| Givi cover hinges | |
+6Cosmic_Jumper model28a Meldrew NWSSC Cookie tinman 10 posters |
Number of posts : 1298 Age : 75 Location : Matheson, Ontario, Canada Points : 5891 Registration date : 2011-11-29
Cookie Super Scooter Rider
Number of posts : 233 Location : Essex UK Points : 4807 Registration date : 2011-10-03
| Subject: Re: Givi cover hinges Wed Sep 09, 2015 10:34 am | |
| Can you post a photo of the offending parts? It might make suggestions easier. Thanks |
NWSSC Silver Wing Rider
Number of posts : 418 Age : 86 Location : Mt Prospect IL 30 miles west of Chicago Points : 5610 Registration date : 2010-03-03
| Subject: Givi cover hinges Wed Sep 09, 2015 11:49 am | |
| If you could be a little more descriptive (pictures-model) it would help with your concern. As you know there are many different styles of GIVI systems. I also have a large GIVI top box(Monokey system)and it appears that the hinges are molded into the unite. I'm sure someone here has had a similar problem. Howard |
| Subject: Re: Givi cover hinges Wed Sep 09, 2015 12:16 pm | |
| Modle 55 maxim, the metal hinges that holds the lid open to access the box.the screws fall out constantly ,Epoxy won't hold the screws in place. |
Number of posts : 4170 Location : York, North Yorkshire, England UK Points : 9159 Registration date : 2010-11-16
| Subject: Re: Givi cover hinges Wed Sep 09, 2015 1:01 pm | |
| I've had a Givi E55 Maxia Stealth top box on the back of my Silver Wing for nearly 5 years now, and after reading your post I've just been and checked the twin lid hinges on mine. They look and work like new. They hold the lid open and the little cross head screws holding the hinges onto the box and lid are tight and secure. |
| Subject: Givi cover hinges Wed Sep 09, 2015 2:54 pm | |
| I would also suggest doing a search on line. Seems GIVI is good about standing behind there products. Howard |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7319 Registration date : 2010-02-03
| Subject: Re: Givi cover hinges Wed Sep 09, 2015 2:57 pm | |
| Just a thought, have you tried Loctite or any other thread thread locker? |
| Subject: Re: Givi cover hinges Wed Sep 09, 2015 3:59 pm | |
| Did you contact Givi about the problem?
If you are referring to the hinge-to-case screws coming loose from the case body or the case lid then possibly you could use larger screws. I'm offering that suggestion having no idea what your Givi hinge looks like.
As others have suggested a photo of the hinge/case would help.
| Subject: Re: Givi cover hinges Wed Sep 09, 2015 4:26 pm | |
| Sorry I don't no how to post pics. I have a Mack book ,and I never looked at a computer before I join this forum.I will try a larger screw if I can fin one 3\8 " long one If things don't work out.The place where I purchase the Givi box is no longer in business ( pass warranty ) Don't know hoo to contact in Canada. |
| Subject: Re: Givi cover hinges Wed Sep 09, 2015 4:50 pm | |
| How about www.givi.ca It lists all the dealers in various parts of Ontario and the importer for Canada. Get a move on it's almost winter eh! |
hotwings Silver Wing Expert
Number of posts : 876 Age : 53 Location : Ontario Points : 5327 Registration date : 2012-04-29
| Subject: Re: Givi cover hinges Wed Sep 09, 2015 6:37 pm | |
| The Kappa model wouldn't have these problems . |
| Subject: Re: Givi cover hinges Wed Sep 09, 2015 7:24 pm | |
| Subject: Re: Givi cover hinges Thu Sep 10, 2015 4:24 am | |
| Paying $800 for the same Givi kit that we can buy in the UK for about $530 is even funnier. |
| Subject: Re: Givi cover hinges Thu Sep 10, 2015 6:05 am | |
| Meldrew,the Givi 55 cost about $ 500.00 add brake lights about $190.00 ,and the mounting brackets $ 150.00. + taxes .Nothing's cheap in the North. The Hyper pro spring that i purchase this spring was double the cost of the retail price by the time it got to me.Count yourself lucky, the UK wind knee deflector was $300. Bling is bling . I sent a email to Givi .ca.but I don't xspect much to come out of it. |
| Subject: Re: Givi cover hinges Thu Sep 10, 2015 6:32 am | |
| - Meldrew wrote:
- Paying $800 for the same Givi kit that we can buy in the UK for about $530 is even funnier.
