give a little heat onto the windshield for defrosting? What Da Ya Think of That? |
exavid Silver Wing Rider
Number of posts: 411 Age: 69 Location: Medford, Oregon Points: 1373 Registration date: 2009-07-17
 | Subject: Re: Upper Air Vents ? Thu Aug 20, 2009 6:00 pm | |
| Those little vents all get their air from in front and above the radiator. The air passed through the radiator exits underneath the scooter. If you look under there you can see the air exhaust louvers. The small vents would help dissipate some heat generated under the fairing when the bike's parked in the hot sun but they really don't serve much purpose. My Goldwing 1500 has similar vents in an analogous location but they aren't very effective either. |
 | Subject: Re: Upper Air Vents ? Thu Aug 20, 2009 6:01 pm | |
| | tvpRich wrote: | Hi, With your info, one could deduce that maybe HEAT generated from the fan below might build up in the area just behind the Vents. For that matter, maybe they're there to purposely give a little heat onto the windshield for defrosting? What Da Ya Think of That? |
Possibly, but I don't think enough air comes through them, cool or warm, to make any difference to the bike. I don't even remember seeing hoses hooked up to them. They're just open to the inside of the cowling. I think they're more decorative than anything.
Most of the engine's cooling air supply exits under the bike through the little NACA duct looking things beneath the fuel tank area. The design of those ducts creates a vacuum at speed, thus "sucking" air through the radiator and eliminating the need for the cooling fan to operate at highway speeds. |
 | Subject: Re: Upper Air Vents ? Thu Aug 20, 2009 6:03 pm | |
| I don't know if you'd actually HEAR speakers in those locations, but they would make great places for auxiliary light switches, etc. I'm glad I thought of that! Hmmmmm....... |
 | Subject: Re: Upper Air Vents ? Thu Aug 20, 2009 6:55 pm | |
| Just to be sure, I'm gonna duct tape them closed an see if anything BLOWS UP! |
 | Subject: Re: Upper Air Vents ? Thu Aug 20, 2009 7:34 pm | |
| I have front and rear speakers on my Goldwing fed by it's onboard audio amp which I think is around 50W. The speakers are 4". I don't think you could much behind those vents there's no real space behind them. You could of course mount a pair of speakers in front of them but I think the best bet would be a set of handlebar mounted speakers. They aren't cheap though you can find speakers for motorcycles under $100.
http://www.motorcyclespeakers.net/shop/stereo-speakers-amplifiers-26-ctg.htm |
 | Subject: Re: Upper Air Vents ? Thu Aug 20, 2009 10:34 pm | |
| In the interest of science I went zipping down the freeway tonight and checked what comes out of the vents. Answer: Air. A modest amount of cool air.
The vents aren't involved in engine cooling in any meaningful way, nor are the connected directly to any vents in the bodywork. I don't think you'd miss them. |
Number of posts: 1585 Age: 62 Location: Western Europe Points: 2617 Registration date: 2009-06-29
 | Subject: Re: Upper Air Vents ? Fri Aug 21, 2009 3:17 am | |
| Do they not contribute to the overall venting of the space under the fairing? _________________ Mike - Riding on the right - riding for pleasure!
Miro Maxi-Scooter Rider
Number of posts: 101 Age: 43 Location: Milwaukee, WI Points: 1084 Registration date: 2009-06-08
 | Subject: Re: Upper Air Vents ? Fri Aug 21, 2009 8:00 am | |
| | Excell wrote: | | I think I am going to take my radio out .You can't hear it on the Hwy ,and I never turn it on in town .Its just wasting space. If you want to put speakers there you can just make sure their is enough room behind for them .I don't know if any one has tried that .I know they have been mounted in both glove box lids ,which is a terrible waste . I have mine mounted on the handle bars . |
Shark radio (250W) recommended on this and other forums has an option for speakers to be mounted on mirrors mounts so they are just above brake fluid reservuars (sp?). |
 | Subject: Re: Upper Air Vents ? Sun Aug 23, 2009 4:12 am | |
jdeereanton Site Admin
Number of posts: 1688 Age: 54 Location: Huntsville, AL Points: 2865 Registration date: 2008-12-24
 | Subject: Re: Upper Air Vents ? Sun Aug 23, 2009 2:54 pm | |
| Those two outboard dash vents simply evacuate air from under the front piece. The air comes into the area from the openings just outboard of the headlight assembly. The air movement is not pressurized. It has nothing to do with air across the radiator. The volume of air coming in the front of the bike and exiting out of the outboard dash vents is not likely to be 1:1 as some air is probably going to be deflected down and it is not a direct path. _________________ Dale Huntsville, AL
2 x 2005 - Hers & His Boots, socks, underwear, pants, t-shirt, jacket, gloves, & helmet.
http://www.youtube.com/user/jdeereanton
Riding on "Just Basic Shocks" - My shocks, while completely functional, have never even been nominated for an award.
KurtPerthWA Silver Wing Expert
Number of posts: 848 Age: 62 Location: Belmont, Perth WA Points: 2537 Registration date: 2009-01-19
 | Subject: Re: Upper Air Vents ? Mon Aug 24, 2009 3:08 am | |
| Thanks Dale, now I can install that aircon/heater system off the Range Rover. I've been thinking about mounting another Swing motor to drive it. Just kidding!!!!!  |
