| February 2012 | | Sun | Mon | Tue | Wed | Thu | Fri | Sat |
| | | | 1 | 2 | 3 | 4 | | 5 | 6 | 7 | 8 | 9 | 10 | 11 | | 12 | 13 | 14 | 15 | 16 | 17 | 18 | | 19 | 20 | 21 | 22 | 23 | 24 | 25 | | 26 | 27 | 28 | 29 | | | | Calendar |
| Author | Message |
Bernardo Super Scooter Rider
Number of posts: 261 Location: Buckinghamshire, United Kingdom Points: 1347 Registration date: 2008-12-25
 | Subject: Worn J costa pins, and slightly higher revs. Sun May 31, 2009 5:10 pm | |
| Hi Folks, The other day I noticed that the first bar of my fuel gauge went down when I was on 38 miles.... Normally its in the forties.... I had been doing a fair bit of stop start riding mind, and with a heavy right hand on the throttle. After using a full tank with more varied riding MPG was around 48 as usual. However again I was in the high thirties when the first bar of the fuel guage went off, so I filled up and worked out I had been doing about 44 MPG, a bit lower than the norm, but again in stop start traffic. I checked my revs against speed and have discovered my revs are up about 200 to what they were when I first had the J costa installed.... I reckon that my drive belt has done about 13-14k miles, since its last change and the variator pins are have done about 6,500 -7,000 miles, so I figure its either the pins, the belt or both that are the culprit. That said I do tend to ride the S'wing quite hard, especially when commuting... I am quite surprised about the revs at 40mph mind! Still the S'wing seems to be going as fast as ever, I've not noticed a drop in performance, which I suppose also would tie in with the pins being worn, thus getting lighter....? That said, since the J costa works on a transverse system as opposed to a longitudinal one (as with the stock variator) would lighter pins make a difference.... In which case, I might be needing a new belt... MPH Original Revs Revs Now 40 4,000 4,300-4,400 50 4,500 4,700 60 5,100 5,300 70 5,600 5,800 80 6,200 6,400 Happy Riding! |
|  | | JeffR Site Admin
Number of posts: 1672 Age: 52 Location: Fremont, Ca Points: 2835 Registration date: 2008-12-19
 | Subject: Re: J. Costa Variator Sun May 31, 2009 7:06 pm | |
| Bernardo, I would think that your pins, if worn enough, could be causing the 200rpm difference. That is what happened to me the first time I changed the pins, and I changed them at about 8,500 miles. Your belt should probably be good for about 20,000 miles really. I changed mine at 12,000, just because I was installing the J. Costa for the first time, and decided to start with the new Mitsibishi belt. I keep the old one since it looks brand new still. When I decide to get new pins again I am going to use the dry lube on the bell housing to see if it reduces the friction and maybe allows the pins to last longer. Not sure if it will work... but what the heck. I was thinking that the worn pins increases the rpm's since they are ground down and probably weigh less. That is just my opinion but it seems to make sense. _________________ Ride safe, JeffR 2007 Silver Wing (30,000 miles) 2005 Majesty 400 (sold 12,500 miles) 2004 Reflex (sold 3,500 miles) Givi Windshield, top case, vista cruise, power commander, dr pulley sliders, air hawk seat pad, (J. Costa not installed now), kevlar belt  |
 | Subject: Re: J. Costa Variator Mon Jun 01, 2009 2:46 am | |
| Hi Jeff, Thanks for that. I guess I'll be contacting the scootertrap unless I can get the pins in UK / Europe.... It's crazy that its so difficult to get them here and thus easy to buy from the USA as I did with the variator! So it would appear that this is a downside of the J Costa.... So are you gonna consider the 21g Dr Pulley sliders? |
|  | | honda_silver Site Admin
Number of posts: 2111 Age: 51 Location: Georgetown, Tx Points: 3350 Registration date: 2008-12-23
 | Subject: Re: J. Costa Variator Mon Jun 01, 2009 6:49 am | |
| | Bernardo wrote: | | I'll be contacting the scootertrap unless I can get the pins in UK / Europe.... It's crazy that its so difficult to get them here and thus easy to buy from the USA as I did with the variator! |
http://www.jcostacompetition.co.uk/distributors.html_________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
|  | | darrwin Scooter Rider
Number of posts: 4 Points: 1026 Registration date: 2009-04-20
 | Subject: Re: J. Costa Variator Tue Jun 02, 2009 12:29 pm | |
| Just installed my new J Costa. I really took my time, since I'd never torn into a variator before. I made my own "variator tool" to hold the outer plate while turning the nut--worked great. Before installing the new one, I sprayed dry lube into the bell housing and on the pin face of the inner pulley side. I was careful not to get any on the belt-facing side.
