Number of posts : 4416 Age : 81 Location : damn near Philadelphia, PA Points : 10531 Registration date : 2009-06-12
Subject: WTB Dr Pulley Sliders Wed Aug 10, 2016 4:11 pm
Anybody have a set of 26gm Dr Pulley Sliders for sale? PM me.
Tom G Scooter Rider
Number of posts : 95 Age : 86 Location : Jacksonville, FL Points : 4734 Registration date : 2011-09-10
Subject: Re: WTB Dr Pulley Sliders Wed Aug 17, 2016 1:57 pm
No, I don't have what you are looking for; however, I do have a question I'm sure you can answer.
First, are Sliders really more efficient than Rollers? And, what weight (of either type) gives lower RPM at highway speeds, and, conversely, faster acceleration from a stop to highway speeds?
Knowing that you can't have the best of both worlds, what is the best weight to achieve the optimum of each?
Thanks,
Tom
Subject: Re: WTB Dr Pulley Sliders Wed Aug 17, 2016 2:13 pm
Sliders are more efficient. OEM rollers are 28gm and switching to 28gm sliders will give improved performance, smoother operation (relative to OEM rollers) and lower RPMs at cruising speeds. 21gm sliders will give a whopping improvement in accelleration at the expense of fuel efficiency as well as top speed. That said, can you really notice the difference between 115mph and 100mph? So a good compromise would fall somewhere between the 21 & 28gm sliders.
Tom G Scooter Rider
Subject: Re: WTB Dr Pulley Sliders Wed Aug 17, 2016 2:29 pm
Thanks for the immediate reply.
So, Tim, as I am not into Drag Racing or taunting the Harley guys, would you suggest 28 gram sliders, not rollers, for best and improved, all around performance. yes?
While I'm at it, what are your thoughts on installing a J. Costa Variator?
Thanks again,
Tom
Number of posts : 2778 Age : 73 Location : NE Oklahoma Points : 8881 Registration date : 2008-12-28
Subject: Re: WTB Dr Pulley Sliders Wed Aug 17, 2016 3:08 pm
Hey Tom,
The J. Costa Variator, what a blast!!! A lot of us that have been involved with this scooter for a time installed a J. Costa Variator. I still have mine in a box in the garage.
Positive: Great off the line acceleration. WOW!!!
Negatives: Gas mileage drops, Variator light keeps coming on from over reeving, Belt life goes south much sooner, plates wear faster.
In short it's a lot fun for a short time and it wears out fast and is expensive to maintain.
janitorj1 Maxi-Scooter Rider
Number of posts : 104 Age : 70 Location : Folkston, GA Points : 3643 Registration date : 2014-09-07
Subject: Re: WTB Dr Pulley Sliders Wed Aug 17, 2016 3:45 pm
Can someone post a pic of the difference between a "roller" and a "slider"? So I want to buy a set of 28 gm sliders - where? Thanks all.
Everything is cool on my swing, but sliders seem intriguing. Simple enough job I presume...
Jon
Number of posts : 109 Age : 77 Location : Sedro Woolley ,WA Points : 3717 Registration date : 2014-06-12
Subject: Re: WTB Dr Pulley Sliders Wed Aug 17, 2016 5:04 pm
I have a J Costa with a few thousand miles on it. I'd let it go for 1/2 price of a new one plus shipping.... Dave
Tom G Scooter Rider
Subject: Re: WTB Dr Pulley Sliders Thu Aug 18, 2016 6:12 am
DennisB wrote:
Hey Tom,
Can't recall if I replied or not; anyway, thanks a lot for the info. No J. Costa for me. Sounds good on paper, but higher maintenance and replacement feature is not for me.
Tom G Scooter Rider
Subject: Re: WTB Dr Pulley Sliders Thu Aug 18, 2016 6:14 am
Thanks Dave, but I'll pass. What is your reason(s) for not using the J. Costa?
Same as Dennis B's?
