» New member from Europe
gear oil change I_icon_minitimeby steve_h80 Today at 4:47 am
gear oil change I_icon_minitimeby Loosemarbles Yesterday at 4:25 pm
gear oil change I_icon_minitimeby tedebr Tue Mar 26, 2024 10:56 pm
gear oil change I_icon_minitimeby zrx212 Tue Mar 26, 2024 1:19 pm
» What were they thinking?
gear oil change I_icon_minitimeby MikeO Tue Mar 26, 2024 5:57 am
» Hello everyone
gear oil change I_icon_minitimeby MikeO Tue Mar 26, 2024 5:54 am
» Sidelight Bulbs
gear oil change I_icon_minitimeby Green7 Mon Mar 25, 2024 5:25 pm
» Voyager trike kit forsale
gear oil change I_icon_minitimeby Mkdelay12@gmail.com Sun Mar 24, 2024 7:41 pm
» tiny oil leak
gear oil change I_icon_minitimeby Loosemarbles Sun Mar 24, 2024 1:41 pm
» Low charging
gear oil change I_icon_minitimeby yammer Sat Mar 23, 2024 1:49 pm
 gear oil change
2 posters
AldusFran
Number of posts : 201
gear oil change Empty
PostSubject: gear oil change   gear oil change I_icon_minitimeSun Aug 09, 2015 7:35 pm
I don't know why people are having such a hard time doing rear gear oil changes. Here it goes. Take you scoot for a little ten minute ride. Put bike on center stand and remove the two outer cases (maybe five minutes) now you are looking at the fill plug. Put a couple news papers under the drain plug. Take off the filler pug and put a drain pan under the drain plug and remove plug. Get an empty gear lube plastic bottle with the tapered tip and put in about one pint motor oil. leaving off your drain pug give the plastic bottle a nice squeeze and wait until the oil looks clean coming out of the drain plug hole. Soon as the oil looks clean install drain plug and now continue to fill rear case (.34 quart) .when oil starts coming out ,wait a few minutes until oil stops coming out and reinstall filler plug. Now you can clean outer case filter and covers. Bingo neat and clean.
PostSubject: Re: gear oil change   gear oil change I_icon_minitimeSun Aug 09, 2015 8:24 pm
That sounds like a good way to clean everything out, thank you for the tip. I guess I've been lucky every time I've drained mine the oil that came out looked just as clean as what I put in.
Topic moved from Introductions to Maintenance, Tips and Hints by Mod.
gear oil change
» oil change erronious washer change
» What if I overfill the gear oil?
» New Enough - Motorcycle Gear
» Which rain gear?
» LDComfort gear
