» YSS rear shocks for sale
Brake Caliper mounting bolts I_icon_minitimeby StuartBrown Today at 12:11 pm
» checking the oil
Brake Caliper mounting bolts I_icon_minitimeby COMick Yesterday at 9:46 am
» Hobbies? (Besides maxi scooters, of course?)
Brake Caliper mounting bolts I_icon_minitimeby Erdoc48 Yesterday at 6:46 am
» Modifying Honda Silver Wing 600
Brake Caliper mounting bolts I_icon_minitimeby Frenchy Sat May 04, 2024 4:11 pm
» Poor man’s Power Commander: IAT Sensor modification (Intake Air Temp Sensor)
Brake Caliper mounting bolts I_icon_minitimeby gavinfdavies Fri May 03, 2024 3:33 am
» Sinko De Mayo
Brake Caliper mounting bolts I_icon_minitimeby GHM-PM Thu May 02, 2024 7:10 am
» May 2024 forum picture
Brake Caliper mounting bolts I_icon_minitimeby MikeO Thu May 02, 2024 4:42 am
» Strongly considering a one way ride from Texas to Progreso,Mexico and could use some advice
Brake Caliper mounting bolts I_icon_minitimeby GHM-PM Mon Apr 29, 2024 10:08 pm
» LF extended back rest
Brake Caliper mounting bolts I_icon_minitimeby Rzor93 Mon Apr 29, 2024 4:14 pm
» FOR SALE - 2009 Silver Wing
Brake Caliper mounting bolts I_icon_minitimeby GHM-PM Mon Apr 29, 2024 6:47 am
3 posters
Mike from NS
Mike from NS
Number of posts : 462
Brake Caliper mounting bolts Empty
PostSubject: Brake Caliper mounting bolts   Brake Caliper mounting bolts I_icon_minitimeMon Sep 20, 2021 5:00 pm
Good day to all.  A little story to set the mood .....
September is my month every two years for an MVI on my 2005 Silverwing.
I had thought the MVI required more than 3/32" of tread depth to render a pass of the inspection.  And ... my rear tire was just on the line for that tread depth.
So I ordered a tire from my local dealer and had the tire in hand about 10 days later.  ( I went with another Michelin Power Pure.)  So I removed the rear wheel all set to take it to a shop for the switch.  But decided to check with Motor vehicle requirements for this tread depth and found they want 2/32".  That isn't much but for the amount of riding I'm doing that amount of rubber may last a while ; and why waste a tire with a bit of life left.  To be sure, since the local dealer will probably be the inspection station, I called to check their take on the matter.  Yup 2/32" tread will pass.   So I started the re-assemble.
 Checking the rear brakes I found lots of brake pad and enough rotor thickness.  The front pads were thin and questionable so I replaced the pads.  To complete the job I grabbed my trusty torque wrench and proceeded with caution.  All done and snugged but wanted to check the rear caliper bolts without the torque wrench.  Just gave them a bit of pressure with the socket and driver.
MISTAKE ! ! !
I broke one of the two M8X50 Flange Bolts.  The other one looked stressed.  So off to the dealer for two bolts.... or so I thought.  Not in stoke nor in stock at Honda Canada.  Earliest estimated delivery was mid November and maybe not until January.  Off to a bolt supplier ...no luck.  I did find M8x50 Hex Head Cap Screws at Princess Auto (Similar to the US Lowes) And with a washer this should work.   But my question ...... Does anyone have a recommendation of a supplier of these bolts.  Partzilla has them but they don't ship to Canada, as far as I can tell.
Moral of this story ....trust your torque wrench. Your comments will be appreciated.
Mike
Number of posts : 929
PostSubject: Re: Brake Caliper mounting bolts   Brake Caliper mounting bolts I_icon_minitimeMon Sep 20, 2021 5:18 pm
First, the Princess Auto equivalent in the USA is Harbor Freight. Lowes is more like Home Depot or Rona.
Second, we have a Bolts Plus where I live. They usually carry every shape and size of bolt, nut, screw and fastener I've ever needed. Also, our local Fastenal store usually has all kinds of fasteners as well but I find them pricier. Another name we can access is Debrasco or something like that. I obvious don't shop there but I have driven by it.
Since you know the bolt you want, perhaps asking the aliens (Google it) will help? It's likely going to be an industrial/commercial hardware supplier that will carry what you want. Good Luck Mike.
Number of posts : 388
PostSubject: Re: Brake Caliper mounting bolts   Brake Caliper mounting bolts I_icon_minitimeMon Sep 20, 2021 5:24 pm
Maybe try a local motorcycle wrecker; they usually have a bin full of surplus fasteners, and the Silverwing will use a common size across lots of Hondas.
Mike from NS
Mike from NS
PostSubject: Re: Brake Caliper mounting bolts   Brake Caliper mounting bolts I_icon_minitimeMon Sep 20, 2021 8:24 pm
Thanks for the help ...
Yes Harbor Freight is what I had in mind.
I stopped at Fastenal in Dartmouth this afternoon. Locked up tighter than a jail. Had to call from the parking lot and got nowhere with that. I see Wurth in Guelph has the bolt in a minimum package of 10 for about $27. I also see Fastenal in Halifax lists the bolt for $1.22. The Dartmouth shop had signage indicating minimum purchase of $20. I haven't checked with TransWorld in Dartmouth yet.
Anyway I think I can find the right bolt now. But those from Princess Auto will do for now.
Again ...thanks for your replies.
» Rear Caliper Mounting Bolts Torque
» Eric Walker’s stripped caliper mounting bolt
» Front brake caliper
» Brake Caliper Grease
