| freewheeling | |
kevinbrady Scooter Rider
Number of posts : 23 Location : uk Points : 2717 Registration date : 2016-12-14
| Subject: freewheeling Sun Mar 05, 2017 8:17 am | |
| hi silverwingers enjoying commuting and local riding on my new to me 2004 wing the weather is too crappy and i am too old to enjoy a long run new tyres and new belt and new fork seals fitted have to move or remove the backrest as i find it a bit cramped wierd thing is when i am going really slowly the clutch is disengaged and the scoot freewheels , its not a prob but just wierd is this normal , ??? never had the same on any other cvt scoot sorry if this is a stupid question and thanks |
Number of posts : 1936 Location : Hocking Hills U.S.A. Points : 5145 Registration date : 2016-01-29
| Subject: Re: freewheeling Sun Mar 05, 2017 9:32 am | |
| The freewheeling is normal, under 2000 rpm's I believe. I took a little riding to get used to that and the two hand lever stop on a dime give a nickle change brakes |
| Subject: Re: freewheeling Sun Mar 05, 2017 10:01 am | |
| thank you my minds at rest now :not worthy: |
steve_h80 Silver Wing Expert
Number of posts : 997 Location : Teesdale, UK Points : 3972 Registration date : 2016-05-15
| Subject: Re: freewheeling Sun Mar 05, 2017 12:29 pm | |
| It gave me a fright first time it happened too! |
| Subject: Re: freewheeling Sun Mar 05, 2017 1:57 pm | |
| thanks steve yes its what i felt , i thought the belt , clutch, variator were the prob i just need to adapt my low speed manouvering to the peculiarities of the bike best wishes
NWSSC Silver Wing Rider
Number of posts : 418 Age : 86 Location : Mt Prospect IL 30 miles west of Chicago Points : 5632 Registration date : 2010-03-03
| Subject: freewheeling Sun Mar 05, 2017 2:52 pm | |
| Yes it all sounds normal. With a little practice try maneuvering at low speed and applying the left brake lever slightly to help stabilize the scooter. With a little practice it defiantly helps at low speed. Howard |
| Subject: Re: freewheeling Sun Mar 05, 2017 4:33 pm | |
Riggers Scooter Rider
Number of posts : 60 Location : Hull, England Points : 3259 Registration date : 2015-08-18
| Subject: Re: freewheeling Wed Mar 08, 2017 3:25 am | |
| I find it's a problem when going down a steep hill. When the clutch disengages you lose engine braking and have to depend entirely on the brakes. Not good. |
| Subject: Re: freewheeling Wed Mar 08, 2017 6:52 am | |
| - Riggers wrote:
- I find it's a problem when going down a steep hill. When the clutch disengages you lose engine braking and have to depend entirely on the brakes. Not good.
The only way I got to do that was on purpose, yes you can " coast " downhill but just a blip of the throttle will reengage the drive. |
| Subject: Re: freewheeling Wed Mar 08, 2017 8:52 am | |
| have not come across this going down hill bit yet but forewarned is forearmed it was just low speed corners or moving bike around in a tight area ,for sure i will get used to it |
Cookie Super Scooter Rider
Number of posts : 233 Location : Essex UK Points : 4829 Registration date : 2011-10-03
| Subject: Re: freewheeling Wed Mar 08, 2017 2:42 pm | |
| Yes, the clutch does disengage below around 15mph which is a bit higher than a lot of other scooters. It's not a problem though - it certainly never has been in my experience and I've been to quite a lot of hilly areas. Sometimes it can be a nice feature for example allowing you to roll gently up to traffic lights etc. However steep the hill the brakes should be fine at that low speed and if your speed is increasing due to rolling down the hill just blip the throttle as oldwingguy said - make sure you do it before the speed picks up too much though (which is just common sense surely).
Really it all just comes down to getting to know the characteristics of any new vehicle. |
| Subject: Re: freewheeling | |
| freewheeling | |