Seems fine so far. Seems smoother overall, and actually quieter when engine braking to decelerate. Revs are somewhat higher: 4,000 at 30MPH and 5,200 at 60. Definitely takes off with a kick when I open the throttle, I guess because it goes to higher RPMs while the scooter starts to move. |
 | Subject: Re: J. Costa Variator Thu Jun 04, 2009 1:43 pm | |
| | honda_silver wrote: | | Bernardo wrote: | | I'll be contacting the scootertrap unless I can get the pins in UK / Europe.... It's crazy that its so difficult to get them here and thus easy to buy from the USA as I did with the variator! |
[url=http://www.jcostacompetition.co.uk/distributors.html | http://www.jcostacompetition.co.uk/distributors.html[/quote[/url]] Thanks for that! Bernardo |
 | Subject: Re: J. Costa Variator Sat Jun 06, 2009 4:28 pm | |
| | JeffR wrote: | Bernardo,
When I decide to get new pins again I am going to use the dry lube on the bell housing to see if it reduces the friction and maybe allows the pins to last longer. Not sure if it will work... but what the heck. I was thinking that the worn pins increases the rpm's since they are ground down and probably weigh less. That is just my opinion but it seems to make sense. |
I think I'll email the scootertrap and ask about that as having checked out the J Costa UK suppliers the price of a J Costa variator here in UK (Thanks Honda Silver!) is the same in pounds sterling as it is in US Dollars in the USA!! So I figure it will be probably be cheaper to get the pins from the Scootertrap anyway! And I have found a great way to actually get back to my former fuel economy... Its simply this... In town and traffic don't keep twisting the throttle too far just cos it feels so good, and you go faster! You just have to brake harder and sooner at the next set of lights... Chill out.... On the open road mind, well that's Ok to just let rip if the feeling takes you, and viola! I'm back at the 50mpg mark. I'll continue a while longer and see if the revs keep going higher...... I mean what the hell, in theory this means my S'wing will accelerate faster?  |
|  | | Captain Scooter Rider
Number of posts: 50 Location: St. John's, NL Canada Points: 1150 Registration date: 2009-01-24
 | Subject: Re: J. Costa Variator Sat Jun 13, 2009 5:08 pm | |
| Well, bit the bullet and got the J. Costa. Took a couple of hours with Jeff's instructions laid out before me but I eventually got there. However, I was really cautious with the screws and bolts to make sure I didn't lose any. Impact wrench made removal of the variator nut a piece of cake!! As far as the variator tool went, I didn't have any pieces of metal to make a Y shaped thingy. Wandered around and finally came across a piece of sample hardwood flooring that I picked up a few months back. I was 3 1/2" wide and close to 2' long. Drilled two holes for the bolts, and between the two bolts, I drilled a larger hole that I could use to torque the variator nut. Then I put one end of the piece of hardwood to hold it in place. It worked!! Torqued up to 76 or 78 lbs/ft - hard to tell precisely with the old pointer styled torque wrench but I checked it 3 times so it should be OK. Got a few minutes to ride it but it wasn't too warm so it was a short ride. The takeoff was much better (lag was all but gone). It seeemed to accelerate faster everywhere (speed wise). Its still not a sportbike but it certainly makes for a marked improvement. In fact, I think it feels a little more like my old CBR600F2 in terms of acceleration now than some of my previous sub 1000cc cruisers (relatively speaking of course) but the Swing has good power everywhere so its a far more enjoyable ride than the CBR ever was. I didn't open it full throttle really as I want to scoot around a bit first - although I haven't heard anyone say there's any kind of break-in period for the pins. Overall, it was seems to be worth the cost. I'll post more opinions once things warm up again. Captain |
