Welcome to the home for Honda SilverWing and everyone interested. This is a place to ask questions, share, and learn about the SilverWing and its dedicated riders. Please post an introduction when you join as a sign of Courtesy.
» New(er) Silverwing FJS600 D9
by Cosmic_Jumper Today at 11:48 am
» The best hot weather shirt I've found
by Dale N. Today at 10:43 am
» My First Ride of the Season
by Dale N. Today at 10:41 am
» Windshield woes?
by Meldrew Today at 6:32 am
» Fuel gauge anomaly
by Dale N. Yesterday at 10:14 pm
» A service manual! Please
by Easyrider Yesterday at 9:39 pm
» Air Hawk R seat pad
by Easyrider Yesterday at 9:13 pm
» Body panel rattling
by Mike from NS Yesterday at 1:24 pm
» My other ride
by janitorj1 Yesterday at 7:41 am
» Hello again...
by Tcrichard Fri Feb 16, 2018 11:09 am
 S/W transmission special tools
NWSSC
avatar
Number of posts : 419
PostSubject: S/W transmission special tools   Thu Jul 17, 2014 4:22 pm
I have not tried to order from Honda,but does any one have or know the source for the tools to R/R the transmission clutch drum.
Page 10-10 of the Service Manual. Thank you. Howard
avatar
Number of posts : 2539
PostSubject: Re: S/W transmission special tools   Thu Jul 17, 2014 6:11 pm
A couple of members here have been able to remove the clutch bell using a long arm (6-8") three arm gear puller. Dunno if he's still active on this forum, but ToolBoxJesse figured that trick out. You might search the archives for that info.
NWSSC
avatar
PostSubject: Re: S/W transmission special tools   Thu Jul 17, 2014 7:03 pm
Thanks for the reply Tim.My real concern is installing the clutch drum back on the shaft. I understand the drum is not extremely tight (for that reason it is retained by a snap ring ) but if you have to tap it back on you are putting strain on the center of the bearing behind it and this is not good.The reason for disassemble is a bearing noise.I think my long trips with heavy loads has taken it's toll. If some one has removed the drum I would like to know how difficult it was to reinstall. Thanks again. Howard
Mudnman
Number of posts : 219
Registration date : 2014-01-15
PostSubject: Re: S/W transmission special tools   Thu Jul 17, 2014 8:17 pm
I seen a vid on YouTube.I'm going off hit in head memory (lol) With the real tool it was as easy as turning a wrench.I might have seen or posted the vid here.I'll have a look see.
Mudnman
PostSubject: Re: S/W transmission special tools   Thu Jul 17, 2014 9:27 pm
Here it is.
http://m.youtube.com/watch?v=yJqXC7QoaA4
avatar
PostSubject: Re: S/W transmission special tools   Thu Jul 17, 2014 10:31 pm
Use a ~8 inch section of 1 1/2" PVC, a stack of washers and the clutch nut to 'press' the clutch bell on the shaft. PITA, but it works.
