| Can I start my Silverwing in this condition? | |
Gustafa Super Scooter Rider
Number of posts : 218 Location : Cordova, TN Points : 3361 Registration date : 2015-10-10
| Subject: Can I start my Silverwing in this condition? Tue Aug 08, 2017 9:00 am | |
| As most of you know, Im overhauling the look and doing normal maintenance of the Silverwing.
Finally have both rims back from powdercoat, new tires installed, front tire on and rear tire goes on tonight - all new brakepads all around.
My question is - I have the front cowl completely off without the headlights attached to the wiring harness.
Can I still start the bike up in this state without issue?
I just want to give it a chance to run for a few minutes as its been siting on a stand for a while now.
Thanks ahead of time! |
Number of posts : 327 Age : 84 Location : Orlando Fl. USA Points : 3077 Registration date : 2017-05-13
| Subject: Re: Can I start my Silverwing in this condition? Tue Aug 08, 2017 9:12 am | |
| - Gustafa wrote:
- As most of you know, Im overhauling the look and doing normal maintenance of the Silverwing.
Thanks ahead of time! Yes, But why take the chance of damaging something in the Charging or Electrical systems by doing this? Patience, Continue your great work. Happy motoring lloyd 193. |
| Subject: Re: Can I start my Silverwing in this condition? Tue Aug 08, 2017 9:17 am | |
| - lloyd193 wrote:
Yes, But why take the chance of damaging something in the Charging or Electrical systems by doing this? Patience, Continue your great work. Happy motoring lloyd 193. Thanks! I dont have to start it, but just wanted some collective wisdom and def dont want to damage any electrical. |
dekare Maxi-Scooter Rider
Number of posts : 125 Location : MN Points : 2925 Registration date : 2016-08-09
| Subject: Re: Can I start my Silverwing in this condition? Tue Aug 08, 2017 10:58 am | |
| Mine sits 6 months of the year without starting. |
| Subject: Re: Can I start my Silverwing in this condition? Tue Aug 08, 2017 12:16 pm | |
| - dekare wrote:
- Mine sits 6 months of the year without starting.
Ive sat 4 months before without starting and she starts right up. I think as I work through her, I just want peace of mind, but Ill have that next week LOL |
bandito2 Maxi-Scooter Rider
Number of posts : 181 Location : Somewhere outside of the box Points : 5306 Registration date : 2010-04-04
| Subject: Re: Can I start my Silverwing in this condition? Wed Aug 09, 2017 4:30 pm | |
A couple years ago, mine had sat in my garage for over 3 years after being rear ended and never having been started that whole time. Fixed the broken parts, put in a new battery and crossed my fingers when starting it up for the first time in 3 1/2 years. Cranked just a little bit more than normal, but started on the first try. WOW! I was amazed and impressed by the wonder of FI. Siphoned out the old gas, put in fresh with some Sea Foam fuel treatment and it has been good to go ever since. (these things just don't want to die) |
Number of posts : 1981 Age : 77 Location : Princeton, MN Points : 5816 Registration date : 2014-02-13
| Subject: Re: Can I start my Silverwing in this condition? Wed Aug 09, 2017 10:30 pm | |
| When I bought my 08 SWing from my sister in FL it sat under a tarp for two years before I got it. When I got it home I ordered two new tires, a belt, 26 gram Dr Sliders and a new battery. While waiting for them to get here I hooked the jumper cables from my pickup to the SWing battery cables (I already had the old dead battery out). I wanted to check out all the lights etc just to make sure they all worked. They all did. Then I got the idea of seeing if it would start with 1/2 a tank of two year old gas. It turned over about 3 times and fired right off and purred like a kitten with no smoke or complaining. When I put the new belt on I also put in the 26 gram Dr Sliders and haven't had any problems with it all these four years. The battery I ordered was off eBay and cost $25. I just wanted it running and hoped the battery would last the whole riding season, which it did. During the first winter I ordered a Battery Tender Lithium Ion battery and installed it and haven't had a problem with that either. |
Thebreen Scooter Rider
Number of posts : 78 Age : 61 Location : Space Coast, Florida Points : 4667 Registration date : 2011-09-15
| Subject: Re: Can I start my Silverwing in this condition? Fri Aug 11, 2017 1:06 pm | |
Thanks ahead of time! if i understand your question / configuration - I would not hesitate to start my silverwing if all i had disconnected was the headlights. i would not expect any problems to any of the systems as a result of doing so. if MORE than just the headlights (and turn signals) are disconnected i would be more hesitant. why do you want to start it? when was the last time it was run? |
| Subject: Re: Can I start my Silverwing in this condition? | |
