| | Duct tape on a Swing !!! | |
cotetoi Silver Wing Expert
Number of posts : 757 Location : New Brunswick, Canada Points : 4847 Registration date : 2013-06-27
| Subject: Duct tape on a Swing !!! Fri Oct 11, 2013 6:22 pm | |
| I was getting very annoyed with the rattle and buzz whenever I slowed down to about 50 kmh. The rattle would diminish and sometimes stop if I squeezed the handlebar cover. So, I took the cover off this afternoon, and found nothing under there that could cause the noise. Everything looks soft; except for the tabs and metal inserts that hold the two pieces together. I got the idea to tape the metal inserts with some duck tape. I tried the bike up and down my street, and that rattle and buzz is gone. But there are others in other places on the bike !! Space Age material to the rescue. I also did temporary repairs on a couple of cracks at the very bottom of the right skirt fender. The tab with metal insert was broken, but with all the pieces still there, crazy glue and duck tape to the rescue. Most of the tape is on the inside, so the repair looks quite good. When it doesn't: new tupperware. |
Number of posts : 4416 Age : 81 Location : damn near Philadelphia, PA Points : 10531 Registration date : 2009-06-12
| Subject: Re: Duct tape on a Swing !!! Fri Oct 11, 2013 7:32 pm | |
| Ah ha! Duct Tape, Red Green's secret weapon.
BTW Crazy glue probably won't hold too long, but if you can get hold of a small can of ABS plastic plumbing pipe cement (glue) and some fiber glass drywall tape you can repair the cracks, etc from the inside. Be sure that you sand off the old paint & stuff from the area where you want the cement to adhere to. And be sure that you use ABS-only cement, PVC or PVC/ABS cement wont work.
Acetone (nail polish remover) might also work initially as it melts the ABS body work and might help fuse it together --but without any additional support. Use it sparingly though as it will weep into the crack and end up melting the paint on the outside of the panel.
Number of posts : 2940 Age : 75 Location : Winnsboro, Texas, U.S.A. Points : 8341 Registration date : 2010-02-17
| Subject: Re: Duct tape on a Swing !!! Fri Oct 11, 2013 8:52 pm | |
| Ah, duct tape, Sometimes called Oklahoma Chrome. |
| | | exavid Silver Wing Guru
Number of posts : 2658 Age : 81 Location : Medford, Oregon Points : 8181 Registration date : 2009-07-17
| Subject: Re: Duct tape on a Swing !!! Sun Oct 13, 2013 12:05 am | |
| ABS cement does work well on the Honda ABS plastic you get a chemical weld instead of simple surface adhesion. Much stronger than any epoxy based adhesive and cheaper as well as easier to use. One thing to be careful about is if you need a thick build up for reinforcement do it with several thing coats. A thick coat will take forever to dry since it will skin over before all the solvents have evaporated. I've repaired a lot of Goldwing parts and a couple SW parts in my old shop and never had one come back. |
| | | pauldeere Scooter Rider
Number of posts : 19 Location : SW ohio Points : 3890 Registration date : 2013-09-19
| Subject: Re: Duct tape on a Swing !!! Wed Oct 16, 2013 5:41 pm | |
| I also have a annoying buzz comming from the front during acceleration. I removed the handle bar covers, seen nothing that could cause the noise. I snugged everything up by using wire ties on the electrical wireing on both sides. Still have the buzz.. |
| Subject: Re: Duct tape on a Swing !!! Thu Oct 17, 2013 9:56 pm | |
| You know how things turn out when you miss the rattle and buzz from a low speed pick-up. Well, it seems the duct tape on the metal inserts for the tabs in the steering covers has taken care of the buzz and rattle in the front panel. I went for a spin this afternoon, and don't remember getting rattled by the racket up front. No wonder they have duct tape on the ISS. |
| | | Microtouch Scooter Rider
Number of posts : 30 Location : Lancaster Pa Points : 4292 Registration date : 2012-08-24
| Subject: Re: Duct tape on a Swing !!! Fri Oct 18, 2013 8:44 pm | |
| Red Green would be proud!! :lol!: |
| | | Sponsored content
| Subject: Re: Duct tape on a Swing !!! | |
