| Tire inflation | |
+6cliffyk Modernman1953 cotetoi bandito2 exavid lloyd193 10 posters |
Number of posts : 327 Age : 84 Location : Orlando Fl. USA Points : 3077 Registration date : 2017-05-13
| Subject: Tire inflation Sun May 28, 2017 4:47 pm | |
| I do not know if this subject has been discussed Previously, But here goes. Many places are selling Nitrogen for tires at high prices, Our earths Atmosphere is about 80% nitrogen, so paying for Nitrogen is only replacing about 20% of the air in that tire. Save your Money and Check those tires a little more often. Happy Motoring lloyd 193. |
| Subject: Re: Tire inflation Sun May 28, 2017 8:15 pm | |
| I've been using 78% nitrogen for years in all my vehicles. I find it works quite well. |
bandito2 Maxi-Scooter Rider
Number of posts : 181 Location : Somewhere outside of the box Points : 5306 Registration date : 2010-04-04
| Subject: Re: Tire inflation Mon May 29, 2017 1:02 am | |
| - exavid wrote:
- I've been using 78% nitrogen for years in all my vehicles. I find it works quite well.
Me too... And it's free! |
cotetoi Silver Wing Expert
Number of posts : 757 Location : New Brunswick, Canada Points : 4825 Registration date : 2013-06-27
| Subject: Re: Tire inflation Mon May 29, 2017 11:30 am | |
| A bit like bottled water from exotic places. Tap water is only tested once a day. |
Number of posts : 379 Location : Yuma, AZ Points : 3283 Registration date : 2016-06-01
| Subject: Re: Tire inflation Mon May 29, 2017 3:38 pm | |
| I use compressed 78% nitrogen. It works better under pressure. Like some of our Mods do. |
| Subject: Re: Tire inflation Mon May 29, 2017 9:12 pm | |
| Surprising that you can't get the stuff at gas stations. I've asked a couple guys at some local stations and they tell me all they have is air. Check and see if your local station carries 78% nitrogen. |
| Subject: Re: Tire inflation Tue May 30, 2017 3:02 pm | |
| Trouble with that leaking bead area is a simple fix. Next time that tire is off that rim use your wire brush to thorouly clean that bead area, Finish that cleaning with some steel wool until that bead is smoothe. Then two coats of clear aerosol spray, Krylon works well for me. After you have done both bead areas, Allow to dry over night is best. Then mount that new tire using a good Lubricant and your bead leak problem will have Disappeared. Happy motoring lloyd 193. |
cliffyk Maxi-Scooter Rider
Number of posts : 182 Age : 77 Location : Saint Augustine FL Points : 3075 Registration date : 2016-05-15
| Subject: Re: Tire inflation Tue May 30, 2017 3:41 pm | |
| I also use nothing but the 78.09% nitrogen, 20.95% oxygen, 0.93% argon, 0.04% carbon dioxide blend, have been on all my pneumatic tired things for over 65 years--and check the tires on my '06 at least once a week as It's parked just 7 feet away from my compressor--and because there's only two of them and I had one blow out once (rear), it sucks¹...
------------------------------------------- ¹ - Back when motorcycle seats were upholstered with leather we had an expression for experiences like tank-slapping turns on washboard roads, tire blowouts, etc.--"It's a good thing shǐt sticks to leather". I have found over the years it sticks acceptably well to vinyl too. |
| Subject: Re: Tire inflation Wed May 31, 2017 12:46 pm | |
| I use a tire pressure monitoring system that keeps track of the amount of compressed nitrogen I have in my passenger tire commonly referred to as darkside. A simple weekly check of my nitrogen pressure with a nitrogen pressure tester to double check the accuracy of the passenger tire pressure monitoring system assures me that the monitoring system is working properly. NOTE: The adapter to check the nitrogen pressure vs the regular air pressure is an app that can be downloaded for free online. Just google passenger tire nitrogen pressure monitoring adapter. Below is a picture of a manual nitrogen pressure tester. I hope this clears the air. |
Bash On! Super Scooter Rider
Number of posts : 252 Location : Dallas, Texas Points : 3412 Registration date : 2015-08-24
| Subject: Re: Tire inflation Wed May 31, 2017 3:18 pm | |
| I was all in favor of the TPMS in my car until I realized that when the transmitter batteries wear out it's $250 to renew the system. |
| Subject: Re: Tire inflation Wed May 31, 2017 11:39 pm | |
| There are some decent TPMS units available that don't require batteries that expensive. Of course on a car there's the labor in removing, breaking the bead, installing new battery, reseating the tire times four. My GT came with TPMS as standard equipment. Replacement batteries aren't all that expensive for it. Surprising considering the usual price of BMW parts. |
| Subject: Re: Tire inflation Thu Jun 01, 2017 1:17 am | |
| My tire pressure monitoring system uses the valve stem caps and the batteries are small 1.25 Volt batteries which costs $2.00 each at Batteries Plus. I haven't had to replace one yet as mine came with spares, but I did check on the replacement batteries.
