Hi, this forum is not accepting new members. You should join www.maxi-scoots.com . They are for scooters and motorcycles and have a Silverwing section.
» Cock a doodle do
by Max Q Today at 7:19 pm
» First Road Trip
by Chris Olson Today at 6:44 pm
» Aftermarket exhaust.
by Hondafreak Today at 6:38 pm
» Please submit a picture of your Silver Wing
by steve_h80 Today at 4:29 pm
» Be ready at all times
by Pastor Ron Today at 4:10 pm
» Today's Liberals
by EvilTwin Today at 10:57 am
» can castrol GTX ultraclean 10w-40 a3/b4 be used as final drive oil?
by GHM-PM Today at 8:14 am
» Worn out variator?
by Mighty Mouse Today at 12:30 am
» What did you do to your SW today.
by Mech 1 twa Yesterday at 7:42 pm
» Silverwing Bulletproof engine
by Mech 1 twa Yesterday at 7:34 pm
 [SOLVED] Givi V46 light kit won't go on
thornev
Number of posts : 15
Registration date : 2016-06-13
PostSubject: [SOLVED] Givi V46 light kit won't go on   Tue Jun 14, 2016 8:41 pm
On my 2004 FSC600D the Givi 46V Monokey Top case has the light kit that is supposed to light the 4 round LED lights.  It seems to be wired correctly, but the lights don't go on as running lights nor brake lights.  I can't find a wiring diagram for the scooter.  Does anyone know to what tail light/brake light wires on the scooter the blue and black light kit wires should be wired to?  (yikes, ended a sentence with a preposition!)  Thanks.
avatar
Number of posts : 3109
PostSubject: Re: [SOLVED] Givi V46 light kit won't go on   Wed Jun 15, 2016 5:11 am
Green (Ground)
Light Blue (Rt Signal)
Orange (Lt Signal)
Black/Brown (running lights)
Green/Yellow (brake lights)
thornev
PostSubject: Re: [SOLVED] Givi V46 light kit won't go on   Wed Jun 15, 2016 5:22 am
Thanks, Mike !  Cheers.
avatar
PostSubject: Re: [SOLVED] Givi V46 light kit won't go on   Wed Jun 15, 2016 5:28 am
Pleasure!
Good luck. Smile
thornev
PostSubject: Re: [SOLVED] Givi V46 light kit won't go on   Wed Jun 15, 2016 9:38 am
A little troubleshooting and I found the problem. The bottom spring-loaded connector by the trunk latch was not firmly making contact with the corresponding metal poles on the top of the trunk. What I did to fix was to put a tie around the connector to make it sit higher and put a piece of adhesive between the connector and the trunk piece that holds the connector in place so the connector wont wiggle. Let there be (brake) light !
avatar
PostSubject: Re: [SOLVED] Givi V46 light kit won't go on   Wed Jun 15, 2016 10:29 am
Excellent! cheers
thornev
PostSubject: Re: [SOLVED] Givi V46 light kit won't go on   Thu Jun 16, 2016 1:43 pm
deleted - already answered above.