 | Subject: Re: J. Costa Variator Sun Jun 14, 2009 8:52 am | |
| Hi There Captain, Welcome to the exciting world of J costa! By the way thanks for the tip about the variator tool... I'm thinking about replacing my drivebelt soon, and checking the pins, so that's a useful tip... I'll need to get myself a torque wrench and oder the belt... |
 | Subject: Re: J. Costa Variator Sun Jun 14, 2009 8:58 am | |
| | Bernardo wrote: | | JeffR wrote: | Bernardo,
I emailled the scooter trap and they (Matt) suggested that my belt was probably stretched and hence the higher revs. He said that the variator pins should be OK for 10-12k. I had the S'wing serviced not long ago, so I'll see how my overall fuel economy is and if it is getting worse I'll buy myself a torque wrench, and change the belt, and see what difference this makes before deciding whether or not to change the pins aswell. |
|  | | JeffR Site Admin
 | Subject: Re: J. Costa Variator Mon Jun 15, 2009 8:20 pm | |
| Bernardo, How many miles do you have on your pins? I ride kind of hard, and I think you do to, so we may wear them out sooner. I bought an electric impact wrench that only torque's to 90 ftlbs so I know I can't over tighten it too much at all. I do remember that my rpms' went up by about 200 rpm's and then when I changed them they went down the same amount. But hopefully you can get more miles out of your pins. _________________ Ride safe, JeffR 2007 Silver Wing (30,000 miles) 2005 Majesty 400 (sold 12,500 miles) 2004 Reflex (sold 3,500 miles) Givi Windshield, top case, vista cruise, power commander, dr pulley sliders, air hawk seat pad, (J. Costa not installed now), kevlar belt  |
 | Subject: Re: J. Costa Variator Tue Jun 16, 2009 7:56 pm | |
How many miles do you have on your pins? I ride kind of hard, and I think you do to, so we may wear them out sooner. I bought an electric impact wrench that only torque's to 90 ftlbs so I know I can't over tighten it too much at all. I do remember that my rpms' went up by about 200 rpm's and then when I changed them they went down the same amount. But hopefully you can get more miles out of your pins. |
Hi Jeff, Recently commuting into London (see my London commuting Adventure post) I managed a healthy 54mpg, in all sorts of traffic, including rush hour riding. So I am quite happy with that. It was a bit hair raising at times so I wasn't as hearty with the throttle..... My pins have done about 7,000 miles and the belt about 14,000. I shall just carry on as normal for now and monitor the revs...... I'm not sure why for a while my mpg was lower than usual.... Although I have altered my laminar lip which is now a bit lower on the screen, and I have not been as heavy handed throttle wise in urban traffic, though on the open road I still let rip at times... I reckon it's the slow stop start commuter crawl / too much low speed throttle happiness that really hits the economy. |
|  | | JeffR Site Admin
 | Subject: Re: J. Costa Variator Tue Jun 16, 2009 8:40 pm | |
| Hi Bernardo, I sure envy you getting that good of mileage. After reading about your and Bill's (Honda-Silver) mileage I know I have to get a Power Commander. If I'm conservative, doing mainly 55 mph or so I can get 51 mpg but if I really give it heck it is in the low 40's. As a matter of fact, I just filled up today after doing all interstate at 85-95 mph, and I only avg'd 39 mpg, which is kind of good I guess. But I was giving it WOT all the time but never going over 95 indicated. I just felt like having some fun for a tank. I also just commented on your London story, and it was a great story. Thanks. _________________ Ride safe, JeffR 2007 Silver Wing (30,000 miles) 2005 Majesty 400 (sold 12,500 miles) 2004 Reflex (sold 3,500 miles) Givi Windshield, top case, vista cruise, power commander, dr pulley sliders, air hawk seat pad, (J. Costa not installed now), kevlar belt  |