Number of posts : 693 Age : 66 Location : Loveland, Colorado Points : 6236 Registration date : 2009-01-23
Subject: Re: WTB Dr Pulley Sliders Thu Aug 18, 2016 9:35 am
When I bought my 2007 Swing it came with the OEM rollers. I installed a J Costa variator and was thrilled with the improved acceleration and smoother feel, but after only about 10,000 miles it was showing a lot of wear on the plates and the variator light came on frequently, so I replaced the J Costa with the OEM variator but installed 26g sliders. This worked very well, but I missed the quicker acceleration I had with the J Costa, especially when riding in the mountains, so when I got my 2009 Swing I installed 22g sliders. These give me nearly the same acceleration as the J Costa, but overall I get better fuel economy. With the 22g sliders, I have lost a little off the top end. I used to be able to register 115 on the speedometer, and now it seems to top out at about 106, but since I never ride at that speed, the loss of top end isn't an issue. The real benefit is when riding in the mountains, the 22g sliders allow the engine to immediately jump into the power band when I need to accelerate up a hill or pass someone. I usually try to keep my revs at or less than 5,000 rpms and if I do I will get between 50 and 55 mpg. The worst fuel economy I get are on those occasions when I ride with a lot of hard acceleration, and even then, I will still get 48 mpg.
Tom G Scooter Rider
Subject: Re: WTB Dr Pulley Sliders Thu Aug 18, 2016 2:51 pm
Thanks for the info. Next belt change it will be 22g sliders for me.
Number of posts : 1012 Age : 73 Location : HI Points : 4133 Registration date : 2015-12-18
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 2:00 am
Tom, I experimented with 26, then 24gm sliders. I settled on the 24gm sliders for the off line response, and 500 RPM less at about 60MPH. I get around 50 MPG(US). Well worth the money. Good luck with your choice. Maybe others that went with the 22gm sliders will give their impressions.
Davefirestorm Scooter Rider
Number of posts : 94 Location : Norhamptonshire Points : 2994 Registration date : 2016-05-29
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 2:43 am
Interesting thread,my SW is just past 15k miles and I reckon I'll be using Dr.P 26g sliders with a new belt.But where in UK can I buy set or do I buy from States?
Old Limey Silver Wing Expert
Number of posts : 921 Age : 79 Location : BOLTON LANCASHIRE ENGLAND Points : 6079 Registration date : 2010-06-09
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 4:14 am
If you want Dr Pulley sliders in the UK go to Dr Pulley.com I think they come from Germany but you can choose the weight of sliders you want. I got 26grm for my last Silver wing and for my present one. They are about fifty pound.
The Bern Silver Wing Expert
Number of posts : 897 Location : Telford, UK Points : 4414 Registration date : 2014-11-20
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 4:42 am
Wotcha Dave, as Old Limey says Germany, 26 gram link ... http://drpulley.shopnix.de/product_info.php?products_id=572
Other weights available see ... http://drpulley.shopnix.de/index.php?cPath=47_58
Link corrected , many thanks to Cosmic Jumper for being 'on the ball'
Last edited by The Bern on Fri Aug 19, 2016 8:54 am; edited 2 times in total (Reason for editing : Removed incorrect link & added right one)
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 4:54 am
Thanks for that you two,so I just swap these sliders with the stock rollers and away we go lol? New belt needed too is the Honda one best or is there an alternative favoured?
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 6:02 am
Old Limey & myself are both using Gates belt from Wemoto
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 7:26 am
The Bern wrote:
Wotcha Dave, as Old Limey says Germany, direct link for 26 gram .... http://www.ebay.co.uk/itm/Variomatic-Weight-17-0g-Dr-Pulley-26-x-13mm-set-A-8-pieces-442959-/272307366500?hash=item3f66c8aa64:g:NCMAAOSwygJXh1m-
Bern, the first link to eBay is NOT for Silverwing sliders. It appears that they are for some Suzuki models. The measurements for Dr Pulley S'Wing sliders are 28 x 20 x (chosen weight).
The second link to the Dr Pulley Shop in Germany does show the slider options available for S'Wings.
