» Givi windshield
by "Hi Yo" Today at 1:03 am
» heavier duty front springs for swing
by Waspie Today at 12:46 am
» Windshield
by Waspie Today at 12:43 am
» Auxiliary Front Lights - Advice Wanted
by tarmacburner2 Today at 12:39 am
» Run to LaPorte
by JeffR_ Yesterday at 9:54 pm
» 2012 Honda-Integra-NC-700-ABS-DCT Review
by JeffR_ Yesterday at 9:52 pm
» UK ride posting
by RArch Yesterday at 2:42 pm
» US Motorcycle Magazine came in the mail today.
by john grinsel Yesterday at 1:12 pm
» Does anyone have the Side Case Attachments on SW 600
by bigbird Yesterday at 11:27 am
» Corbin Seat More Leg Room
by larryinseattle Wed May 23, 2012 11:31 pm
» Stock seat mods
by crahar Wed May 23, 2012 9:24 pm
» Givi Windshield Installation Pictorial
by "Hi Yo" Wed May 23, 2012 8:35 pm
 Final Drive Oil
Goto page : Previous  1, 2
JeffR_
Number of posts: 344
Registration date: 2010-05-12
PostSubject: Re: Final Drive Oil   Sun May 29, 2011 3:37 pm
The final drive holds 10 oz of oil. Just keep filling it until it starts to seep back out and you know you have just enough.
_________________
Ride Safe,
JeffR_
Givi Airflow, Dr Pulley Sliders (28gr), Power Commander, Air Hawk, K&N Filter
2007 Silver Wing 34,000 miles
2005 Majesty (sold) 12,500 miles
2004 Reflex (sold) 3,500 miles
Tagg
Number of posts: 439
Registration date: 2010-11-14
PostSubject: Re: Final Drive Oil   Sun May 29, 2011 5:07 pm
My manual transmission Ford Ranger 5 speed takes, wait for it . . . . . . . . . . . . . automatic transmission fluid. Because its thinner than gear oil, and does the same thing. I made the mistake of putting gear oil in it and it was sluggish, it was taking to much of what little power it had to slog through the molasses of the thick oil. Im guessing that is why Honda wants you to use motor oil, makes sense to me.
I put amsoil 10/40 synth in the gear case, and i will probably never have to mess with it again.
Slick-Tenn
Number of posts: 47
Registration date: 2010-07-19
PostSubject: Re: Final Drive Oil   Sun Sep 04, 2011 2:11 pm
chieninhouston wrote:
Spent sometimes reading the owner's manual of my 2008 Swing. Not able to find the recommended oil, the changing intervals, and the quantity required for the final drive.
I understand this question may have been asked a lot. But this poor soul really wanted to know. Thank you.
Sorry! Honda just won't convince me that 10W30 motor oil will do the job lubricating gears! I use nothing but Amsoil 80W90 synthetic gear oil. Your transmission will thank you!
Number of posts: 2165
Registration date: 2010-05-02
PostSubject: Re: Final Drive Oil   Sun Sep 04, 2011 2:17 pm
Watch out on this one and don't second guess Honda. Some seals in the final drive do not tolerate the additives found in gear oil. That's why they recommend a JASO MA oil for final drive.
http://silverwing600tech.proboards.com/index.cgi
PostSubject: Re: Final Drive Oil   Mon Sep 05, 2011 8:16 am
bigbird wrote:
I use a synthetic 75W-90 gear oil. The service manual suggests good old Honda 10W-30 engine oil which supposedly has a JASO MA rating. Since we're only dealing with GEARS here, and not combustion, I'll continue using a GEAR oil.
I changed my mind on this shortly after posting this in July of 2010. I had read that seals in the final drive may not be compatible with gear oil. Not knowing if that was fact or fiction, I decided to go with mother Honda's recommendation of JASO-MA oil in the final drive. I switched over to the same crankcase oil I use, Shell Rotella T6 5W-40.
I hope this rectifies any inconsistencies in my posts.
PostSubject: Re: Final Drive Oil   Thu Sep 22, 2011 3:53 pm
An explanation from a moderator on a Honda SH150i forum.
He is an industrial mechanic with expertise in hydraulics, machining, and welding. He knows what he's talking about. To quote:
"Synthetic gear oil usually contains a lot of additives to stabilize the viscosity index, these additives are solvent like and may eat the seals , cause them to swell or dissolve the plasticizer in the elastomer after which the elastomer of the seal becomes brittle ,forms cracks and start to leak.
Its like soaking the seal in paint thinner.
Its a problem which also occurred with the first generations of synthetic motoroils but in motoroil this problem has been mostly cured.
In gear oil this problem is more difficult to solve although latest generation gear oil may not have this problem anymore.
However: the use of synthetic gear oil in a normal (non race)application is only beneficial on one or two points: increased interval for changing the oil and a more "flat" viscosity index meaning the oil stays better on the same level of viscosity regardless of temperature.