|  | | som2002 Scooter Rider
Number of posts: 50 Age: 39 Location: Janesville, WI Points: 1019 Registration date: 2009-06-19
 | Subject: Re: J. Costa Variator Fri Jun 19, 2009 12:31 pm | |
| Ordered mine today, can't wait till it gets here. Kinda bummed out about the whole having to replace the pins all the time though...I sure hope it is worth that extra hassle. |
 | Subject: Re: J. Costa Variator Sat Jun 20, 2009 3:38 am | |
| | som2002 wrote: | | Ordered mine today, can't wait till it gets here. Kinda bummed out about the whole having to replace the pins all the time though...I sure hope it is worth that extra hassle. |
Yeah there is that, but a small price to pay methinks..... Having spoken to the scooter trap, I shall not be replacing mine for a while... Have had to spend money on other stuff, including a new set of tyres for my bike.... Which highlights another advantage of the scoot, which is that even when you hustle, you still get a good life out of your tyres... Yet on my bike, although by todays bike standards it has at best modest performance, when you use it (especially now with the better summer weather) the tyres wear kinda quick.... One of life's certainties...... everything wears... sigh (including my hair which is now a nice shade of grey). I suppose the big question is how best to enjoy the wear! |
|  | | The Scootist Silver Wing Rider
Number of posts: 458 Age: 54 Location: Littleton, Colorado Points: 1543 Registration date: 2009-01-23
 | Subject: Re: J. Costa Variator Mon Jun 22, 2009 7:01 am | |
| Bernardo said: even when you hustle, you still get a good life out of your tyres...
I would have to agree. I had just over 8,000 miles on my tires and I knew I was in need of a new rear tire. I had ordered the replacement (Bridgestone Hoop) and even had set up an appointment for tomorrow (Tuesday) to have the new tire mounted, but last Friday while on the way home the old tire blew out when I was cruising along the highway at about 60 mph. When it went, it sounded like a gunshot blast right in my ear - very loud. But the bike didn't feel squirrely or anything, so I wasn't exactly sure what had happened (But with a loud boom like that I knew it wasn't good), so I coasted off the road and looked things over. Sure enough I had run the tire down to cords in one place and that was where it blew. I guess the good news is that the sidewalls of a motorcycle tire are stiff enough that when they go flat the tire doesn't sit down on the rim, the sidewalls hold it up a couple of inches.
So, the new tire is on and my HyperPro springs (my father's day gift) should be here tomorrow and I will have the springs mounted when they get here. |
 | Subject: Re: J. Costa Variator Mon Jun 22, 2009 8:07 am | |
| | The Scootist wrote: | Bernardo said: even when you hustle, you still get a good life out of your tyres...
Woah! Glad to read that you are OK and all went well despite the tyre blowing! I've not had a tyre blow out before, but rather have had the rear tyre run flat, and come off the rim...... That was scarey.... Fortunately I was going slowly so able to stop under control, and upright! Nice fathers day present by the way! I got a man sized space-hopper!! |
 | Subject: Re: J. Costa Variator Mon Jun 22, 2009 8:13 am | |
| Thanks Bernardo: I'm sure that luck played a big role in my outcome. If I had been going 85 mph (like I had that very morning), or If I was in a hard sweeping corner in the twisties, or IF it had been the front tire...
But it wasn't (this time) and I know that in the future, I shouldn't try quite so hard to squeeze every mile out of my tires.
