tankyuong Silver Wing Rider
Number of posts : 475 Age : 49 Location : Missouri Points : 6081 Registration date : 2009-07-12
| Subject: using a motorcycle jack Wed Jul 15, 2009 8:20 pm | |
| Is there a certain place to place the motorcycle jack on the swing?Too much tupperware underneath. |
jdeereanton Silver Wing Guru
Number of posts : 1995 Age : 76 Location : Huntsville, AL Points : 7665 Registration date : 2008-12-24
| Subject: Re: using a motorcycle jack Sun Jul 19, 2009 11:42 am | |
| tankyuong,
Did you get an answer to this question?
I have lifted the front and used blocking materials placed under the front edge of the fairing of the scoot to keep it in the air and remove/replace the front wheel.
As always the center stand should be down and the bike supported so it will not fall over. |
| Subject: Re: using a motorcycle jack Mon Jul 20, 2009 3:26 am | |
| Thanks for the reply jdeer, I heard you can use a piece of wood. |
mr fish Super Scooter Rider
Number of posts : 276 Location : uk Points : 5863 Registration date : 2009-03-23
| Subject: Re: using a motorcycle jack Mon Jul 20, 2009 8:27 am | |
| I used a jack with a block of wood when i did the bearings (with the center stand down) |
| Subject: Re: using a motorcycle jack | |
