Jack Pearson Scooter Rider
Number of posts : 2 Location : Bodfish,CA. 93205 Points : 4216 Registration date : 2012-10-16
| Subject: Intermittent starting Tue Oct 16, 2012 5:10 pm | |
| In the past few months my Honda would refuse to start , but not at every attempt. I would think it needed a charge and found out that did not help.
At times, just leaving it sit and attempting to start it, would be successful. It seems like the side stand has a lot to do with it.
I put a new battery in it and that did not solve a thing. Like I said, sometimes it will start and most times it will not. When I say it will not start, I mean that I do not even get a clicking noise at all,...nothing, no sound.
I hesitate using it when it does start and later miles from home I have the same problem. Any ideas?
Kasotakid |
| Subject: Re: Intermittent starting Tue Oct 16, 2012 5:25 pm | |
rollsroyce250 Scooter Rider
Number of posts : 73 Location : Florida Points : 4402 Registration date : 2012-06-21
| Subject: Re: Intermittent starting Tue Oct 16, 2012 10:28 pm | |
| - Jack Pearson wrote:
- It seems like the side stand has a lot to do with it.
Any ideas? Either you're trolling or you just solved your own problem. |
Number of posts : 199 Age : 62 Location : Athens Greece Points : 4633 Registration date : 2012-04-05
| Subject: Re: Intermittent starting Wed Oct 17, 2012 9:28 am | |
| Either your kill switch needs some contact cleaner or your push button.....oh and don't forget your introduction |
jdeereanton Silver Wing Guru
Number of posts : 1995 Age : 76 Location : Huntsville, AL Points : 7672 Registration date : 2008-12-24
| Subject: Re: Intermittent starting Wed Oct 17, 2012 10:31 am | |
- In the past few months my Honda would refuse to start , but not at every attempt. I would think it needed a charge and found out that did not help.
Kasotakid Jack Pearson, Welcome to the forum, but you really should introduce yourself - just good form. You do know that your bike will not start when the side stand is down don't you? There is a lockout switch that prevents the bike from starting when the side stand is down. Kill switch is a commonly overlooked problem. Can inadvertently be set to the no-run position and not noticed. The start button may need to be cleaned. Don't know the age of your bike so not cetain about this. The owner's manual has a short section in the back on trouble shooting... |
| Subject: Re: Intermittent starting | |