Based on your reviews, I am looking forward to the new springs. And by the way, I liked your story about taking your father for a ride. We need to savor those moments. Very cool. Take care. David |
 | Subject: Re: J. Costa Variator Tue Jun 23, 2009 5:05 am | |
| Hi David, I've just had to buy a set of tyres for my bike.... I had forgooten how expensive they can be! I ended up getting "Maxxis" They were significantly cheaper and from the reviews I have read are as good as the competition. I hope to get them fitted tomorrow. I think they make sccot tyres too. It'll be interesting to read what you make of the springs! All the better with a new tyre, and better still with a michelin on the front (well at least I've found that the best set up for my S'wing) Glad you liked my write up..... Have just had a great day out to a local biker spot, will post something about it later. Happy riding! |
 | Subject: Re: J. Costa Variator Wed Jul 01, 2009 6:25 pm | |
| Installed it and the new belt tonight and went for a ride. All I can say is HOLY SH*#! I was expecting an improvement but nowhere near this much extra performance. My helper with the install has a brand new full bagger Harley Ultra Classic and he was even impressed with how fast it is now. We were screwing around kinda racing each other and he never pulled away from me at all. I don't know if he had anymore left in it but we did it several different times and he never pulled away like he used to be able to. Of course he won't come right out and admit it if I were to ask him being a Harley owner and all....LOL. I was kinda skeptical after reading the one guys post on here about how he didn't think it was worth the money, but I don't understand how he wasn't impressed with this thing???? Either his is defective, installed wrong, or he expected crotch rocket wheelie pulling performance. It is a scooter after all but it now impresses the heck out of me. I'm still grinning ear-to-ear. Enough of me rambling. If you want a mod and you wish you had a little more of a performance style bike instead of a scooter don't hesitate to do this mod, you'll be happy. I can assure you. If you just use it to run errands in town,and as a commuter, don't bother. |
|  | | dspevack Site Admin
Number of posts: 1037 Age: 47 Location: Miami, FL Points: 2367 Registration date: 2008-12-27
 | Subject: Re: J. Costa Variator Wed Jul 01, 2009 7:27 pm | |
| I think this should be J.Costa's tag line:
"J Costa...We keep Harley humble." :Santa : _________________ I ride on two wheels cause I feel very unsafe on one wheel.Dan in Miami. The king of custom! Check out my bike mods hereReality is irrelevant. Its perception that counts. Control people's perceptions, and you control their reality. |
|  | | DenGraham Scooter Rider
Number of posts: 65 Age: 64 Location: The Gardens RV Village, Crossville TN Points: 1161 Registration date: 2008-12-23
 | Subject: Re: J. Costa Variator Wed Jul 01, 2009 7:38 pm | |
| Som2002, Well said and I agree 100%. I really enjoy the difference and was just as perplexed as you with the one person that didn't see any difference. This winter I will change out the belt and put dry lubricant on the pins just to see if they last longer. But, I would not give up the improved performance for anything. Thanks for you post. |
|  | | mr fish Super Scooter Rider
Number of posts: 274 Location: uk Points: 1401 Registration date: 2009-03-23
 | Subject: Re: J. Costa Variator Thu Jul 02, 2009 3:19 am | |
| Im getting jelous now (need upgrades) cant stand the belt slap and vibrations any longer its driving me mad  p.s Scooterist glad your ok i had a blow out once fortunatly it was after i had hit the car when the bike flipped over the top  p.p.s i am wondering if i changed the rollers would this help with belt slap? (cheap option) |
 | Subject: Re: J. Costa Variator Thu Jul 02, 2009 5:47 am | |
| | mr fish wrote: | | p.p.s i am wondering if i changed the rollers would this help with belt slap? (cheap option) |
With the original OEM belt, the belt slap eventually disappeared with more time and wear. If you are looking for a cheap option, I was thinking of removing the cover and adding a dry lubricant to the upper and lower portions of the belt housing to reduce the belt slap ... I never did because the belt slap disappeared.