Retired Scooter Rider
Number of posts : 29 Age : 68 Location : Charlotte Michigan Points : 2864 Registration date : 2016-08-06
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 7:41 am
I just picked up a set from BPNW Dr Pulley slider 28-20 26g (503-860-7250) talked to Mike For $54.95 plus shipping
Number of posts : 462 Age : 71 Location : Nova Scotia Points : 4380 Registration date : 2013-09-12
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 7:42 am
Would you "post" the Gates belt number please? I looked at the Wemoto site hoping to find the number -- but no luck. Thanks. Mike
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 7:51 am
I went with the Honda belt I bought on EBay for $117 plus shipping
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 8:15 am
Right you are Tim, Not sure how I managed that correct link for 26 grams is .... http://drpulley.shopnix.de/product_info.php?products_id=572
Edit : Correct link & a thankyou added to original post, well spotted Tim
Last edited by The Bern on Fri Aug 19, 2016 8:57 am; edited 1 time in total (Reason for editing : as noted)
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 8:20 am
No prob's, just need to go & find my WSM
EDIT : And he's back
Gates part # 9802-41804
I did post this a while back & IIRC it was Bigbird that researched it & found that Gates outlets in the USA did not stock it, due to lack of demand or something similar, however that situation may have changed since
Last edited by The Bern on Fri Aug 19, 2016 8:32 am; edited 1 time in total (Reason for editing : as noted)
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 9:12 am
You will also need a torque wrench for the centre nut .. 76 Lb Ft / 103 N.m / 10.5kg m
While you've got it in bit's, there's a dust filter at the front of the outer cover, blow it clean, obviously blow dust out of the casing & there is a clutch shaft support bearing at the rear of the casing, give it a dollop of grease.
Subject: Re: WTB Dr Pulley Sliders Fri Aug 19, 2016 9:25 am
Couple of video's that may help you ...
Think this one is Bigbird working on another members scoot'
Ohi if you go for a Gates there are no direction of rotation arrows, set it so you can read the name
Tom G Scooter Rider
Subject: Re: WTB Dr Pulley Sliders Sat Aug 20, 2016 8:02 am
Hello Bern,
Your video on belt replacement is absolutely excellent. I've replaced my belt several times, and still learned several important tips from your video.
Thank you
By the way, you mentioned that the nut holding the variator is 17mm. For some reason I though it was larger. I ask because when I take a long trip I like to include the socket that fits that nut. Please confirm that if you will. I had a 2002, and now have a 2013.
Again, thank you for everything you show me (us).
Tom G
Subject: Re: WTB Dr Pulley Sliders Sat Aug 20, 2016 9:11 am
Hi Tom, neither of those you tube video's was made by me, I'm not certain of the socket size myself either, it's been some time since I changed my own one.
Tom G Scooter Rider
Subject: Re: WTB Dr Pulley Sliders Sat Aug 20, 2016 9:27 am
Thanks Bern,
Perhaps someone else out there in "Honda Land" knows, Yes?
The question is: What is the size of the nut that holds the Silver Wing Variator?
I thought it was a 24mm nut, but the video that Bern's posted suggests 17mm.
Please reply if you know.
P.S. I'm to lazy to remove the covers to find out, and I want to carry the correct socket with me.
Thanks.
Tom G
Subject: Re: WTB Dr Pulley Sliders Sat Aug 20, 2016 11:55 am
Davefirestorm, I do use the Gates belt the first one I got from Wemoto, but, the last one was from somewhere else. If you put Gates Drive belts on EBay search, suppliers will come up. Just one point, direction of travel does not matter with the gates belt.
sctr199 Maxi-Scooter Rider
Number of posts : 142 Age : 73 Location : El Cajon, CA Points : 4073 Registration date : 2013-07-29
Subject: Re: WTB Dr Pulley Sliders Sat Aug 20, 2016 7:17 pm
Tom G wrote:
Thanks Bern,
Thanks.
Tom G
It indeed is a bolt that requires a 17mm socket.
