| Would this be bad form? | |
+5Mudnman Chilliwing model28a MikeO SilverwingInIdaho 9 posters |
SilverwingInIdaho Maxi-Scooter Rider
Number of posts : 155 Points : 4805 Registration date : 2011-08-23
| Subject: Would this be bad form? Thu Aug 14, 2014 4:10 pm | |
| Would it be bad form if I bought the Drive belt I need to replace for 50 dollars less then the shop wants and hand it to them when I bring it in for the swap?
Mike |
Number of posts : 3783 Age : 74 Location : Seaham, Co Durham, UK Points : 9414 Registration date : 2009-06-29
| Subject: Re: Would this be bad form? Thu Aug 14, 2014 4:40 pm | |
| Depends how well you know the shop! |
Number of posts : 2085 Age : 71 Location : St.Pete.FL. Points : 7320 Registration date : 2010-02-03
| Subject: Re: Would this be bad form? Thu Aug 14, 2014 4:53 pm | |
| Is it a Honda dealer or an independent shop? If it's an independent shop I think it would save him the hassle of getting a belt. If it is a Honda dealer they may match the price if you ask them. |
| Subject: Re: Would this be bad form? Thu Aug 14, 2014 4:58 pm | |
| Well they sell Honda, suzuki and BMW among others so I don't know. I don;t know them that well but I bought the used silver wing there. |
| Subject: Re: Would this be bad form? Thu Aug 14, 2014 5:05 pm | |
| Marking-up the parts they supply and fit may be the difference for them between profit and loss. I don't think you'd be doing yourself any favours with them if you supply your own parts unless you know them well and have a good relationship with them - in which case it's something you'd probably have discussed with them in the past. |
Chilliwing Maxi-Scooter Rider
Number of posts : 146 Age : 68 Location : Chilliwack, British Columbia, Canada Points : 4762 Registration date : 2011-09-03
| Subject: Re: Would this be bad form? Thu Aug 14, 2014 5:15 pm | |
| I suspect shop's don't mind you bringing them parts, they just increase the labour to make up for the loss. |
| Subject: Re: Would this be bad form? Thu Aug 14, 2014 5:53 pm | |
| You could ask them in advance if it would matter to them. |
Mudnman Super Scooter Rider
Number of posts : 218 Location : Florida Points : 3968 Registration date : 2014-01-15
| Subject: Re: Would this be bad form? Thu Aug 14, 2014 9:13 pm | |
| I'd do it! Say here put my spare belt on.So they only make there hourly rate.Big deal. |
Number of posts : 109 Age : 77 Location : Sedro Woolley ,WA Points : 3696 Registration date : 2014-06-12
bjkaraoke Scooter Rider
Number of posts : 21 Age : 67 Location : Austin Points : 3705 Registration date : 2014-03-08
| Subject: Re: Would this be bad form? Fri Aug 15, 2014 2:17 pm | |
| if you have to change the belt,I would go ahead and but in new rollers if you havent changed over to Dr Pulley 28 gm. Tokk me all of an hour to do the belt change and rollers |
| Subject: Re: Would this be bad form? Fri Aug 15, 2014 5:09 pm | |
| You need to look through some posts on Dr Pulley sliders verses rollers and makeup your own mind what would fit your needs. Myself I would go with Dr Pulley sliders 24gm or at most 26gm. As you can see what I prefer and what bjkaraoke prefers are two different things. Here is a link to read up on Dr Pulley sliders |
| Subject: Re: Would this be bad form? Tue Aug 19, 2014 5:46 am | |
| Reason I don't do it myself is because there is some strange noise coming from the rear of the bike on acceleration. It sounds like two flat pieces of precision milled metal being rubbed together as part of the drive mechanism. Impossible to describe the sound. The Mention of rollers sounds plausible. Anyway I figure they will find the problem when changing the belt. |
How much do new rollers cost? I have a feeling they need to be replaced or should anyway.
| Subject: Re: Would this be bad form? Tue Aug 19, 2014 4:53 pm | |
| I Googled(link below)it and found a lot of information, see if it is any help. If not any on line parts house should help. rollers for Honda Silverwing |
| Subject: Re: Would this be bad form? Tue Aug 19, 2014 6:03 pm | |
| Great Rollers run about 50 bucks which means I'll get to pay 100 over the 300 dollar repair bill I am currently facing. |
| Subject: Re: Would this be bad form? Tue Aug 19, 2014 9:08 pm | |
| They won't check the rollers while changing the belt unless they are told to. |
| Subject: Re: Would this be bad form? Wed Aug 20, 2014 1:34 am | |
| - kreiseldave wrote:
- They won't check the rollers while changing the belt unless they are told to.
I'm afraid I would find a different shop to do my work if I couldn't trust them to check the rollers when servicing and diagnosing the drive line. The OP said he is bringing it to the shop because he can't diagnose the problem himself. |
Number of posts : 1298 Age : 75 Location : Matheson, Ontario, Canada Points : 5892 Registration date : 2011-11-29
| Subject: Re: Would this be bad form? Wed Aug 20, 2014 7:40 am | |
| Partsfish.com rollers are $19.63, shipping in the US would be about $5.00. You may have a dried bearing in the driven clutch ,lock up rear wheel and remove the nut at the end of the clutch and slide it off ,inside there is a bearing that will make a whining noise when the bearing is dry. Easy fix. |
jmaslak Super Scooter Rider
Number of posts : 252 Location : Golden, CO, USA Points : 4572 Registration date : 2012-06-15
| Subject: Re: Would this be bad form? Wed Aug 20, 2014 7:27 pm | |
| Just say you keep a spare belt, so you want them to use that belt, and you want your old one back so you still have a spare. I can't imagine them having a problem, but if they really want you to buy their parts, I'm sure they'll tell you. |
| Subject: Re: Would this be bad form? | |
