» New member from Europe
NOCO Genius Battery Tender I_icon_minitimeby steve_h80 Today at 4:47 am
NOCO Genius Battery Tender I_icon_minitimeby Loosemarbles Yesterday at 4:25 pm
NOCO Genius Battery Tender I_icon_minitimeby tedebr Tue Mar 26, 2024 10:56 pm
NOCO Genius Battery Tender I_icon_minitimeby zrx212 Tue Mar 26, 2024 1:19 pm
» What were they thinking?
NOCO Genius Battery Tender I_icon_minitimeby MikeO Tue Mar 26, 2024 5:57 am
» Hello everyone
NOCO Genius Battery Tender I_icon_minitimeby MikeO Tue Mar 26, 2024 5:54 am
» Sidelight Bulbs
NOCO Genius Battery Tender I_icon_minitimeby Green7 Mon Mar 25, 2024 5:25 pm
» Voyager trike kit forsale
NOCO Genius Battery Tender I_icon_minitimeby Mkdelay12@gmail.com Sun Mar 24, 2024 7:41 pm
» tiny oil leak
NOCO Genius Battery Tender I_icon_minitimeby Loosemarbles Sun Mar 24, 2024 1:41 pm
» Low charging
NOCO Genius Battery Tender I_icon_minitimeby yammer Sat Mar 23, 2024 1:49 pm
mike712
Number of posts : 95
Registration date : 2013-06-28
NOCO Genius Battery Tender Empty
PostSubject: NOCO Genius Battery Tender   NOCO Genius Battery Tender I_icon_minitimeFri Sep 18, 2015 12:20 pm
anyone ever heard of or used NOCO Battery tender?
oldgwingguy
Number of posts : 247
PostSubject: Re: NOCO Genius Battery Tender   NOCO Genius Battery Tender I_icon_minitimeFri Sep 18, 2015 2:58 pm
Who makes it? I'm more familiar with Battery Tender and Shumacker.
mike712
PostSubject: Re: NOCO Genius Battery Tender   NOCO Genius Battery Tender I_icon_minitimeFri Sep 18, 2015 3:18 pm
I saw it on amazon and it looked like it would do a good job. I went there to look for a "Battery Tender Jr."
oldgwingguy
PostSubject: Re: NOCO Genius Battery Tender   NOCO Genius Battery Tender I_icon_minitimeFri Sep 18, 2015 4:05 pm
I've used the BT on most everything from a bike to my tractors and in between, what I haven't see is the Battery Bug that monitors battery health.
Number of posts : 1981
PostSubject: Re: NOCO Genius Battery Tender   NOCO Genius Battery Tender I_icon_minitimeSat Sep 19, 2015 9:13 am
I have a Battery Tender Jr. for the battery in my SWing and 1974 Honda CB750. I also changed both batteries over to the Battery Tender Lithium Ion batteries. They are a lot lighter (1.75 Lbs) and a lot smaller. They come with dense foam pads of various thickness to fill up the empty space left over so the battery doesn't "flop" around in the compartment. Each pad has a self-stick tape on it to hold them in place on the battery. I can go out to the SWing and check the voltage and it's always been holding around 13.5 volts even after sitting for a week, which doesn't happen all that much in the summer. The CB750 doesn't have any drain on the battery like the SWing does so it holds at its max voltage with no problem. Over this coming winter I'll put the Battery Tender Jr. on the SWing about once a month to keep it ready for the two or three weeks of summer we have here in Minnesota. Razz So far I love the Lithium Ion batteries. They have plenty of power and work great. If memory serves they are 240 CCA batteries.
And a P.S. I talked to Battery Tender about using the Battery Tender Jr. on these batteries and they said it will work with no problems. They also have a Lithium Ion maintainer charger but seeing as my garage is attached to my home I can go out there once a month and put the Jr. on it every so often.
AldusFran
Number of posts : 201
PostSubject: Re: NOCO Genius Battery Tender   NOCO Genius Battery Tender I_icon_minitimeTue Sep 22, 2015 11:57 am
I have both the Battery Tender Junior and a Schumacher Companion. The Tender Junior is rated at .75 amps and the Schumacher 1.5 amps. For the price at Walmart I would go with the Schumacher . The Schumacher model is called a different name now but it's still $22.50 at Walmart with Walmart's guarantee on return.
Number of posts : 3291
PostSubject: Re: NOCO Genius Battery Tender   NOCO Genius Battery Tender I_icon_minitimeWed Sep 23, 2015 12:35 pm
I ride my SilverWing everyday and do not need to monkey with battery tender......never have.
» Battery Tender or Battery Tender Jr.
» Battery Tender Jr.
» Battery Tender Plug
» Deltran Battery Tender Jr - Question
» Battery Tender volt checker...
