I've just replaced the rear pads on my 2008 ABS silverwing. The original pads had the metal backing that clips to the back of the pad and the fibre shim fitted. When I load all these up my EBC SFA 196 pads it makes the pads to thick to fit, even with the caliper pistons pushed fully back.
To get the pads in, I've had to omit the fibre shim on both sides, now I'm wondering if EBC ever intended the the metal backing and fibre shim to be fitted.
Anyone else had this issue?
