» drive belts
Hot wire for gps I_icon_minitimeby Loosemarbles Yesterday at 5:43 pm
» New member from Europe
Hot wire for gps I_icon_minitimeby alex_at Yesterday at 3:55 pm
Hot wire for gps I_icon_minitimeby alex_at Yesterday at 3:54 pm
Hot wire for gps I_icon_minitimeby tedebr Tue Mar 26, 2024 10:56 pm
Hot wire for gps I_icon_minitimeby zrx212 Tue Mar 26, 2024 1:19 pm
» What were they thinking?
Hot wire for gps I_icon_minitimeby MikeO Tue Mar 26, 2024 5:57 am
» Hello everyone
Hot wire for gps I_icon_minitimeby MikeO Tue Mar 26, 2024 5:54 am
» Sidelight Bulbs
Hot wire for gps I_icon_minitimeby Green7 Mon Mar 25, 2024 5:25 pm
» Voyager trike kit forsale
Hot wire for gps I_icon_minitimeby Mkdelay12@gmail.com Sun Mar 24, 2024 7:41 pm
» tiny oil leak
Hot wire for gps I_icon_minitimeby Loosemarbles Sun Mar 24, 2024 1:41 pm
 Hot wire for gps
4 posters
hardee41
hardee41
Number of posts : 80
Registration date : 2013-07-23
Hot wire for gps Empty
PostSubject: Hot wire for gps   Hot wire for gps I_icon_minitimeMon May 11, 2015 2:07 pm
I have a mount for gps and was wondering about tapping into a wire that runs along the lt. handlebar; maybe the horn wire. I could then run it into glove-box etc. harley k
NWSSC
NWSSC
Number of posts : 418
PostSubject: Hot wire for gps   Hot wire for gps I_icon_minitimeMon May 11, 2015 2:58 pm
I can not tell you the color of the wire (it has been a few years) but if you remove the cover below the wind screen(four screws) you will find a main connector with several wires. I found one that was live with the key off and spliced a fuse connector(1.5 amps) in the line and ran it to the steering column and under the left handle bar cover to my Garman. I elected to have power to my gps at all times,this is not right or wrong but just my preference and it works for me.
I recommend you solder all connections and be careful runing the wiring. Hope this helps you. Howard
Number of posts : 1981
PostSubject: Re: Hot wire for gps   Hot wire for gps I_icon_minitimeMon May 11, 2015 4:48 pm
My GPS is an old cell phone and a Ram mount. It looks a bit off seeing as I stood off to the side a bit so the flash wouldn't wash it all out. It works pretty good now all I have to do is put a card in the phone to load up with songs and get a blue tooth speaker system that I can mount somewhere on the dash easily and I'll be good to go.
Hot wire for gps Phone_10
PostSubject: Re: Hot wire for gps   Hot wire for gps I_icon_minitimeMon May 11, 2015 8:07 pm
I took the right cubby out and found a hot wire, taped into it using a Posi-tap Posi-tap Connectors and a
Direct USB Hardwire Car Charger Cable Kit for Garmin GPS Then I put the cubby back in. If I need to get at the wiring all I need to remove is the cubby and the wires are right there. My garage door opener is taped in there too.
Hot wire for gps
» can some one tell me how to wire in a wig wag
» live wire
» Power wire
» Brake Light Attention Module Flasher (adjustable)
» Left glove box wire hiding