Paying $530 for a Givi with issues instead of a Bestem for a $100 without issues is even funnier still . |
| Subject: Re: Givi cover hinges Thu Sep 10, 2015 6:36 am | |
| I've been over to the U.S. four times since I've had my Silver Wing and I'd have visited Canada too if I hadn't had a stroke. I still think of the poutine I was going to enjoy in Toronto. I've since eaten Glaspoutine in a burger joint in Glasgow, Scotland, that's poutine with melted Scottish Mature Cheddar on top and it's good stuff. I've often thought that on these trips I should bring a pair of Silver Wing wind deflectors over in my luggage for someone who wants a set. |
| Subject: Re: Givi cover hinges Thu Sep 10, 2015 6:57 am | |
| - hotwings wrote:
Paying $530 for a Givi with issues instead of a Bestem for a $100 without issues is even funnier still . Who over here would buy Bestem from the U.S. with all the hassle of import duties and taxes when we have the choice of European makes like Givi, Kappa, Shad, Krauser, SW-Motech, Trax, Hepco & Becker etc with no import duty and a good € to £ exchange rate. The largest Bestem box is a measly 46 litres which is useless for my needs and they're styled like the Givi boxes of 20 years ago. Bestem may even be the Honda branded top box that seems to be fitted to most of the used Silver Wings and Deauvilles for sale over here. I can also buy Coocase top boxes at a bikers hang out about a 30 minute ride from home. I had a quick look at one of their boxes there a couple of years ago, I'll stick with Givi.
| Subject: Re: Givi cover hinges Thu Sep 10, 2015 9:25 am | |
| At the time of my purchase the Bestem and other makes where not known to me ,and the Givi box was the talk of the forum .Other then the lid screws coming off the givi maxia works well. |
| Subject: Re: Givi cover hinges Thu Sep 10, 2015 10:13 am | |
| Just received email from Givi.ca,and was told that these hinges were discontinued and now are using stop ropes to hold the lid open. That might be an option if the problems persist . |
Deno070 Maxi-Scooter Rider
Number of posts : 121 Age : 50 Location : usa, nj Points : 3904 Registration date : 2013-12-06
| Subject: Re: Givi cover hinges Thu Sep 10, 2015 3:30 pm | |
| Just order the new hinges. The problem doesn't appear like it will miraculously fix it self. Save your self the aggravation. |
| Subject: Re: Givi cover hinges Thu Sep 10, 2015 3:59 pm | |
cerve137 Scooter Rider
Number of posts : 20 Points : 4776 Registration date : 2011-03-26
| Subject: Re: Givi cover hinges Fri Sep 11, 2015 5:54 pm | |
| I had the same problem with my e55 maxia 3. I figured out if you push at the pivot of the hinge towards the front of the bike it locks out the hinge and the top lid won't fall. I think twisted throttle could order the new rubber straps, but they were like $80 plus shipping. |
| Subject: Re: Givi cover hinges Sat Sep 12, 2015 12:43 am | |
| Meldrew said, "...I can also buy Coocase top boxes at a bikers hang out about a 30 minute ride from home. I had a quick look at one of their boxes there a couple of years ago, I'll stick with Givi..."
I put a Coocase on my first Silverwing and switched it to a B650 after I sold the SW. It was a good solid case, the remote keyless entry was kind of cool as was the alarm though it could have been louder. The tiny LED brake lights on the box didn't show up much in daylight though. Not quite up to Givi but not near the price either. |
| Subject: Re: Givi cover hinges | |
