| Silverwing Shudder | |
+6KurtPerthWA john grinsel model28a "Hi Yo" RArch canhead 10 posters |
canhead Scooter Rider
Number of posts : 16 Age : 82 Location : Spokane Valley, WA Points : 4352 Registration date : 2012-06-26
| Subject: Silverwing Shudder Thu Jul 18, 2013 1:41 pm | |
| Am getting a slight shudder when starting out. Is this possibly a belt issue. Have almost 19,000 miles and checked the belt at 14,000 with no visible problem. |
RArch Silver Wing Expert
Number of posts : 613 Age : 57 Location : West London, UK Points : 5204 Registration date : 2011-11-07
| Subject: Re: Silverwing Shudder Thu Jul 18, 2013 2:32 pm | |
| Strip it down, clean the dust out (in particular the clutch) and threat it to a new belt.
Check the rollers too they may not be sliding easily, more dust... |
| Subject: Re: Silverwing Shudder Thu Jul 18, 2013 6:26 pm | |
| Canhead,in your introduction you said your Swing was a 2003. If this is the same bike and the belt has never been replaced, it is probably overdue. It's your choice, but being wrong could be very costly. |
| Subject: Re: Silverwing Shudder Thu Jul 18, 2013 8:01 pm | |
| canhead, how did you stop the shudder last year? Did you ever get it to run smove then? I would do like RArch said as old as the scooter is I sure would not have much faith in rubber that old if you have never changed it. |
| Subject: Re: Silverwing Shudder Fri Jul 19, 2013 6:35 am | |
| simple temp. fix.= run engine up against brake for 5-10 seconds---repeat if still shudders. Bike is old/belt is old/belt beyond service limit-miles.
Replace belt with OEM, probably rollers, too. The shudder is just way rubber band drive scooters are----I have had 4 Helix, Reflex/SilverWing/2 Burgman 400. |
KurtPerthWA Silver Wing Guru
Number of posts : 1709 Age : 75 Location : Belmont, Perth WA Points : 7946 Registration date : 2009-01-19
| Subject: Re: Silverwing Shudder Fri Jul 19, 2013 10:07 am | |
| My Swing shudders every time I pick up the key! |
LN Scooter Rider
Number of posts : 64 Location : Austin TX Points : 4347 Registration date : 2012-08-18
| Subject: Re: Silverwing Shudder Sat Jul 20, 2013 11:17 pm | |
| Here what happened to me. Every time I took off, my bike was making a shaking weird noise. So I took it to the mechanic. Next thing I know they call to tell me that they changed the belt ( one week old belt) and it should be ok now. NOPE !
Took a while but I found out by myself what the problem was. Make that the PARKING BRAKE ....sticking !!!!! I just took the pads off and ....tadaaa ! no more noises, no more vibrating. Good luck ! |
Colin B Silver Wing Expert
Number of posts : 586 Age : 72 Location : Windsor, UK Points : 4702 Registration date : 2013-03-20
| Subject: Re: Silverwing Shudder Sun Jul 21, 2013 12:49 am | |
| - LN wrote:
- I just took the pads off and ....tadaaa ! no more noises, no more vibrating.
And no more parking brake!! |
LN Scooter Rider
| Subject: Re: Silverwing Shudder Sun Jul 21, 2013 4:37 pm | |
| Real man don't need no parking brake I was so pissed with the whole dealer / shmiler, I never put them back on the bike. I managed quite well. I haven't had any problem with the second bike. I am waiting for the first belt to pop at any moment. I am over 27,000 miles on the first belt. On my previous bike it broke at 23,000. |
Number of posts : 1099 Age : 70 Location : Cleveleys, Lancashire, England Points : 6324 Registration date : 2010-03-27
| Subject: Re: Silverwing Shudder Sun Jul 21, 2013 4:41 pm | |
| - LN wrote:
- Real man don't need no parking brake
I haven't had any problem with the second bike. I am waiting for the first belt to pop at any moment. I am over 27,000 miles on the first belt. On my previous bike it broke at 23,000. I assume you never park your scooter on a downhill gradient, manual geared bikes can be left in gear, scooters can't. Cheers, |
LN Scooter Rider
| Subject: Re: Silverwing Shudder Sun Jul 21, 2013 4:52 pm | |
| I got so used to not using the parking brake with my old Silverwing that I still turn the bike so the rear tire rests on the curb / face up hill or just put it on the stand. I drive my bike for a living. I do a lot of stops. I use at 1-3 tanks of gas per day...every day.
L |
| Subject: Re: Silverwing Shudder Sat Jul 27, 2013 6:36 pm | |
| That is some mileage you are doing. Are you thinking of doing an Iron Butt run for a bit of recreation? Cheers, |
Number of posts : 350 Location : Elkton , Maryland Points : 4891 Registration date : 2011-12-11
| Subject: Re: Silverwing Shudder Sat Jul 27, 2013 7:12 pm | |
| I never use the parking brake myself but you are really tempting fate running the belts so far beyond Honda's mileage recommended change interval. |
| Subject: Re: Silverwing Shudder | |