Point one: changing the gear oil is really not more then 3 minutes of work and one liter of oil will give you about 5 oil replacements so also on the financial side changing the gear oil is of almost no impact.
Cost and effort are so low that i change the gear oil at the same interval as motoroil.
Point two: a better viscosity index; the gearbox only has 4 gear wheels on two axles and both axles run on ball bearings.
The effect of a better viscosity index in such a small gearbox is negligibly, its not a high tech 6 speed slipper clutch gearbox and i assume you dont drive anywhere near the pole circle/Antarctica.
Above 15 degrees C the problem of thick gear oil is almost non existing
So why take the risk of broken seals?....
Throwing the bottle in the garbage is a bit over the top but next bottle you buy you may want to reconsider the perceived holy grail of synthetic oil, its not all that fabulous,there are drawbacks to synthetic motor oil."
DaveR
Number of posts: 219
Registration date: 2009-02-19
PostSubject: Re: Final Drive Oil   Thu Sep 22, 2011 8:03 pm
Never doubt what Honda tells us to do in the owners manual and maintenance manual. They know what they are doing so don't try to second guess them with all of your own ideas. It will only lead to problems and costly ones at that.
Old Dave in Western Nebraska
RickV
Number of posts: 38
Registration date: 2010-11-28
PostSubject: Re: Final Drive Oil   Sun Nov 06, 2011 11:39 am
Just a note on my drive oil experience.
My 2002 SW Service Manual recommends the Honda GN-4 10W-40 - pg 3-16 - no surprise there.
My 2002 SW has experienced vibration starting out and the corresponding plastic vibration - new belt and 16K service performed at 12K this Spring and given clean bill of health.
After reading this post of drive oil, took off covers and looked at belt and such - almost no dust inside from this years riding and all looked OK -decided to check the drive oil and it didn't look right to me [changed last year and used Honda GN-4 10W-40 - about 3k miles ago]. Drained the oil and it appeared like it had broken down - following Big Bird I used my Shell Rotella T 15W-40 JASO-MA oil for the refill.
Can't explain it but the vibration has all but disappeared and much much smoother starting out - will monitor next Spring again because riding will end shortly here. I do intend to shorten my drive oil maintenance intervals which is listed as every 2 years.
I am much happier with my SW and been riding it more than my Scarabeo now.
Rick V
PostSubject: Re: Final Drive Oil   Sun Nov 06, 2011 11:49 am
Hi Rick.
Like you, my riding has now ended for the season unfortunately.
My take on your experience is that the final drive oil type/condition should really have no influence on vibration. The oil only lubricates the 2 gears transferring power 90 degrees from the clutch output shaft to the rear wheel and their bearings.
My guess is that when you disassembled the final drive covers and cleaned the belt air filter you may have moved the belt, or covers, or something that changed the belt's path so it is no longer slapping the aluminum cover case. By any chance did you take off the aluminum drive cover and remove the belt, or take apart the variator? By your description I doubt if you did, but something as simple as incorrectly tightening the belt covers by using the wrong bolt holes, or misaligning something could affect the belt slap.
BTW, I am running Rotella T6 5W-40 in both my crankcase and final drive, as well as in my lawnmower and snowblower Smile
RickV
Number of posts: 38
PostSubject: Re: Final Drive Oil   Sun Nov 06, 2011 12:06 pm
Big Bird,
I agree totally - changing the drive oil should not have changed anything with the clutch or belt - I did take off the aluminum drive cover to expose the belt and have done so about 4 times before - there is evidence of belt slap on the bottom of that cover and was the first time so don't know if new belt is flexing that much - I was slightly surprised that there was virtually no belt dust inside. Put everything back together as I have in the past.
Also, performed oil and filter change - replaced Castrol 10W-40 Synthetic with Valvoline 10W-40 4T Motorcycle oil which has the JASO-MA standard. The Castrol was the previous owners recommendation but always thought there was a little excessive engine noise though no oil usage. Believe the engine has quieted down a bit so happy there and about having better high rpm valve protection.
BTW, still riding here in MN - in 50's yesterday; was out last Saturday with morning temp at 30 but with sunshine. Not ready to put the scoots away just yet.
Rick V
PostSubject: Re: Final Drive Oil   Sun Nov 06, 2011 12:09 pm
Rick V
Nice. It's warm up here this afternoon (50's also) but temp falling below freezing tonight with snow. I winterized my Swing last week.
I won't be doing any riding for another 20+ weeks ( early April if lucky).
Final Drive Oil
Page 2 of 2Goto page : Previous  1, 2
» F.A Cup Final - Bin Dippers VS Chelski
» UEFA Europe League 1/2 Final
» Coppa Italia Final Tonight
» UNI QLO First Drive-in Store Opens May 26 in SHANGHAI
» [Single] "TEST DRIVE" Jin Akanishi