Subject: Re: WTB Dr Pulley Sliders Sun Aug 21, 2016 6:13 am
Yep, as sctr says ^^^ 17mm, can't possibly be 24mm as that size socket is to large to pass throuh the hole in my variator locking plate ...
Subject: Re: WTB Dr Pulley Sliders Sun Aug 21, 2016 6:49 am
Bern, What is that Special Tool you've made? The 3rd & 4th pics shown on your Photobucket page. A bolt with a grease fitting, hmm...
Subject: Re: WTB Dr Pulley Sliders Sun Aug 21, 2016 8:03 am
Hi Tim, I was gonna post about that, the bolt is the lean stand pivot, when I was doing a 'lube' service the stand was a bit stiff, on stripping there was a fine layer of dry dirt on the pin & the hole in the stand. So I cross drilled it then drilled down the centre, tapped & fitted a grease nipple. Which then lead onto the logical extension of how to grease the pivot points of the centrestand (blurred picture), I had a dig through my 'odds 'n sods' box & found a couple of press fit nipples, a bit fiddly to do as there is not a lot of metal to work with, now at Autumn & Spring services two shots in each with the grease gun & the job's a good 'un
cliffyk Maxi-Scooter Rider
Number of posts : 182 Age : 78 Location : Saint Augustine FL Points : 3097 Registration date : 2016-05-15
Subject: Re: WTB Dr Pulley Sliders Mon Aug 22, 2016 12:12 am
FWIW my first CVT mod on my new to me '06 S/W, as I was familiar with running DRP sliders on my '400 Burgman, was to install 26 g sliders--I was happy with the performance gain but there is always room for more so I ordered and installed a set of 22 g sliders.
What I found was that though initial acceleration was better it was not as improved as anticipated as the WOT rpms off-the-line climbed to 6400 or so--beyond what my 70 year-old, calibrated and re-calibrated for over 50 years, butt dyno tells me is the engine's peak torque band of 4500 to 5500 rpm. In fact pulling power between 40 and 55 mph seemed less than with the 26 g sliders or OEM rollers. Engine rpm at an indicated 70 mph (63 mph actual) was just under 5200 and it cost 3 to 4 mpg in my normal driving (I live "out in the county" and it's 10 to 12 miles of 65 to 70 mph to get anywhere)
So I opened it up again and loaded (4) 22 g and (4) 26 g (overall the same mass as eight 24 g) sliders. This combo revs to 5500 at WOT startup and seems to be delivering all the engine has. Engine speed at 70 indicated is just over 5000, first tank fuel economy indicates I got back 1-2 mpg; though that is not a major concern. My other set of "wheels", a '96 SL500, gets 15 to 17 mpg on a good day; it's one of those "passes most anything but a gas station" vehicles.
If asked I would recommend 24 g sliders for the 600 S'wing.
Next project is to play with increasing the torque multiplier spring preload. I had good results improving both initial and "passing" acceleration on the Burgman by making a 0.0150" spacer/shim to tighten up the torque multiplier's performance...
Subject: Re: WTB Dr Pulley Sliders Mon Aug 22, 2016 1:14 am
cliffyk wrote:
[EDIT] Next project is to play with increasing the torque multiplier spring preload. I had good results improving both initial and "passing" acceleration on the Burgman by making a 0.0150" spacer/shim to tighten up the torque multiplier's performance...
So increasing the torque spring tension by adding a ~4mm thich spacer would also mean that RPMs needed to be increased to overcome that increased tension. That increased preload also resulted in increased initial and midrange/passing accelleration. Do you feel that that modification was driven because of the "24gm" sliders, and would that mod have been advantageous or necessary if only using 26gm sliders?
Won't decreasing the variator weights while increasing the torque spring tension cause the power band to shift higher up the RPM range? Does the increased spring tension "narrow" the power band vs the power band resulting from "only" switching to lower weight sliders?
Subject: Re: WTB Dr Pulley Sliders Mon Aug 22, 2016 4:50 am
A rolling road dyno would probably give more accurate results
