| All electrics gone on 2007 FJS600 A7 Silver Wing | |
JockTheScot Scooter Rider
Number of posts : 16 Age : 59 Location : New Forest. UK Points : 3018 Registration date : 2016-02-24
| Subject: All electrics gone on 2007 FJS600 A7 Silver Wing Tue Mar 01, 2022 3:14 pm | |
| A week ago I got on my bike and the bike started but I had no lights, horn, indicators or digital dashboard info. I'm mechanically dyslexic, I have not got a clue. I bought a box of fuses and a screwdriver that you have to earth and when you place it on the metal part at the top of the fuse a wee light comes on. The only fuse that i wasn't getting a light on the two dots on the top of the fuse is the ABS fuse. The problem still remains, no electrics anywhere on the bike. Can someone please offer any advice? It would be greatly appreciated |
Number of posts : 388 Age : 59 Location : Auckland, New Zealand Points : 1930 Registration date : 2020-03-11
| Subject: Re: All electrics gone on 2007 FJS600 A7 Silver Wing Mon Mar 07, 2022 3:03 pm | |
| Hiya Terry Thanks very much for the reply. I'll have a look at the weekend. Would the bike still start if the additional main fuse had blown? |
| Subject: Re: All electrics gone on 2007 FJS600 A7 Silver Wing Mon Mar 07, 2022 3:48 pm | |
| No it won't start with a blown main fuse.
Maybe the electrical connector on the back of the dashboard has come out? You'll need to pull off the garnish above the headlight to get in there easily. |
Spud76 Scooter Rider
Number of posts : 8 Age : 47 Location : Belfast, Northern Ireland Points : 578 Registration date : 2022-10-17
| Subject: Re: All electrics gone on 2007 FJS600 A7 Silver Wing Tue Jan 24, 2023 4:19 pm | |
| I'm having the same problem on my 2002 SW. The electrics are working intermittently. Maybe a loose connection?. The scooter starts and runs. No dashboard lights headlights etc. |
JohnyC Touring Scooter Rider
Number of posts : 301 Age : 71 Location : Bristol, UK Points : 810 Registration date : 2022-12-23
| Subject: Re: All electrics gone on 2007 FJS600 A7 Silver Wing Tue Jan 24, 2023 4:35 pm | |
| The only thing all those faults have in common is a bad earth, prob the one on the dashboard wiring socket or main headstock earth, as the Swing starts and runs so its not a main fuse or power issue. Hope this helps.
Be safe, be seen! |
| Subject: Re: All electrics gone on 2007 FJS600 A7 Silver Wing Tue Jan 24, 2023 4:40 pm | |
| Thanks for your advice. I'll check it out tomorrow and get back to you. |
| Subject: Re: All electrics gone on 2007 FJS600 A7 Silver Wing Wed Jan 25, 2023 1:08 pm | |
| I just had another thought about your problem, do the lights come on with just the ignition on, and go out after it's started ? if so it will be a bad return contact on your starter button. Sorry only just remembered it was a problem I found.
Be safe, be seen! |
| Subject: Re: All electrics gone on 2007 FJS600 A7 Silver Wing Wed Jan 25, 2023 3:39 pm | |
| The bike starts and runs perfectly. I have no lights, horn ,indicators, dashboard lights etc. Sometimes when riding over a bump everything works again for a while. Think something is loose somewhere. |
| Subject: Re: All electrics gone on 2007 FJS600 A7 Silver Wing Thu Jan 26, 2023 7:50 am | |
| I took off the rear panel to check the fuses, wiring and relays. The main relay wasn't seated correctly and when I pushed it in properly everything worked again. Thanks for your help!! Appreciate your time!! Admin highlighted |
| Subject: Re: All electrics gone on 2007 FJS600 A7 Silver Wing Thu Jan 26, 2023 8:54 am | |
| Oh well done, good work !
Be safe, be seen! |
| Subject: Re: All electrics gone on 2007 FJS600 A7 Silver Wing | |