The Mitsuboshi Kevlar Belt from www.scootertrap.com never had any belt slap but that is a more expensive and permenant solution._________________ Bill - Georgetown TX 07 Silver Wing ABS Clearview w/vent, Givi E96/TB19/E52 with Admore Lighting, Alaskan Leather, Wrist Rests, 3M Solas tape, K&N air, Hyperpro spring, Grip Puppies, Airhawk, Utopia backrest, Stebel, Apexcone HIDs, StingerZ LEDs (w/Backoff WigWag), Knight Rider Sequential LED, NGK Iridium, Power Commander III, Manic Salamander, Saeng mirrors, Garmin Zumo 660, Dark-Side Sumitomo Tire  |
 | Subject: Re: J. Costa Variator Thu Jul 02, 2009 6:15 am | |
 | Subject: Re: J. Costa Variator Thu Jul 02, 2009 7:05 am | |
| Mr. Fish Thanks. I was pleasantly surprised how stable the bike felt after it blew, but I think I may have been lucky. If I had been going fast, or if I had been laid over in a curve, or if it had been the front tire, things may have been different.
From what I hear the J Costa should take care of that belt slap issue. Plus from a performance point of view, I totally agree with som2002. I think it made a huge difference in acceleration, but that is just me. Maybe I'm just easy to please. |
 | Subject: Re: J. Costa Variator Thu Jul 02, 2009 7:33 am | |
| Yes, I forgot to mention, belt slap that I have had the entire 16,000 miles is now totally gone. I was so excited about the performance aspect that I forgot to mention that little bonus side effect in my first post. LOL |
 | Subject: Re: J. Costa Variator Thu Jul 02, 2009 8:41 am | |
| | mr fish wrote: | Im getting jelous now (need upgrades) cant stand the belt slap and vibrations any longer its driving me mad
Bite the bullet and get a J costa fitted....It feels very different. The drivetrain is smoother, no belt slap, better acceleration, and its a bit noisier but in a good way, more of a sporty buzz to it than the quieter stock variator.....
As to the rollers I was gonna say ask Jeff, however he never had belt slap even with the stock variator and weights...
There is another homemade and cheaper option.... Take the stock weights and drill them out thus making them lighter.... That should improve you performance, although the economy may drop a tad. I don't think this will improve the belt slap though.... However I do know just how annoying it can be, it sure got to me until I had the J costa fitted... I meant to ask, how did the spill with the car go.... I take it this was a while ago, and clearly you lived to tell the tale.... Have been there myself a quite a few times though mostly as a teenager, and never over the top of a car! Hope it wasn't too painful! |
 | Subject: Re: J. Costa Variator Thu Jul 02, 2009 5:07 pm | |
| I feel i need to sweet talk the wife again for the j costa, as for the accident internal bruising hurt like hell but did it all again a week later on the insurance companys bike wrote that off as well they thought i had broken my neck with that one ,9 hours on a spine board about 15 xrays just to find out im a proffesional bouncer lol (witnesses said the the hight and flip was amazing and said i should take up gymnastics)so i learnt my lesson and bought a 1200 bandit had it tuned to about 140bhp then realised i have a family so sold that bought a gilera 180sp, and guess what......... wrote that off in the side of a van  ( signaled left but turned right) and they say bikes are dangerous yet i never seem to hit another bike its vans and cars that hurt, touch wood since then ive been learning how to ride to my ability and bikes ability |
|  | | JeffR Site Admin
 | Subject: Re: J. Costa Variator Thu Jul 02, 2009 9:32 pm | |
| Hi, I never had the belt slap with my SWing but it was brand new when I bought it and installed the J. Costa at about 4,000-5,000 miles, so maybe it just didn't slap. I have the sliders in now and I still don't get any belt slap, but I have the Mitsubishi belt now, so maybe that helps. I'm going to keep the sliders in for the rest of the year and maybe buy some new pins then and re-install the Costa. I just like to play with things. But the J. Costa is really a huge improvement and I do kind of miss the power and acceleration of it. The sliders seem to do good but you can really feel the power in the entire power band with the Costa. _________________ Ride safe, JeffR 2007 Silver Wing (30,000 miles) 2005 Majesty 400 (sold 12,500 miles) 2004 Reflex (sold 3,500 miles) Givi Windshield, top case, vista cruise, power commander, dr pulley sliders, air hawk seat pad, (J. Costa not installed now), kevlar belt  |
Similar topics |  |
| | Permissions in this forum: | You cannot reply to topics in this forum
