» New to Me Swing
Spark Plugs I_icon_minitimeby Erdoc48 Today at 4:55 pm
» I said Farewell...
Spark Plugs I_icon_minitimeby Swingbatter Today at 3:12 pm
» OE Quality Drive Belt
Spark Plugs I_icon_minitimeby JohnyC Today at 5:05 am
» LF extended back rest
Spark Plugs I_icon_minitimeby Rzor93 Yesterday at 2:21 pm
» FOR SALE - 2009 Silver Wing
Spark Plugs I_icon_minitimeby bkr62rsk Wed Apr 24, 2024 9:28 am
Spark Plugs I_icon_minitimeby zrx212 Wed Apr 24, 2024 7:28 am
Spark Plugs I_icon_minitimeby Meldrew Wed Apr 24, 2024 5:37 am
» Rear shock longevity
Spark Plugs I_icon_minitimeby LarryD Tue Apr 23, 2024 5:11 pm
» YSS rear shocks for sale
Spark Plugs I_icon_minitimeby Tbear Tue Apr 23, 2024 12:01 pm
Spark Plugs I_icon_minitimeby welshman in canada Sun Apr 21, 2024 1:37 pm
 Spark Plugs
tarmacburner2
rodenbach
tracab
mick
tinman
11 posters
tinman
Number of posts : 1298
Spark Plugs Empty
PostSubject: Spark Plugs   Spark Plugs I_icon_minitimeThu Feb 14, 2013 2:01 pm
There was a sale on Iridium plugs at a supplier They tried to cross reference with the Swing standard Bosh plug and did not have a match.Can anyone help me on the right plugs to get. Thanks.
mick
mick
Number of posts : 80
Registration date : 2011-11-11
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeThu Feb 14, 2013 2:12 pm
think its these?
CR8EHIX-9
tracab
tracab
Number of posts : 54
Registration date : 2012-08-29
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeThu Feb 14, 2013 2:46 pm
CR8EHIX-9 are the correct ones. I dropped them in last year and picked them up from Advanced Auto Parts for $11.95 for the pair. Best of Luck.
tinman
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeThu Feb 14, 2013 3:07 pm
Thanks for the information. I assume that they are a Bosh plug?
tracab
tracab
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeThu Feb 14, 2013 4:04 pm
Tinman,
No, Sorry about that i should have mentioned that. They are NGK.
tinman
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeThu Feb 14, 2013 5:07 pm
Got it thanks.
Number of posts : 3295
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeThu Feb 14, 2013 10:25 pm
US Models come with NGK or maybe nissan denso. Look in riders manual for recommend plug and heat range.
I find the cheapest plain NGK plugs work just fine----near as I can figure the expensive plugs can make no difference in performance. I get at least 30,000 miles from the cheap plugs.
Important is use a little never seize on the threads---bike shops often run them in dry.
Online
rodenbach
rodenbach
Number of posts : 321
Registration date : 2012-08-30
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeFri Feb 15, 2013 10:13 am
... I find the cheapest plain NGK plugs work just fine----near as I can figure the expensive plugs can make no difference in performance....
I can only agree: just stick to the recommended plugs
tinman
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeFri Feb 15, 2013 10:40 am
I guest your both right At 31k kl the plugs look real good so far.I will buy the recommended Honda plugs and will change them at my next oil change and belt and rollers ,filter inspection. Time to replace everything soon to be on the safe side.
Number of posts : 921
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeFri Feb 15, 2013 12:06 pm
I always changed plugs at 8,000ml interval, until someone on this site suggested Iridium plugs should last 50,000mls. At 8000mls i put Iridium plugs in (they were the same price as standard plugs). At 16,000mls i took the plugs out to clean and check and they didn't need cleaning and the gap was spot on. At 24,000mls i again took them out to check them, and again they needed no attention. In my opinion they are well worth putting in, depending on the price you can get them for. Smile They are NGK's
tarmacburner2
tarmacburner2
Number of posts : 1099
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeFri Feb 15, 2013 12:51 pm
Plugs may keep firing but lose their effectiveness, so not all fuel is burnt in combustion. Get iridium plugs.
Just checked prices, NGK Standard plug £11.94, Iridium plug =£13.93. So it is a no brainer.
Cheers,
Last edited by tarmacburner2 on Fri Feb 15, 2013 12:57 pm; edited 2 times in total (Reason for editing : Prices added.)
rollsroyce250
Number of posts : 73
Registration date : 2012-06-21
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeFri Feb 15, 2013 5:38 pm
I thought a spark was a spark.
RArch
RArch
Number of posts : 613
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeFri Feb 15, 2013 6:20 pm
No, its an Electrician...
clown
http://www.rcmodeltalk.co.uk
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeFri Feb 15, 2013 6:47 pm
US and UK prices are really different.
Dennis Kirk---trusted supplier of bike stuff:
NGK plug, reg or Resistor @$2.60 they show iridium plugs from $10-18.
I am sure bike shops charge more.
I also had good luck getting NGK plugs at reg auto parts stores in WI and prices were fair. I started using NGK plugs in '62 when I first went to Japan. Their heat range numbers are easy to understand.
Online
jose.illegal
Number of posts : 11
Registration date : 2012-07-03
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeFri Feb 15, 2013 8:46 pm
Kind of out there but I have Iridium plugs in my Toyota Tundra with 146'000 miles on them and it runs just as well as it did new, and still gets 20 miles per gallon.
tarmacburner2
tarmacburner2
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeSat Feb 16, 2013 5:46 am
That is the reason they need changing at regular intervals. Smile Iridium plugs are much more resilient.
Cheers,
tinman
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeSat Feb 16, 2013 6:33 am
My 03 Tracker has 128 k kl, the plugs has never been changed .My owner's manual say change at 160 k kl. Hell I cant even see the spark plugs.I hope they don't strip the threads out when it's time to change.
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeSat Feb 16, 2013 8:37 am
I would say put cheapest NGK plugs in---in the right heat range---most scooter riders think they have had a "big" year when they ride 5-10,000 miles.
It appears to be coldest day of the year in the south----30 mins leave for Key West on scooter===Complete Aerostich jacket (Darien) and pants on, long underwear----this would be warm spring day in N WI---Darien and my water-proof Volverine 11" boots means no stopping to change clothes when I run into the expected rain.
Online
tinman
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeSat Feb 16, 2013 9:30 am
I put 25k kl In the 6 month Max that I can ride. 1.5 months in 5 -8 C whether . This year the way the wether,I might be less . If I win the Lottery,Im moving South to warmer temp. motorcycle
Spark Plugs Empty
PostSubject: Re: Spark Plugs   Spark Plugs I_icon_minitimeSat Feb 16, 2013 2:18 pm
Modern ignition systems are amazing. When I sold our old Mercury Marquis four years ago it had 180,000 miles on it and still had the original spark plugs. I'm cheap enough to wait until something shows up, like hard starting, a miss under load, uneven idling or a drop in mileage before I change plugs nowadays. In years past we'd pull the plugs, sand blast them, file the electrodes back to shape, and re-gap them. British Lodge plugs in my MGA were even designed to be disassembled to clean and service them. But those requirements are long gone along with breaker point ignition. My '93 Goldwing had 175,000 miles on it when I sold it and was on it's second set of plugs. I had no real reason to change them but felt mildly guilty when I did it's 100,000 mile service so I put in another set of plain old NGKs. Removal of lead from gasoline also went a long way to increased plug life.
Spark Plugs Empty
Spark Plugs
» Installed New Iridum Spark Plugs
» spark plug replacement
» Silverwing spark plug upgrade?
» Gimmick Spark plugs
» Spark plugs burn out