| Subject: Re: Tire inflation Thu Jun 01, 2017 9:05 am | |
| Okay, so what TPMS should I be looking for then? Something that doesn't require breaking the tire bead to mount inside, something which mounts outside and presumably replaces the valve stem? Or is it that a truly functional TPMS mounts inside the rim? Photos? Inquiring minds want to know.
| Subject: Re: Tire inflation Thu Jun 01, 2017 12:24 pm | |
- Okay, so what TPMS should I be looking for then? Something that doesn't require breaking the tire bead to mount inside, something which mounts outside and presumably replaces the valve stem? Or is it that a truly functional TPMS mounts inside the rim? Photos? Inquiring minds want to know.
Tim I use a direct observation and periodic validation based system, it consists of:
- Looking at the tires before I ride to see if they look properly inflated, worn, or damaged in any way;
- Checking the inflation pressure a couple times a week, or if I haven't ridden in a while--which is rare here in Florida;
- A close inspection of tread depth, sidewall condition, etc. once a month or so;
This has been working for 60+ years--I.e. it ain't broke so I'm not planning on fixing it anytime soon... |
terrier Super Scooter Rider
Number of posts : 299 Age : 74 Location : Northumberland, UK Points : 3489 Registration date : 2015-08-12
| Subject: Re: Tire inflation Thu Jun 01, 2017 1:14 pm | |
| - cliffyk wrote:
- I use a direct observation and periodic validation based system, it consists of:
[*]Looking at the tires before I ride to see if they look properly inflated, worn, or damaged in any way; [*]Checking the inflation pressure a couple times a week, or if I haven't ridden in a while--which is rare here in Florida; [*]A close inspection of tread depth, sidewall condition, etc. once a month or so; [/list] This has been working for 60+ years--I.e. it ain't broke so I'm not planning on fixing it anytime soon... Thanks Cliff. I realize that that TPMS works well for some of you folks in the more temperate weather zones, but getting down to check pressures then attempting to get back up is a tedious and oft times painful task for me. I was kinda hoping that some one of you guys had a magic soultion for monitoring tire pressures. Tim |
| Subject: Re: Tire inflation Thu Jun 01, 2017 1:56 pm | |
| One of the things that I liked about my scooter when I got it was the TPMS. At 74 with arthritis it's uncomfortable to get at the valves with my gauge. I often put the bike up on my HF bike lift just to check tire pressure. The system on my GT isn't super accurate it reads about three psi below what my two tire gauges show. Since the differential is pretty constant I know if I see 39psi on the rear tire it's actually 42psi which is the proper pressure. A fellow down the street from me has one of the cheap systems in the link below. He got it a few months ago and says it's working well for him. He has it on a Harley and mounted the receiver inside the fairing where he can see it but it's not too obvious to prevent theft. The sensors on the wheels don't look too obviously different so they don't call attention to themselves. https://www.walmart.com/ip/Measurement-Limited-Motorcycle-TPMS-Monitor/21118551?wmlspartner=wmtlabs&adid=22222222222015273670&wmlspartner=wmtlabs&wl0=e&wl1=o&wl2=c&wl3=10359492225&wl4=kwd-1103077496333&wl12=21118551_0&wl14=motorcycle%20tpms&veh=sem
Number of posts : 1012 Age : 73 Location : HI Points : 4111 Registration date : 2015-12-18
| Subject: Re: Tire inflation Thu Jun 01, 2017 2:17 pm | |
| Tim, I use the FOBO TPMS system to monitor my tire pressure. It mounts on the valve stem and uses Bluetooth to communicate to your cellphone. It does have a replaceable round battery. Works with IOS and Android phones. The battery lasts about 2 years. I have had mine for about four years now and have not had any problems with it. At anytime you can check it with your phone. You set the max/low pressures for both tires. You get automatically notified when the actual pressure falls out of the range you set. You do have to unscrew it from the valve stem to add air. I have used it long enough to trust it, so I only get on my knees when I get notified of a low pressure. |
| Subject: Re: Tire inflation | |
| Tire inflation | |
